RE: BJCraft Episode    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: BJCraft Episode
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: BJCraft Episode - 9/24/2012 12:07 PM
danamania
Score: 105
Last Login: 5/21/2013
Status: offline
Sooo... what are the expected differences in flight characteristics between the Episode and the Nuance, given that there is good product differentiation between the two ARFs? Any design notes from Mr. Park that we can discuss yet? As flight reports look to be a week or two away, it will be interesting to see if the expectations come to fruition. Cheers!
_____________________________
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to shannah)
       Post #: 126
RE: BJCraft Episode - 9/24/2012 2:03 PM
rcpattern
Score: 100
Status: offline
Dana,
My gut feeling is the Episode is designed for the F type sequences. the DTFS wings help with snaps, although, with some work, I was able to get my Nuance to snap very well. I believe that with the lower wing area of the new shape wings that the canalyzer adds some of the wing area back, but it is closer to the center of the fuse, but also helps improve some of the yaw instability that the Nuance displays at certain speeds. I added tail fences to mine and it took care of that issue. From my experience with multiple Nuances and a large number of flights, my feelings are that the plane was designed to fly very slow and close in. It took some work to make it happy at higher speeds. I think that a lot of the design changes in the Episode will help with a wider speed range. I realize others may disagree with my observations, but that has been my personal experience with his planes. With some effort, I absolutely love how my Nuances fly, even though both FAI sequences.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to danamania)
       Post #: 127
RE: BJCraft Episode - 9/24/2012 2:42 PM
rcpattern
Score: 100
Status: offline
Here are my Nuances with stab fences installed. 1/8" depron.
Arch
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to rcpattern)
       Post #: 128
RE: BJCraft Episode - 9/24/2012 3:03 PM
underdw
Score: 100
Status: offline
Thanks for the hints Arch.
I've got about 50 flights and one contest on mine now. I like it, but something that I can't quite put my finger on is bugging me.
I'd try your stab fences. Would you be willing and able to PM me the stab fence pattern?
Thanks, Dan
(and I'll try slowing the rudder servo speed down, John Gayer
Hide Signatures
       Post #: 129
RE: BJCraft Episode - 9/24/2012 3:30 PM
smcharg
Score: 110
Status: offline
Arch is exactly correct (Steve would be able to chime in about this as well).  The Episode is designed particularly for the F sequence.  After quite a bit of communication with BJ, it is quite clear that he believes that the current F sequence type of maneuvers will become more and more predominant in FAI as we progress.  He was quite clear that anyone would be hard pressed to make the Episode fly the P sequence as well as the Nuance but the Episode was definitely designed to be the F sequence slayer.
This has also reinforced my own belief that one either needs an airplane for each sequence in FAI or two completely different setups utilizing one aircraft.  I have spoken to many of my FAI friends who concur.  This is just my opinion however and I have zero doubt that many of the great FAI guys will prove otherwise.  These are the same guys that can win with a brick and motor though.
Scott McHarg
Hide Signatures
(in reply to underdw)
       Post #: 130
RE: BJCraft Episode - 9/24/2012 7:23 PM
Portlandflyer
Score: 100
Status: offline
So Arch, how are you attaching the stab fences?
Hide Signatures
(in reply to smcharg)
       Post #: 131
RE: BJCraft Episode - 9/24/2012 7:37 PM
rcpattern
Score: 100
Status: offline
I just used silicon rubber in a tube. Basically clear caulk. Works great, and its easy to remove if I ever want to play with different sizes and shapes, which I do plan to do. Just haven't gotten around to it yet.
Hide Signatures
(in reply to Portlandflyer)
       Post #: 132
RE: BJCraft Episode - 9/24/2012 7:52 PM
Portlandflyer
Score: 100
Status: offline
Arch,
Hide Signatures
       Post #: 133
RE: BJCraft Episode - 9/25/2012 3:21 AM
jgg215
Score: 105
Last Login: 5/20/2013
Status: offline
Dan,
Not just me. BJ put the servo speed issue in his technical notes. All I did was read them and try it out.
Considering the way you flew the Nuance this past weekend here in Albuquerque, I'm not sure you should be allowed to fix anything that might improve the airplane.
John
Hide Signatures
       Post #: 134
RE: BJCraft Episode - 9/25/2012 8:10 PM
Thinn
Score: 100
Last Login: 5/15/2013
Status: offline
Does anyone have any thoughts regarding the difference in characteristics between the Episode and the Arixtra?
I only fly the F3A P-schedule, and reading the last posts made me wonder. I really like the design of both planes, but favour the Episode as I don't have time to build!
Any thoughts are welcome!
Audun
(Considering going el.....)
Hide Signatures
(in reply to jgg215)
       Post #: 135
RE: BJCraft Episode - 9/25/2012 10:11 PM
shannah
Score: 105
Status: offline
B.J. Park has put some information regarding the stab fences and wing adjusters here:
http://rcone.kr/board/index.html?id=bjair1&no=103
Team BJCraft
Hide Signatures
(in reply to Thinn)
       Post #: 136
RE: BJCraft Episode - 9/28/2012 11:08 PM
F3A Unlimited
Score: 123
Status: online
The "company Episode" is ready to fly and will probably go out tomorrow or Sun to get some flights on it. Just needs the arming plug assembly installed. More details shortly..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
F3A Unlimited
Hide Signatures
       Post #: 137
RE: BJCraft Episode - 9/28/2012 11:12 PM
danamania
Score: 105
Status: offline
Spiffy! It sports an Advance? All the best for a great Maiden!
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to F3A Unlimited)
       Post #: 138
RE: BJCraft Episode - 9/29/2012 1:24 AM
svrcp
Score: 100
Last Login: 5/22/2013
Status: offline
Where does the LINE start's . Hold my place in line for Sunday, I be there tomorrow if I could to bad for honey do's. HAHA.
Look great
Jr
D2
Hide Signatures
       Post #: 139
RE: BJCraft Episode - 9/29/2012 9:45 AM
nicepoz
Score: 100
Last Login: 4/21/2013
Status: offline
Hello
Are you guys using the original hinges that comes with the plane?
Size of spinner?
Total weight?
Regards Roland
Hide Signatures
       Post #: 140
RE: BJCraft Episode - 9/29/2012 10:45 AM
serious power
Score: 100
Status: offline
Hi Chris,
Do you know what the incidence of the cannaliser is relative to the wing.
Brian
Hide Signatures
       Post #: 141
RE: BJCraft Episode - 9/29/2012 6:58 PM
shannah
Score: 105
Status: offline
I'm back home and will pick up where I left off.
As soon as I get the wing installed I'll measure incidence relative to the channelizer.
I've started on the wings and will set them up with the stock horns. On the Nuance I used MK style aluminum horns with the ball bearing cleavis's. That turned out to be unnecessary (and more work) in my opinion and I will use the stock FR4 horns that come with the kit. I'll still used ball bearing cleavis's however.
Now for a word of caution.
THESE WINGS ARE VERY LIGHT AND FRAGILE.
If you notice the weights I posted, these wings are much lighter than the stock Nuance wings. In fact, they are even lighter than the set of Nuance DTFS wings that I have (they appear to be the same size but I haven't had a chance to compare them in detail yet).
B.J. told me that he went very light on the balsa on these wings. The sheeting appears to be thinner than on the Nuance. So, they must be handled with great care. One of my wings had a slight indentation which may have been caused when DHL decided to add some air holes to the shipping crate (I was really worried when I saw the bottom of the crate). Or, it may have been caused during packaging or even by me during unpacking since it looks like about the size of a thumb print.
I pressed the indentation out and dripped some thin CA in the area. It looks OK and doesn't appear to have any weakened structural issue. I think I may drip some more thin CA around the area and also do that on the other wing. I am already thinking about how I must tell my caller at a contest not to touch the wing when picking up the plane.
Treat these like you would a honeycombed foam wing.
I noticed a very slight bow in the TE of the right aileron. The TE is thinner on this wing than on either of the Nuance wing styles. Most likely due to the thinner sheeting. So, a quick pass of the monokote heat iron straightened it right out.
The servo installation is the same as on the Nuance. In fact, the pushrod lengths appear to be identical. If I were lazy, I could probably just remove my servos and pushrods from the Nuance and transplant them into these wings. But, I don't want to disturb the Nuance.
As a reference, I am posting the link to the Nuance build instructions from B.J.'s site. These also apply to the Episode. But, a few things such as battery tray placement, are different. Battery tray will be positioned for the proper CG.
http://rcone.kr/board/index.html?id=bjreference1&no=11
Team BJCraft
Hide Signatures
(in reply to serious power)
       Post #: 142
RE: BJCraft Episode - 9/30/2012 11:40 PM
rcpattern
Score: 100
Status: offline
Had the chance to fly this plane today. VERY impressive. Flies everything well. They took the best parts of the Nuance and Prolog, kept them and then made it do integrated rolling stuff even better. I was stunned at how solid it was even through the lower class maneuvers. Definitely a phenomenal plane and one I will have in my garage very soon.
Thanks for the flights Chris!
Arch
Hide Signatures
       Post #: 143
RE: BJCraft Episode - 10/1/2012 12:45 AM
shannah
Score: 105
Status: offline
Can't wait to get mine done..
Here are a few updates. I noticed some extra bracing in the fuse so I included a couple pics of that. The bulkhead behind the canopy is reinforced, most likely due to the channelizer. There is also a horizontal bulkhead in the tail. That should stiffen up the tail.
The aileron cutouts and mounting plate are the same great fit as teh nuance.
I decided to change the rudder installation. I had no issues with the side mounted servo in the Nuance but I decided to mount it in a more traditional fashion. Similar to what Chris Fitzsimmons did on his Nuance. I fabricated a mounting plate and then installed the servo into the plate. I am using a 1.25" MLP arm from AirWild (had it left over from my IMAC days). The arm extends out through a slot in the side of the fuse.
In order to make the plate I first made a trial version from Depron then made the final out or Glass/Nomex plate with some plywood reinforcement on the bottom for the servo screws.
The stabs are mounted in the same way as the Nuance. I installed the BLS153 servos in the pre-existing mounts in the stab.
By the way, someone asked about the hinge type being used. I don't use the supplied hinges. Instead, I always use the Great Planes CA hinges. They are thicker and more "hairy" than the stock ones and most others on the market. I have always had great luck with these hinges.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Team BJCraft
Hide Signatures
       Post #: 144
RE: BJCraft Episode - 10/1/2012 10:36 AM
pippy
Score: 100
Status: offline
Hi shannah,I like the method of installing the rudder servo you have done. But how do you get at the screws?
Paul Houlihan
Hide Signatures
       Post #: 145
RE: BJCraft Episode - 10/1/2012 2:35 PM
nonstoprc
Score: 110
Status: offline
I like the method too and can use it on my passport if I want to turn the split rudder to single rudder.
The color scheme on the Episode resembles the alien characters in the movie Transformer. Cool.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to pippy)
       Post #: 146
RE: BJCraft Episode - 10/1/2012 3:47 PM
shannah
Score: 105
Status: offline
quote:
ORIGINAL: pippy
It is pretty accessible. But, to be sure, I tested it before I glued in the tray...
I put the servo in the tray before installation and screwed it in. Then removed the screws and the servo. This makes it easier to screw it in once installed since the holes already have been threaded.
I use socket head servo screws from Microfasteners.com http://www.microfasteners.com/catalog/standard.cfm?Category=TWS&SubCategory=SHWHMS
Then, I use a ball head hex driver so that you can be at a slight angle. Once I get the screws pretty well driven in I use one of those simple hex drivers with the 90 degree bend to torque completely.
You can use a phillips head screw and drive in the screws with a phillips head driver bit from a socket driver. Just twist the bit with your fingers. Or, use one of those flexi shaft socket driver things you can get at Harbor Freight.
Keep in mind that there is a big access hatch in the side of the fuse on the Nuance and Episode and there is also a large cutout in the stab mounting area. That makes it easy. If you are going to do this on a plane which has no access hatch (i.e. Passport) you'll either need to cut a hatch in the side or put one in the bottom and go in from underneath.
Team BJCraft
Hide Signatures
(in reply to pippy)
       Post #: 147
RE: BJCraft Episode - 10/1/2012 4:10 PM
F3A Unlimited
Score: 123
Status: online
Some pics from 9/30 at the "Come fly the company Eposide day" Archie Stafford flying the Episode -note how little rudder it needs to fly knife edge. Line up of the current BJ Craft 2 meter F3A line
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
F3A Unlimited
Hide Signatures
       Post #: 148
RE: BJCraft Episode - 10/1/2012 9:22 PM
BHolsten
Score: 100
Status: online
Very Kool,..can't wait to see one in person, maybe fly one.
bholsten
Hide Signatures
       Post #: 149
RE: BJCraft Episode - 10/1/2012 10:32 PM
F3A Unlimited
Score: 123
Status: online
The Episode will be at Winston - Salem and at Green Sea contests in Oct. Check it out and take a test spin.
We have been working with the factory and are pleased to announce that the US retail price for the Episode ARF is now LOWERED to $2000 from $2200.
F3A Unlimited
Hide Signatures
(in reply to BHolsten)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
