ys 91 4 stroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys 91 4 stroke
Page: [1]
Login
ys 91 4 stroke - 11/13/2011 10:44 PM
fulload
Score: 100
Last Login: 6/27/2012
Status: offline
My YS has fuel dripping from the vent line during operation can you suggest what might be done to correct this?
Thanks for your help.
Hide Signatures
       Post #: 1
RE: ys 91 4 stroke - 11/13/2011 11:45 PM
ThumbSkull
Score: 108
Last Login: 5/20/2013
Status: offline
YS does NOT have a vent line. It's a pressurized fuel system. There are NO connections to the muffler.
Hide Signatures
(in reply to fulload)
       Post #: 2
RE: ys 91 4 stroke - 11/13/2011 11:53 PM
fulload
Score: 100
Status: offline
My ys has a nipple located on the rear left [as you are facing the engine], lower 1/2 of engine which drips fuel. I called it a vent, it is probably something else.
Any thoughts or suggestions?
Thanks for looking and best wishes.
Hide Signatures
(in reply to ThumbSkull)
       Post #: 3
RE: ys 91 4 stroke - 11/14/2011 12:15 AM
ThumbSkull
Score: 108
Status: offline
Like this one?
Hide Signatures
       Post #: 4
RE: ys 91 4 stroke - 11/14/2011 12:51 AM
fulload
Score: 100
Status: offline
Thumb.....thanks for hanging there with me. Turns out the nipple is on the carburator. There are two nipples at the very front of the engine and the one on the carb. The supply and pressure come off the front of the engine. It is labled OS 91 AC.
It is the nipple off the carb that drips fuel.
Best to you.
Hide Signatures
       Post #: 5
RE: ys 91 4 stroke - 11/14/2011 1:01 AM
ThumbSkull
Score: 108
Status: offline
The nipple at the carb gets plumbed to the regulator just under the cam on the side of the engine like on the bottom image.
The rest of the plumbing is like the top picture. The top image is from the 91AC manual.
Replace that line with new tubing.
Hide Signatures
       Post #: 6
RE: ys 91 4 stroke - 11/14/2011 1:19 AM
petec
Score: 101
Status: offline
Here is a picture of a YS 91AC at this LINK
If you are dripping fuel from the carb nipple it is either loose, the washer is missing or the fuel tubing has lost its elasticity.
_____________________________
Team YS, Team Airtronics
Pattern Junkie, Revver Brother #82, Gear Head
Hide Signatures
       Post #: 7
RE: ys 91 4 stroke - 11/14/2011 1:32 AM
fulload
Score: 100
Status: offline
I was finally able to get the cowel off and get a closer look. What I thought wa a nipple appears to be a set screw or adjusting screw on the other side of the engine. It is not a niopple. My guess is the carb is dripping fuel. It was dripping off the set screw so I thought it was some kind of nippole.
Any thoughts on why the darb would drip fuel?
Thanks to you bogh for looking.
Hide Signatures
(in reply to petec)
       Post #: 8
RE: ys 91 4 stroke - 11/14/2011 2:29 AM
petec
Score: 101
Status: offline
Yep. if the regulator gets some crap in it and it doesn't close you will get a drip from the carb. If the engine is inverted you will get a little drip every now and then just from fuel giving in to gravity but a constant drip is the regulator not sealing shut.
Hide Signatures
       Post #: 9
RE: ys 91 4 stroke - 11/14/2011 3:07 AM
krayzc-RCU
Score: 104
Last Login: 5/25/2013
Status: offline
good deal that 91 is a beast i run a 16 x 6 on mine
smooth as silk!
Hide Signatures
(in reply to petec)
       Post #: 10
RE: ys 91 4 stroke - 11/14/2011 8:22 PM
fulload
Score: 100
Status: offline
Thanks guys so much for your help. Now if I can just figure out how to clean that regulator.
Best wishes.
Hide Signatures
(in reply to krayzc-RCU)
       Post #: 11
RE: ys 91 4 stroke - 11/14/2011 9:29 PM
petec
Score: 101
Status: offline
The regulator is pretty straightforward, before you begin take note of where the regulator is set. Pull the housing off the engine, back the regulator screw the whole way out and remove it and the spring, noting which way the conical spring points, and flush it out with raw fuel while exercising the plunger. Make sure you do all this in a clean environment as any dirt in the area will find its way into your regulator and cause you grief.
If you are not comfortable doing this you can box it up and send it in to YS for repair. Given the age of the 91 it might prove prudent to have it gone through.
Hide Signatures
       Post #: 12
RE: ys 91 4 stroke - 11/14/2011 9:59 PM
fulload
Score: 100
Status: offline
Pete; thank you. I was trying to find a drawing of the parts assembly. Your description help a lot.
Best wishes.
Hide Signatures
(in reply to petec)
       Post #: 13
RE: ys 91 4 stroke - 11/14/2011 10:02 PM
petec
Score: 101
Status: offline
http://www.centralhobbies.com/Engines/parts/YS91ACEX.html
Exploded diagram of 91AC.
Hide Signatures
       Post #: 14
RE: ys 91 4 stroke - 11/14/2011 10:45 PM
fulload
Score: 100
Status: offline
Thank you sir, working on it now.
Hide Signatures
(in reply to petec)
       Post #: 15
RE: ys 91 4 stroke - 2/19/2012 4:31 PM
wetbird
Score: 100
Last Login: 5/22/2013
Status: offline
Fullload
I know it's been a few months since your last post on the YS 91, was wondering if you got your engine running yet. I have a YS-91A and when you have trouble with this engine, it can be frustrating, even the plumbing can be confusing. But once you get it running right, it's a powerhouse!! I've had my YS-91 since 97 and it's still going strong!
Just wanted to throw my two cents in!..Enjoy!
Gerry
Hide Signatures
       Post #: 16
RE: ys 91 4 stroke - 2/20/2012 3:19 PM
fulload
Score: 100
Status: offline
Hey Gerry;
Thanks for checking up on me. I have not gotten into the 91 yet. Busyness keeps getting in the way. I have however put the plane on my hobby table 3 days ago to begin.
I have the detail breakdown right next to it and planned to make it the next project.
If I run into problems, can I come back to you?
By the way, you are right, the YS 91 has more power than should be allowed. I am really surprised at what it is capable of putting out. I have a Saito 90 for comparison and although the Saito runs well, there is no comparison relative to power.
Thanks again for the check back and best wishes.
Hide Signatures
(in reply to wetbird)
       Post #: 17
RE: ys 91 4 stroke - 2/20/2012 4:14 PM
fulload
Score: 100
Status: offline
Petre
Bit the bullet, and took the time to pull the 91 apart. Pretty straight forward, may have been a tiny peice of metal in it, but otherwise looked pretty clean.
I do have 1 questionm; How far in do I turn the large pring regulator screw? It appears to have a pretty wide adjustment range. Can you give me any tips for that?
Thanks again, and best wishes.
Hide Signatures
       Post #: 18
RE: ys 91 4 stroke - 2/21/2012 1:54 AM
ThumbSkull
Score: 108
Status: offline
Flush with the regulator body to start.
Hide Signatures
       Post #: 19
RE: ys 91 4 stroke - 2/21/2012 3:17 AM
petec
Score: 101
Status: offline
Yep start with the brass screw flush with the regulator body and go from there. Do NOT screw it down the whole way or you risk the little spring taking a set and not functioning properly. Also make your adjustments 1/8th turn at a time and allow the engine to catch up to the changes so you don't keep chasing the regulator.
Hide Signatures
       Post #: 20
RE: ys 91 4 stroke - 2/21/2012 3:56 PM
fulload
Score: 100
Status: offline
OK, I've got a dumb question. I make 1/8 turn adjustments with the screw, what am I looking for to determine when I have the setting correct? Will the engine just not run if it is too tight?
Thanks and best wishes.
Hide Signatures
(in reply to petec)
       Post #: 21
RE: ys 91 4 stroke - 2/21/2012 4:16 PM
petec
Score: 101
Status: offline
Check out this link:
http://www.julton.net/Fact%20Sheet%20YS%20Engines.html
It will answer a lot of questions.
Hide Signatures
       Post #: 22
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> ys 91 4 stroke
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
