RE: The Evader Coalition ~ T.E.C. Part 2.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The Evader Coalition ~ T.E.C. Part 2.
Page: <<   < prev  40 41 [42] 43 44 45 46 47 48 49   next >   >>
Login
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 5:56 PM
jk47
Score: 100
Last Login: 12/17/2012
Status: offline
That 2800kv motor is basicaly an 1/8 motor and while it doesn't spin all that fast i'd be running 17t pinion to 50t spur which should be more power and the same top end as your 5700kv motor, so that combined with 1/8 buggy tires and I think would be a bit too much either for my diff or that topshaft gear. I'm trying to ensure a bullet proof tranny, so while the b2 gear would prolly hold up, I'm not convinced. I might try my stock tranny for a few runs but I doubt it will last.
_____________________________
If I had a nickel for every time someone asked if it was gas.
Hide Signatures
(in reply to Crash7772)
       Post #: 1026
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 7:55 PM
cumquat
Score: 210
Last Login: 5/25/2013
Status: offline
um, there is quite a few differences between a 540 (1/10 scale) and 775 (1/8 scale) motor. for one, if it is actually a 1/8 scale motor, you'll need to at very least drill new holes to mount the motor to the plate. second, they all use 5mm shafts, so a standard pinion wont fit. 3rd, most require 4s to operate properly. and 4th, you will NOT be able to keep the front end down. if this is your motor http://www.hobbypartz.com/96m214-3674-2800kv-6t.html , it's not 1/8 scale, it's just a lengthened 540, basically a short course motor. still, you will need a pinion with a 5mm hole but guessing by the conversion to 32p, i presume you know that. one warning on that motor, it draws a lot of power. more than most any 1/10 scale esc can supply. i still stand by the statement that the front might as well have ailerons on it. that's the only criticism i have, the rest seems promising. good luck!
HELP! IM STUCK ON AN ESCALATOR!
Hide Signatures
(in reply to jk47)
       Post #: 1027
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 8:34 PM
jk47
Score: 100
Status: offline
That is the motor i'm going to use. I no its not really an 1/8 motor. I was just trying to explain that it is a fair bit torquier than a 5700kv 540.  Yeah keeping the those front wheels down seems to be a troublesome task. I'm mostly running on a golf course (shhhh! )so maybe the limited traction will help...
Hide Signatures
(in reply to cumquat)
       Post #: 1028
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 9:20 PM
cumquat
Score: 210
Status: offline
if you zip by and plow their balls into the hole, they wont mind
Hide Signatures
(in reply to jk47)
       Post #: 1029
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 9:21 PM
EXT2Rob
Score: 177
Status: offline
DANG.  I wish those Nitro Evader CVDs would fit in an EXT. Bet they'd hold up better than the EXT CVDs.  Then again, maybe not!  I just noticed that the axle dia on the nitro CV is slightly smaller, hence, I'd suspect they'd break just as readily as the ones I have.  Feh!
Hide Signatures
(in reply to jk47)
       Post #: 1030
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 9:36 PM
egbasher
Score: 100
Last Login: 5/24/2013
Status: offline
I'll bet it's your wheel. It only takes one slip between the wheel and the pin to round off the edges of the slots in the wheel.  You did remember to put in the spacer behind the pin.  That provides the space for the wheel to slip on and get the pin deep enough in the grooves so it won't slip and rip.  Hope this helps.
quote:
ORIGINAL: DieHard1207
Ya, I know what ya mean. Just took it out for a run, and I got 4 feet, and the left axle started slipping.  I don't know if I sheared it off, or it wrecked the wheel, or maybe I cut the drill bit pins too short. I don't know. I'm just too lazy and it's too wet for me to take it apart and find out right now. I guess I'll take it apart when it drys off. I'm sick of it being so muddy outside with these morning snows and then later the sun comes out and melts it all making puddles of crap all over.  If it's gonna snow, SNOW!!! But if it isn't, just let everything be DRY!!!! I hate this half-snow junk.
Sorry if I sound angery and that I have negative opinions lately, I'm just mad because I spent 1/2 hour of struggling time perfecting those stupid make-shift pins and they are falty right from the start. I hope that everyone is not baffled by what I said and this ends up being the last post here for the next week. I'm just having one of those bad (awful, retarded, crappy, most hated) days.
Hide Signatures
(in reply to DieHard1207)
       Post #: 1031
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/13/2012 9:51 PM
egbasher
Score: 100
Status: offline
I dunno, but my dogbones and the ext2 CV's both fit my brushless metal diff.  I ordered the diff separately but I assume it's the same one that comes with the brusless evader car.
Yes, just what I said. (you posted while I was typing.) But yeah, the balls on the ends of the dogbones are too big for the Evader Brushless tranny. The CV shafts only work on the ST diff outdrives. I wish I could run CVs.
quote:
ORIGINAL: jk47
Rclug, arn't the out drives smaller on the ext, ext2 and brushless diffs? Or is that just the ext? If they are the stock shafts won't work.
Hide Signatures
       Post #: 1032
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/14/2012 1:58 PM
DieHard1207
Score: 116
Status: offline
Dang!!! I totally forgot that spacer! That's probably my whole stinkin problem!!! URRRRGGGHHHHH!!! No wonder it sliped. My wheel isn't completely wrecked, and I do have a spare wheel with the right mounted tire.  Man, I am so mad that I forgot that!!! URRGH! Thanks for reminding me, I probably would have went out and spent another $20 on a new pair of tires soon. Thanks again!
quote:
ORIGINAL: egbasher
-When all else fails, angrily hammering the throttle is usually the best solution.
-If I can''t fix it, it ain''t broke
Hide Signatures
(in reply to egbasher)
       Post #: 1033
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/14/2012 8:20 PM
egbasher
Score: 100
Status: offline
Glad to help.  Don't be too hard on yourself Diehard. The only reason I thought of it is because I did the same thing!
quote:
ORIGINAL: egbasher
Hide Signatures
       Post #: 1034
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/15/2012 12:13 AM
DieHard1207
Score: 116
Status: offline
Well today (Like all Fridays), I went in to the LHS and picked up my lipo for my Losi Micro Brushless SCT that I ordered. And taking EXT2Rob's idea, I bought (2) 3ft peices of music wire that was the right diameter. (That stuff is hard! I think I'll have to get some bigger wire cutters from the garage to cut that stuff. Or do I use a hand saw?) I was just about to walk out, when I noticed that the balancing plug on the lipo wouldn't work with my balance block. So I talked to Bob about it, and he spent 1/2 hour trying to find out what kind of adapter to use. He finally came up with an Eflite wire set that would work....But it was $11.99 for just 4 wires and 2 connectors!!! It turns out that I charge it through the balancing cable. I finally got out of there after taking a $20 loan from my sister to pay for part of the battery, the music wire, and the adapter.  But $20 won't be too hard to get...I don't think.  So tonight I'll try to make some wheel pins, AND be SURE to put those spacers behind them!!!
Hide Signatures
       Post #: 1035
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/15/2012 5:07 AM
cumquat
Score: 210
Status: offline
that's what siblings are for, walking ATMs of course i'm usually the one with money
Hide Signatures
       Post #: 1036
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/15/2012 7:22 AM
Crash7772
Score: 100
Last Login: 1/1/2013
Status: offline
quote:
ORIGINAL: jk47
Mine runs around 40 (conservative guess) on 2s and hopefully 80+ on 3's (and the motor can take 4's but that's pushing the limit of the motor). I do understand that lower kv generally creates more torque but on 2s but as far as I know the lower the kv on the same voltage runs much less rpms. I don't think you'll be pushing it to much as a standard 1/8th scale tires is roughly 4.6". Mine does wheelies easy on 2s so I made a wheelie bar and also have some weight to add to the front when 3s go in. I'm currently running Mamba Max 5700kv (punch control on max), Gens Ace 40c 2s, 24 pinion, 81 spur, AE slipper mod, B2 diff w/carbide balls, Jaco foams, and EXT metal idler in a Evader Pro ST. But will be changing gearing when going to 3s but below are theoretical numbers. Running the same math with the gearing you said and figuring the 4.6" tire height you should be close to 40 which is pretty fast for a basher type setup (I think my Boss would kill me if I took mine out on the golf course though....lol).
Rollout 1.18.1
Total Motor Speed 47880rpm(2s)71820 (3s)95760 (4s)
Theoretical Maximum Vehicle Speed 53.555mph (2s)80.32 (3s)107.1 (4s)
Hide Signatures
(in reply to jk47)
       Post #: 1037
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/16/2012 3:26 AM
DieHard1207
Score: 116
Status: offline
Well, I made some wheel pins about an hour ago. They turned out better than I thought they would. I haven't gotten a chance to try them out yet due to rains and severe down pours. " alt="" mce_src="/forum/js/punymce/plugins/emoticons/img/trans.gif" src="http://www.rcuniverse.com/forum/js/punymce/plugins/emoticons/img/trans.gif" /> Here are some pics.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1038
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/16/2012 3:28 AM
DieHard1207
Score: 116
Status: offline
 I apologize for the screwed up post...Just ignore the URLs and other things that don't make sense.
Hide Signatures
       Post #: 1039
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/16/2012 4:18 PM
EXT2Rob
Score: 177
Status: offline
Good catch, EGbasher!  Yep, gotta have them spacers.
DH, yeah that music wire is tough stuff. I'd imagine that it would dent your average pair of wire cutters. I use a Dremel, or in a pinch, screw cutters. (You know, one of those plier/stripper tools that has threaded holes for various size screws, that allow you to cut screws to length.)  Just remember to carefully apply a little blue loctite to the pin.  They don't fit tightly and tend to fall out upon removing the wheel.
Hide Signatures
       Post #: 1040
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/16/2012 6:29 PM
DieHard1207
Score: 116
Status: offline
Hey, you were right EXT2Rob! I just went out and bashed the heck out of my Evader just to test it. (I swear, that thing has been to hell and back.) It held up perfectly well! Thanks for the fix!  I do have a question. I have the spacers, but there is no room for one behind the pin. It's like the axles aren't long enough, or the hub carriers are too thick. The hub carriers are the original ST. But the axles are EXT2. The space between the hub carrier bearing and the pin is so small that I can't even fit a 0.0012 washer in there. I have tried pushing the bearings together farther, but I think they're all the way together. Do you have any idea on what's wrong?
Hide Signatures
(in reply to EXT2Rob)
       Post #: 1041
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/17/2012 5:51 AM
egbasher
Score: 100
Status: offline
Glad you got it running DieHard.  I'd say take out the bearings and clean them and the hubs real good.  Maybe there's something preventing a bearing from fully seating.  If that doesn't work then I probably is the ST hubs.  WIthout a spacer you must be running the wheel pins right near the edge of the wheel slot.  I've munched a couple of wheels when the hub nut backed off a bit and that was with a spacer.
Hide Signatures
       Post #: 1042
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/18/2012 3:56 AM
DieHard1207
Score: 116
Status: offline
Well, I took apart my evader's hub carrier bearings and found that when I assembled it, I actually had 4 of those spacers that go behind the pin, and I put 2 of them between the two bearings and the center spacer. So I took those out, and reassembled it, and sure enough, the spacers fit behind the pins!  I can now tighten my wheel nuts all the way with the wheel still spinning freely. Thanks again egbasher!
Hide Signatures
       Post #: 1043
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/18/2012 6:51 PM
egbasher
Score: 100
Status: offline
Happy i could help DH.  Life's a b*tch.  Ya get a car running good and then winter hits...
Hide Signatures
       Post #: 1044
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/18/2012 10:14 PM
DieHard1207
Score: 116
Status: offline
Yeah. Do you and EXT2Rob get much snow out there in California? It looks like a green Christmas this year.  But if it's not too cold, and it actually stays dry, I might just not put my lipos in storage mode and just run them as much as possible. Kinda hoping for snow though to go snowmobiling in.
Hide Signatures
       Post #: 1045
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/19/2012 6:31 AM
egbasher
Score: 100
Status: offline
Up in the Sierra Nevada Mts. it snows a lot.  I live down in the central valley near Sacramento.  It rarely snows here.  EXT2Rob lives up in the foothills around 1500 feel elevation.  He gets snow about once a year but just an inch or two and it usually melts in a day.  The real snow starts around 5000 feet in elevation and Lake Tahoe (around 6500 ft.) gets lots of the white stuff.  We're lucky.  We pretty much can race all year although ya really  gotta watch motor temps during the summer.
Hide Signatures
       Post #: 1046
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/20/2012 3:20 AM
DieHard1207
Score: 116
Status: offline
Yeah. How hot does it get in the summer?
Hide Signatures
       Post #: 1047
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/20/2012 5:58 AM
egbasher
Score: 100
Status: offline
Usually in the 90's.  We get heat waves of 4 or 5 days in a row in the 100's a couple times each summer.  When the air temp is 90 the track temp can easily be 125.  CA sun is hot!
Hide Signatures
       Post #: 1048
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/20/2012 4:54 PM
EXT2Rob
Score: 177
Status: offline
Yes indeed.  Summers get hot, but at least not HUMID hot like Michigan gets, huh DH?  But even "dry heat" can get pretty miserable when it's over 100.  What I call "a-hundred-an-shoot-me".  Those days you gotta find shade to stand in an wear sunscreen.  And usually gear down a tooth or two to keep motor temps in check.
But yesterday, the ground started out crunchy. Frosty and a cold 32 degrees.  But at least it was clear and the sun warmed up the track and air.  Started out kinda muddy, but as the day wore on, the track got drier, but kept the perfect amount of moisture, giving us great traction and a great race day.  Albeit, a little shorter. Once the sun dropped below the horizon, it was too cold so we called it a day.  Traction must've been high, as I snapped one of my CV axles!  Snapped off right where the shaft meets the CV joint.  I think I'm going back to using the stock dogbones/axles.  They hold up better and are a lot cheaper. The difference in efficiency probably isn't significant.  I've broken two of those CVs in the last two months, and at $17/pr, I think I'll go back to stock.
But I'll tell you what, guys, if you think you need a little more power and going 3S is just too much, stay with 2S but get a higher C-rating!  EGbasher an I have been running 25-30C Lipos, but we just picked up a couple 40C Gens Ace batts. The difference in performance is like you just got a whole new motor!  You know how your car drives with a freshly-charged battery in it?  That's what a 40C is like for the whole runtime!  Mid-range power is punchier and the top-end is a little higher. Our 18mo old LiPos have lost half their capacity and runtime. Probably about time to replace them.  We didn't care for them quite properly, leaving them sit fully charged most of the time.
Hide Signatures
       Post #: 1049
RE: The Evader Coalition ~ T.E.C. Part 2. - 12/21/2012 3:38 AM
DieHard1207
Score: 116
Status: offline
It doesn't get HUMID...it's just gets a little humid. But we have central air!  Besides, in the summer, it doesn't get dark till 10pm. And by that time it's well cooled off. Just the right temps to run evaders!!  So whats everyone got planned for the weekend? I'm going south to Kalamazoo for my aunt's Christmas party. I asked her for a pair of slippers, and for (6) Elfite battery packs for my MCX2. Can't wait to run that thing. The lipos went bad months ago when I left them laying around fully charged.
Hide Signatures
       Post #: 1050
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.608RCU1
