Nimh for longest run times...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Nimh for longest run times...
Page: [1]
Login
Nimh for longest run times... - 11/10/2011 8:05 AM
Aksala
Score: 100
Last Login: 3/7/2012
Status: offline
 Wondering what battery would give the longest run time for a traxxas rustler vxl...
I'm gonna go with nimh for the time being...seen some video's of lipos burning up...scary...
So until I feel I need to I'll stick to a battery that won't burn my house down if I screw something up.
Hide Signatures
       Post #: 1
RE: Nimh for longest run times... - 11/10/2011 11:30 AM
guver
Score: 174
Last Login: 5/19/2013
Status: offline
Welcome to RCU. The highest capacity NIMH will give longest runtime if the voltages are equal. SubC are up to about 5000 + mah now.
_____________________________
and airplanes were in
Hide Signatures
(in reply to Aksala)
       Post #: 2
RE: Nimh for longest run times... - 11/10/2011 12:29 PM
collector1231
Score: 148
Status: offline
Higher MaH and higher voltage= better run time. 8.4 (or 7 cell) i think that lipo 2s are just as strong as 5000 mah 8.4 volts. Try this battery-  http://www.amainhobbies.com/product_info.php/cPath/1389_1392_1859/products_id/215887/n/Traxxas-Series-5-7-Cell-84V-NiMH-Hump-Battery-Pack-w-Traxxas-Connector or cheaper-  http://www.cheapbatterypacks.com/product/97/526/84-volt-Elite-5000-SC-Double-Stick-Hump-Pack.aspx it's up to you.
I may have 3 wheel drive and 1 wheel for brakes, but i''m still gonna win!
Hide Signatures
(in reply to guver)
       Post #: 3
RE: Nimh for longest run times... - 11/10/2011 7:14 PM
Aksala
Score: 100
Status: offline
So on scale of importance 1-10...
Name on the side of the battery.....?
Numbers on the side of the battery?
Thanks for the input guys.
Hide Signatures
(in reply to collector1231)
       Post #: 4
RE: Nimh for longest run times... - 11/10/2011 10:39 PM
guver
Score: 174
Status: offline
I'd say that an accurate number on the label is important. Name not so important , however the two names above can be trusted. So the numbers can also be trusted. I guess the name is important after all.
Hide Signatures
       Post #: 5
RE: Nimh for longest run times... - 11/11/2011 12:44 AM
Aksala
Score: 100
Status: offline
Any guesses to what an 8.4v 5000mah run time might be on a rustler vxl?
I keep hearing there are lipo batteries that you can run for an hour on...
Is 20-30 minutes the max for nimh?
Hide Signatures
(in reply to guver)
       Post #: 6
RE: Nimh for longest run times... - 11/11/2011 1:17 AM
collector1231
Score: 148
Status: offline
quote:
ORIGINAL: Aksala
About that, mabye 15 to 20 minutes. 15 on hard driving, and 20 on light driving
Hide Signatures
       Post #: 7
RE: Nimh for longest run times... - 11/13/2011 3:30 PM
Link119
Score: 128
Last Login: 5/20/2013
Status: offline
The lipo fires are from careless people.
Gws Slow Stick Brushless
Hide Signatures
       Post #: 8
RE: Nimh for longest run times... - 11/14/2011 5:37 AM
Aksala
Score: 100
Status: offline
Careless/Pothead....kinda same thing?
Hide Signatures
(in reply to Link119)
       Post #: 9
RE: Nimh for longest run times... - 11/14/2011 3:39 PM
378
Score: 163
Last Login: 5/9/2013
Status: offline
Well he is using it in a car, lipos can and will get damaged from crashes and hard landings. But that's mainly limited to soft-shelled packs, the hard shelled ones generally only take damage from extremely hard crashes.
OP, get a 2s 5000mAh lipo, suitable balancing charger, and a metal ammo can from your local surplus store. Put the battery in the can, hook the charge and balance leads up, and you're good. Even if the battery does let go it won't burn anything with it as long as it's inside that metal can. If you have a genuine fireplace, that, too, will work, just stick it in there. Or you can buy a brand name lipo charging sack, which again will prevent it from burning your house down if it does go.
My stash:
1 rally modded NTC3, 1 HeliMax Axe CX Nano, 1 Hobbico NexSTAR.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
