ESM BF-110C    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> ESM BF-110C
Page: [1]
Login
ESM BF-110C - 11/6/2011 7:15 PM
teamqball
Score: 100
Last Login: 11/10/2011
Status: offline
This winter I'm planning on getting a BF-110C from ESM. I was wondering if you guys had any experience with this model and what engines you suggest, I was thinking of getting some Laser 120s or DLE-20s. So what do you guys think?
Hide Signatures
       Post #: 1
RE: ESM BF-110C - 11/6/2011 10:03 PM
tevans55
Score: 123
Last Login: 5/20/2013
Status: offline
I have the ESM B-25 which is similar in size to this plane. I used the DLE 20 engines and it will fly both of these 95" WS planes at 3/4 throttle. I have the ESM Spitfire 72" wingspan with the OS 120 AX and you will spend a fortune on fuel if you decide to use that engine. My B-25 is 33.5 lbs and I am flying it with 8 oz tanks. Not only is the fuel cheaper for the DLE 20's it uses much less than the OS 120's. Good Luck with your choice
Click to see fullsize image.
Click for fullsize
_____________________________
Nothing difficult is ever easy.
Spitfire Brotherhood #44
Hide Signatures
(in reply to teamqball)
       Post #: 2
RE: ESM BF-110C - 11/6/2011 10:16 PM
dutch Jan Hermkens
Score: 100
Last Login: 5/17/2013
Status: offline
But the sound of 2x four stroke engines is much much more nicer, and especially the lasers, than 2 strokes petrols.
regards,
Jan
Flying Dutchman. Multiple Scale Champion all over Europe, with B17, P61, Sunderland.
www.janhermkens.nl
Hide Signatures
(in reply to tevans55)
       Post #: 3
RE: ESM BF-110C - 11/6/2011 10:39 PM
teamqball
Score: 100
Status: offline
Ok, good to know tevans55 and yes I agree dutch Jan Hermkens but I don't really want to spend a ton on fuel. Though I would be interested in four stroke gas engines if you guys know of reasonably priced ones.
Hide Signatures
(in reply to dutch Jan Hermkens)
       Post #: 4
RE: ESM BF-110C - 11/7/2011 2:16 AM
tevans55
Score: 123
Status: offline
I don't think you will be disappointed by the sound of twin DLE 20's with Jetc wraparound mufflers.
Hide Signatures
       Post #: 5
RE: ESM BF-110C - 11/7/2011 3:29 AM
teamqball
Score: 100
Status: offline
Well I guess I will stick with those then, also, should I get twinsync?
Hide Signatures
       Post #: 6
RE: ESM BF-110C - 11/7/2011 6:22 AM
tevans55
Score: 123
Status: offline
You do not need twin sync. These engines will run within 100 rpm on the high and low end when properly adjusted and broken in. I made sure to break mine in on the ground with about 6 hours of run time on both before I flew my plane. You absolutely will not have any problems getting these engines to run together...they are fantastic engines. Use this information below from JediJody to break in your engines.
Click to see the file in new window.Attachment.pdf
Hide Signatures
       Post #: 7
RE: ESM BF-110C - 11/7/2011 6:28 AM
teamqball
Score: 100
Status: offline
Great! Well that saves me about a hundred bucks, thanks for all the help. I'll let you guys know when I'm finished getting all the parts and putting the plane together (might not be until spring though).
Hide Signatures
       Post #: 8
RE: ESM BF-110C - 11/7/2011 1:04 PM
tevans55
Score: 123
Status: offline
Let me know if I can help with setup. I set up the engines with a servo on the chokes which made shutting down the engines easy. I also used one 3500 mAh Nicad for both engines. I was able to use this battery as nose wieght. I put 2 leads on the battery and a switch/charge jack on the side of each nacelle. That way I could charge the battery from either jack and turn the power on/off at each engine individually during startup. Good Luck!
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
