RE: The Evader Coalition ~ T.E.C. Part 2.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition ~ T.E.C. Part 2.
Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
Login
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/13/2012 3:57 AM
cumquat
Score: 210
Last Login: 5/20/2013
Status: offline
i have 1 rear tire, not sure where i put the other. i have the reciever, but i cant quite remember what i did with the transmitter or antenna i do have the shocks though. however, i cant send any of it until next month as i'm tapped out i get money on the first, so i can have them out by that Tuesday (the 4th). i'll check back with you guys then to see if you still want the stuff. i know that's some time off, but it'll likely be before the new stuff is in stock. while i'm at it, does anyone need a sprint esc? i have one or 2 around here too, with the speed 2 motors (i know i have them somewhere).
_____________________________
HELP! IM STUCK ON AN ESCALATOR!
Hide Signatures
(in reply to cumquat)
       Post #: 526
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/13/2012 5:02 AM
vic2367
Score: 100
Last Login: 3/30/2013
Status: offline
anyone know the stock servo info on the evader ? wanna upgrade to a better servo ,,looking for more speed and torque , do i get a regular sized servo ?
emaxx 16.8
Hide Signatures
       Post #: 527
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/13/2012 5:15 AM
cumquat
Score: 210
Status: offline
yep, any old standard servo will do. when i stripped mine, i put in my trusty futaba s3305. not ery quick but it had enough torque to swing the evader when i held it by one tire
Hide Signatures
(in reply to vic2367)
       Post #: 528
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/13/2012 2:50 PM
JSS4
Score: 100
Last Login: 11/10/2012
Status: offline
I installed a Traxxas waterproof High torque digital servo and it is great? Part # is 2056, I think.
Also, the DX2e I got is great! Not as feature packed as the DX3c, but it is less than half the price.
Hide Signatures
       Post #: 529
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/14/2012 12:22 AM
DieHard1207
Score: 116
Last Login: 5/19/2013
Status: offline
I put a digital high torque servo in my evader ST just the other day. I think it's a 180oz. Does yours have metal gears? Mine does.
-When all else fails, angrily hammering the throttle is usually the best solution.
-If I can''t fix it, it ain''t broke
Hide Signatures
(in reply to JSS4)
       Post #: 530
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/14/2012 3:31 AM
NoTraxxisRustler
Score: 100
Last Login: 2/3/2013
Status: offline
Hey Guys,
I just scored a brushless gearbox on ebay. Anyone have any experience with this part? I'm thinking of giving the AE gearbox that I grafted into my EXT a rest and going stock BL. (tranny plate, mount etc). The AE gearbox is a ball diff, and I've really come to like it. Think it's worth swapping out? (anybody)
I see some of ya'll are looking for parts, there are a few people "parting" Evaders on ebay. I don't know why in the devil Tower cannot keep DTX parts in stock.
Local HobbyTown does not carry DTX parts anymore . . . which sux.
NTR
Hide Signatures
(in reply to DieHard1207)
       Post #: 531
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/14/2012 5:23 PM
DieHard1207
Score: 116
Status: offline
Hey, do you have an Evader ST Top Shaft, Mine is bent?
quote:
ORIGINAL: cumquat
Hide Signatures
       Post #: 532
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/14/2012 5:47 PM
EXT2Rob
Score: 177
Last Login: 5/17/2013
Status: offline
I don't understand DTX and their parts avalability or lack thereof either.  It's been like this for the two years I've been into this hobby.  I wonder if they just don't do the volume of Losi or AE, so they only order just so many parts from their (Chinese) manufacturer, and when they run out, we have to wait for the slow boat!
Regarding tires....if you're trying to remove old rubber from Duratrax wheels, good luck.  Their wheels are flimsy and neither boiling nor acetone will give you satisfactory results.  If your rubber is worn out, get new wheels with the new rubber. I think it's the only way you're gonna get a good glue-job and have the tires stick. If you try to mount new rubber on old rims, with the old bead still in the groove, it ain't gonna work.
Now if your foam inserts have broken down, and you still have useable tread, you CAN cut the inner bead around the rim, peel back the tire and remove/replace the old foam with new, then glue the bead back together. THAT works, I've done it. Only because your gluing the same rubber back together. The shapes match up so they can be glued.  But if you need new tires, just get new rims too.
Hide Signatures
       Post #: 533
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/14/2012 7:36 PM
Harlow
Score: 100
Last Login: 9/22/2012
Status: offline
I was trying to save a set of rear st wheels but the beads tore from the tire and are stuck on the wheels. Oh well. I do have a set of extra buggy wheels from my son's exb with dirt hawg truck tires on them. I just tried the boiling technique and it worked great I was able to get the tires off with no problem.
< Message edited by Harlow -- 8/17/2012 8:17 PM >
Hide Signatures
(in reply to EXT2Rob)
       Post #: 534
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 2:42 AM
NoTraxxisRustler
Score: 100
Status: offline
EXT2Rob,
Did you update to brushless tranny?? If so how is it holding up? (I scored one on ebay and considering swapping out the AE tranny that I put in)
I still say DTX made a big mistake marketing EXT's (with weak trannys) for a couple years when most of the motor selections were brushless. I have talked with dealers that contend that DTX is just fine. The guys at my local hobby town that hate them. But then, they are not the most well like group of guys in the Richmond RC world.
NTR
Hide Signatures
       Post #: 535
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 3:18 AM
cumquat
Score: 210
Status: offline
quote:
ORIGINAL: BurningEvader1458
quote:
ORIGINAL: cumquat
no, all i have is ext2 parts and both top shaft gears are worn. sorry.
Hide Signatures
       Post #: 536
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 3:55 AM
DieHard1207
Score: 116
Status: offline
I know the part numbers are different, but do you think the Nitro Evader ST Top Shaft would work?
Hide Signatures
       Post #: 537
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 4:06 AM
cumquat
Score: 210
Status: offline
not a clue.
Hide Signatures
       Post #: 538
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 5:22 PM
EXT2Rob
Score: 177
Status: offline
Harlow - Wow, you got the tire off the DTX wheels w/o destroying the wheel?  Good on you!  My buddy tried it and melted the wheel.
NTR - No I haven't upgraded to the actual BL tranny from the BL Evader, but I HAVE installed the metal diff from the BL in ONE of my cars.  Still waiting on DTX's Slow Boat From China for #2.  It's really odd: when we first got these cars, stock brushed mind you, we were stripping top gears like crazy. Of course, THEY were in short supply too.  Now that we've upgraded to BL systems, we haven't stripped one top gear yet!  It's like, for a while, DTX's manufacturer lost the recipe for good hard metal and were putting out crap, but then they fixed it?  I dunno.  Now it's just the plastic diff cases that strip.  The metal diff solves that problem.
Will a nitro evader top shaft work in the electric?  You'd have to check the specs. Dimentions, etc.  RCLUGNUT10 may have info on that.  Check here:  https://sites.google.com/site/evaderinfo/home
Hide Signatures
       Post #: 539
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 7:53 PM
Harlow
Score: 100
Status: offline
I'm not sure if it was a DTX wheels. But the boiling worked I was trying to salvage the tires which was sucessful.
Hide Signatures
       Post #: 540
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 8:51 PM
DieHard1207
Score: 116
Status: offline
I am currently in my Evader ST running the BL Evader Tranny. (Except the top shaft) I just installed it, but haven't had a chance to acually try it out do to the lack of money to buy a new battery. My old NiMh crapped out, and I have tried multiple times to get it back to life, but it just ain't work'in. I was pretty easy installation, but getting the parts is a whole other issue. I was lucky enought to catch the Rear Chassis Plate on eBay, and won the bid.
Hide Signatures
(in reply to Harlow)
       Post #: 541
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 10:39 PM
NoTraxxisRustler
Score: 100
Status: offline
Not meaning to but in, but go to HobbyPartz.com and get the Gen's Ace. 4000MAH, 30C, 7.4 V puts NIMH to shame. 22bux. I've got one, it's great. You will need the EXT2/BL esc plate, battery strap. But that's like 6.00.
Hide Signatures
       Post #: 542
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 10:44 PM
NoTraxxisRustler
Score: 100
Status: offline
I scored the whole DTX tranny on EBAY. The ASC tranny I have in mine has been great, but it's going to need a bit of work. Got the DTX tranny bc I would like to go back to stock tranny mounts etc. But I really have mixed emotions with DTX QC issues and all. We'll see.
NTR
quote:
ORIGINAL: EXT2Rob
Hide Signatures
       Post #: 543
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/15/2012 11:31 PM
EXT2Rob
Score: 177
Status: offline
Hey Burnin',  are you using a brushless system?  In my experience, a brushless system will suck the life right out of NiMh cells.  I eventually ruined all of my NiMhs on the Castle system I had.  I don't think they were built to deliver the current BL systems can pull.  They over-heat and eventually won't take a charge.  Guess that's why they invented LiPo!
Big +1 on those Gens Ace batts, good value.  This battery fits PERFECTLY in the Evader chassis:
http://www.hobbypartz.com/98p-30c-4000-2s1p-hardcase-direct.html
Hide Signatures
       Post #: 544
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 2:22 AM
DieHard1207
Score: 116
Status: offline
Yeah, I'm running the Traxxas Velenion 3S ESC and 3500kv Brushless sensorless motor. I bought the 3S one so I could run 3S, otherwise I would of bought the Castle Creations system. I guess the system really drained my DTX 3800mah NiMh. I can't get it to charge. I am saving for lipo, I was gonna get the Venom 11.1v 35C 5000mah battery, but everybody says the Traxxas system runs hot on 3S. What do you guys think?
quote:
ORIGINAL: EXT2Rob
Hide Signatures
       Post #: 545
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 3:26 AM
cumquat
Score: 210
Status: offline
you will regret 3s as your only pack. i have only had 2s and the brief period i ran dirt hawgs in back, i was pulling wheelies on gravel! the stock tires will pull wheelies on asphalt and at times on grass but wont hook up well enough on gravel.
Hide Signatures
       Post #: 546
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 7:22 AM
Harlow
Score: 100
Status: offline
just curious for you guys running brushed motors what esc / motor combo are you using? Gear ratios? My youngest son is running an Ext with the radio, receiver, and esc out of the ST I'm redoing with a Traxxas Stinger motor. Runs pretty quick for him. My oldest son is running an exb with a stock esc and a Stinger motor as well. The EXB was geared with an 18t pinion and an 87t spur gear. I switch it to the stock 20t/88t since he is running truck wheels on the back. Not sure what the stock gear ration is for the exb? Is it the same as the evader truck? I'm redoing an old evader so it's more like the ext/ext2. Changed the front axles, a BL front bumper, I have an EXT trans, rear chassis plate, dog bones and axles on the way. I have a Novak Explorer II esc I was going to run the only down fall is no reverse. But I have a Traxxas XL-5 water proof esc I'm going to use. Now just have decide on an motor. Was going to get a Trinity Speedgems 17t Double Onyx motor but I'm undecided. I just plan on bashing with it and just have fun with my boys.
Hide Signatures
       Post #: 547
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 10:48 AM
cumquat
Score: 210
Status: offline
i liked the axial 27t, loads of torque and they were $13. i think they run $15 now. they have one of those rotor mounted fans inside so it doesnt get too hot but that also makes it slightly longer than most 540s.
Hide Signatures
       Post #: 548
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 4:17 PM
Harlow
Score: 100
Status: offline
do you run stock gearing with it?
Hide Signatures
       Post #: 549
RE: The Evader Coalition ~ T.E.C. Part 2. - 8/16/2012 4:26 PM
DieHard1207
Score: 116
Status: offline
Harlow-Are you planning on doing the metal diff in that Evader that your redoing? If so, please pm me about the shims.
Cumquat-What do you mean by I will regret 3S as my only pack? I have my evader set up for 3S. Should I start out with a 2S?
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
