HobbyZone SuperCub turning problems    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> HobbyZone SuperCub turning problems
Page: [1]
Login
HobbyZone SuperCub turning problems - 11/9/2011 4:13 AM
M9cat
Score: 100
Last Login: 11/18/2011
Status: offline
Its been awhile since i posted here,anyway I have a hobbyzone supercub lp 3 channel and the darn thing is just hard to turn,bank or pull out of a right handed turn..It dosnt respond at all to the rudder movenment..I guess im asking what is better to have it turnable or manuverable with more tail weight or more nose heavy? Its like the rudder yaw has no effect but a little, the rudder is able to move both ways to where it just about touches the elevator..Any help on why i cant turn much or pull out of a turn more rapidly..Thank you!
_____________________________
Live To Learn,Learn To Live!!
Hide Signatures
       Post #: 1
RE: HobbyZone SuperCub turning problems - 11/9/2011 1:09 PM
whitecrest
Score: 106
Last Login: 5/23/2013
Status: offline
Your wing may not have enough dihedral to translate yaw (created by the rudder) into wing banking. In this case, the plane will just slip sideways through the air after a heading change. If possible, try to increase the wing's dihedral angle (V) to make rudder turning more responsive. An alternative is to consider adding ailerons. You will definitely improve turning response with this modification.
Tim
Hide Signatures
(in reply to M9cat)
       Post #: 2
RE: HobbyZone SuperCub turning problems - 11/9/2011 10:41 PM
M9cat
Score: 100
Status: offline
ok thank you, will try and adjust
Hide Signatures
(in reply to whitecrest)
       Post #: 3
RE: HobbyZone SuperCub turning problems - 11/12/2011 10:23 AM
M9cat
Score: 100
Status: offline
it was the dihedral of the wings...not enough V
thank you whitecrest
Hide Signatures
(in reply to M9cat)
       Post #: 4
RE: HobbyZone SuperCub turning problems - 11/12/2011 2:17 PM
whitecrest
Score: 106
Status: offline
Good job! I'm glad you got it flying properly. I had experienced the same problem with one of my scratch-built planes. The dihedral angle was set at only 3-4 degrees, and rudder turning was terrible. One of my earlier ships, a Gentle Lady, had polyhedral wings and had excellent rudder turning.
Good luck with your future flights!
Tim
Hide Signatures
(in reply to M9cat)
       Post #: 5
RE: HobbyZone SuperCub turning problems - 11/12/2011 9:32 PM
cyclops2
Score: 111
Last Login: 3/1/2013
Status: offline
M9cat
Thanks for taking the time to post what did correct your problem. That will help others. Wish more people would do that.
We learn from others.
Rich
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
