RE: BJCraft Episode    Gallery
Logged in as Guest
Users viewing this topic: ram_z, rcprecision, Warrior523, elan120
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: BJCraft Episode
Page: <<   < prev  6 7 8 [9] 10 11 12 13 14 15   next >   >>
Login
RE: BJCraft Episode - 11/4/2012 11:34 AM
serious power
Score: 100
Last Login: 5/23/2013
Status: offline
Hi Tony,
Sounds like it might be worth trying a cannalyser on the Nuance first.
Are the canopies interchangeable ?
Brian
Hide Signatures
(in reply to TonyF)
       Post #: 201
RE: BJCraft Episode - 11/4/2012 1:34 PM
mups53
Score: 105
Status: offline
quote:
ORIGINAL: serious power
Hi Tony,
Brian
 Brian I think they may be interchangable. The Nuance and the Prolog are. The basic fuse is the same on all 3 models. I have no idea what effect it would have. Mike
_____________________________
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
(in reply to serious power)
       Post #: 202
RE: BJCraft Episode - 11/4/2012 2:51 PM
TonyF
Score: 108
Status: offline
As Steve mentioned earlier, the wing location, stab location and the layout of the area of the rudder are different between the Nuance and the Episode. A canalyser on the Nuance might work, but I'd rather just try the Episode.
TonyF - Team Horizon, Team BJ Craft, Team Contra Drive, Neu Motors
2010,2009 US Masters Champion,2011 Masters Also-Ran
Hide Signatures
(in reply to mups53)
       Post #: 203
RE: BJCraft Episode - 11/4/2012 5:23 PM
rcpattern
Score: 100
Status: offline
The canopies do fit, however the Episode uses different attchment method, but they do fit on the fuse.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to TonyF)
       Post #: 204
RE: BJCraft Episode - 11/4/2012 5:25 PM
mups53
Score: 105
Status: offline
 Right Arch Chris said the attachmenet system on the Episode is like the Wind Pro and the Oxai's. They have the buttons. Mike
< Message edited by mups53 -- 11/5/2012 1:10 AM >
1 800 591 2875
Hide Signatures
(in reply to rcpattern)
       Post #: 205
RE: BJCraft Episode - 11/8/2012 5:14 PM
mups53
Score: 105
Status: offline
Mini version
Click to see fullsize image.
Click for fullsize
1 800 591 2875
Hide Signatures
       Post #: 206
RE: BJCraft Episode - 11/8/2012 6:30 PM
rcpattern
Score: 100
Status: offline
Very nice. I want one of those.
Arch
Hide Signatures
       Post #: 207
RE: BJCraft Episode - 11/8/2012 7:13 PM
mups53
Score: 105
Status: offline
 I'm thinking they may be coming with the new planes. The first shipment is in Sidney Australlia today. Mike
1 800 591 2875
Hide Signatures
       Post #: 208
RE: BJCraft Episode - 11/8/2012 7:54 PM
EHFAI
Score: 100
Status: online
Mike
What route do these things take in their travel for mfg to F3AU?
Earl
Hide Signatures
       Post #: 209
RE: BJCraft Episode - 11/8/2012 8:25 PM
mups53
Score: 105
Status: offline
 Hey Earl. They travel south thru the Indian Ocean and come thru the Suez canal. Then west thru the Rock Of Gibraltor.  Ending up in New York and then into Baltimore. The ships make many stops along the way.  It takes about a month. I think there in pirate sea's for a little bit too. Mike
1 800 591 2875
Hide Signatures
(in reply to EHFAI)
       Post #: 210
RE: BJCraft Episode - 11/11/2012 2:05 AM
rcpattern
Score: 100
Status: offline
Thanks to Chris Moon, I was able to get some flights on the "Company Episode" before mine arrives next month. I put 2 on it yesterday and 6 on it today. I really like this plane. I still think the Nuance flies P a little better, but the Episode is incredible for F. Snaps are very quick and easy to stop. The rudder is as effective as most foamies I've flown. You can actually loop the plane tighter knife edge than you can upright. Great flying plane.
Arch
Click for fullsize
Hide Signatures
       Post #: 211
RE: BJCraft Episode - 11/11/2012 12:56 PM
BHolsten
Score: 100
Status: offline
I'm jealous,.....LOL
bholsten
Hide Signatures
       Post #: 212
RE: BJCraft Episode - 11/11/2012 6:05 PM
f3a05
Score: 100
Status: offline
quote:
ORIGINAL: shannah
quote:
ORIGINAL: f3a05
My canalyzer is set at 0.3 degrees negative ( i.e.trailing edge raised) relative to the wing.
The wing incidence, measured on the ''non-aileron'' part,near the aileron root, is itself set (by the factory settings on my example), at 0.8 degrees positive relative to the tail.
You might want to recheck your incidences again. I found it pretty difficult to get an accurate measurement on the wing at the non-aileron section. That section is swept fairly deep and it was hard to keep the incidence meter on the wing properly.
I checked with B.J. on this topic and he says that the wing and canalizer factory setting is +1.5 relative to the horizontal stabilizer. Set the horizontal stab at zero trim and verify its center with the neutral elevator jig template (be careful because there is a bit of play in that, not much but a bit). Then measure the wing incidence relative to the stab. The wing should be +1.5 positive in relationship to the horizontal stab. The canalizer is not adjustable but is set to match the wing incidence at the factory setting. Make sure that your canalizer is fitting flush in the mount and that the TE is not raised.
This +1.5 wing incidence is a starting point for the airframe. Adjustment may be necessary depending upon final CG setting and preference. Moving the CG may require adjustment to the wing incidence to restore elevator trim to zero.
If you are indeed at +0.8, this might explain why you had some pitching on knife edge. Try bumping up the incidence and see. I think I am at +1.3 so I'll dial in a bit more on mine.
Hope this helps. I'll update as I get more info on mine and verify where I am at. I think it's probably a good idea to install adjusters on this one, especially if you move the CG around.
Rechecked the wing incidence relative to the tail, and yes, still 0.8 positive.
So, returned the elevator to 0 relative to the stab using the supplied jig, used the wing incidence adjusters to eliminate the (right) aileron trim, then set the wing to 1.5 positive.
Set the c of g at 270 mm from the back of the canopy floor, and voila ! no k/e mix, to pitch or roll, vertical uplines fine ;no pitch or yaw.
Power-off vertical downs still need a fair bit of the usual throttle to elevator mix, more than I'm used to at 5% on a JR Tx, but flyable.
Needs more fine tuning, but all-in -all the c of g at 260-270,and the decalage at 1.5, definitely suits the model.
Many thanks for the advice!
Hide Signatures
(in reply to shannah)
       Post #: 213
RE: BJCraft Episode - 11/11/2012 7:17 PM
serious power
Score: 100
Status: offline
Hi,
Have you reset the cannaliser or is it now at -1.0
Brian
Hide Signatures
(in reply to f3a05)
       Post #: 214
RE: BJCraft Episode - 11/11/2012 9:02 PM
f3a05
Score: 100
Status: offline
Hi,
Brian
It is at -1.0 relative to the wing, thus + 0.5 to the tail.
Photos just now, meter left on between shots:
Tail:
[URL=http://imageshack.us/photo/my-images/267/img1925be.jpg/] [/URL]
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
Wing:[URL=http://imageshack.us/photo/my-images/222/img1927y.jpg/] [/URL]
Canaliser:
[URL=http://imageshack.us/photo/my-images/39/img1931lg.jpg/] [/URL]
Hide Signatures
       Post #: 215
RE: BJCraft Episode - 11/23/2012 2:47 AM
shannah
Score: 105
Last Login: 5/22/2013
Status: offline
I finally got a chance to go put in a few more flights yesterday. I am still fine tuning the incidence, thrust, and subtle mixing. I'm liking the way it flies. I LOVE the snaps. It really does the opposite snaps in F13 nicely. I'll fly again this weekend again and do some more trimming. I had a bit of a pull to canopy on upline so I put another shim for down thrust and we'll test that next time out. I found that my elevator throws weren't quite aligned so I tweaked that setup a bit as well. My canalizer and wing are pretty close, my latest measurement shows that my wing is +0.2 relative to the canalizer.
I started setting up my new DTFS wings on the Nuance so I'll be interested in seeing how it compares to the original wings and the Episode. My thoughts from yesterday were that the Nuance has a slight edge for P13, but we'll see how that holds up as I get the Episode dialed in.
Team BJCraft
Hide Signatures
(in reply to f3a05)
       Post #: 216
RE: BJCraft Episode - 11/23/2012 3:05 PM
pippy
Score: 100
Status: offline
Hi shannah, I would be very interested to know how the DTFS wings operate on the Nuance as I may purchase a set. Post ASAP please
Paul Houlihan
Hide Signatures
       Post #: 217
RE: BJCraft Episode - 11/24/2012 2:02 AM
shannah
Score: 105
Status: offline
Hello Paul,
I will try and get those wings installed and tested shortly. I saw a set fly on Kris Fitzsimmons' Nuance at our District 7 meet recently. It looked very good in the air. I'm anxious for some side by side comparison on mine. I have a round of travel coming up for work so hopefully I can give it a shot next week, otherwise it will be later in December.
FWIW, on the topic of the Episode, I was able to do some real sequence practice with the Episode today. It flies really well. I still need to get used to the rudder as it is sensitive, but I am getting that dialed in. It feels very solid in the air overall.
Steve
Team BJCraft
Hide Signatures
(in reply to pippy)
       Post #: 218
RE: BJCraft Episode - 12/3/2012 12:19 AM
shannah
Score: 105
Status: offline
Hi Paul,
Sorry, I got the wings fitted to the Nuance but it has been raining for the past couple days. I'll post on the Nuance thread when I get a chance to fly it. Probably won't be for a couple weeks due to work commitments.
Team BJCraft
Hide Signatures
       Post #: 219
RE: BJCraft Episode - 12/3/2012 1:03 AM
F3A Unlimited
Score: 123
Status: offline
The ship with the Episode ARFs arrived today in port, once they clear Customs and are delivered to us we will get them back out to everyone who ordered one. That should occur within a week barring any Customs delays.
F3A Unlimited
Hide Signatures
       Post #: 220
RE: BJCraft Episode - 12/12/2012 11:46 AM
shannah
Score: 105
Status: offline
I thought I would post this link to a good cheap 70mm CF spinner. There aren't a lot of good 70mm spinners to choose from out there. I cut my own cooling holes (I'll post a pic when I get home). It's fairly light and looks good. A bit on the pointy side, but for the price ($25) it's great.
http://sdshobbyusa.net/index.php?main_page=product_info&cPath=33_360_226&products_id=3103
Team BJCraft
Hide Signatures
(in reply to F3A Unlimited)
       Post #: 221
RE: BJCraft Episode - 12/23/2012 7:30 PM
shannah
Score: 105
Status: offline
I got a chance to squeeze in a couple flights yesterday. I was trying a 20x13 prop per BJ's suggestion. He recommends a 20" pitch because he says that the smaller diameter is more compatible with the canalizer. I thought it was a bit less yaw sensitive and rolled more axially (although it was pretty nice on the 21x14). It was faster overall, but not too bad.
I am just about ready to fix the rear anti rotation pins in place since I think my incidence is OK. I made a very slight thrust adjustment that I want to test before I do that however.
I still think this is a real solid flying airframe. It takes more work to fly it as smooth in P13 as the Nuance but it clearly excels in the more difficult FAI maneuvers. I hope to get out and do some more serious sequence flying over the next few weeks. I'll post my updates and progress.
Team BJCraft
Hide Signatures
       Post #: 222
RE: BJCraft Episode - 12/24/2012 6:59 AM
ram_z
Score: 100
Status: online
Hi Steve,
Thanks for the info.
Since I will set up my Episode with contra drive, I wonder which prop and gear ratio I sould start with...
Any ideas?
Hide Signatures
       Post #: 223
RE: BJCraft Episode - 12/24/2012 6:55 PM
shannah
Score: 105
Status: offline
I am not sure which prop and gear set would be best. Perhaps Tony F. can chime in on this. He's flown mine and has some thoughts as to the contra drive application on the Episode. Tony?
Team BJCraft
Hide Signatures
(in reply to ram_z)
       Post #: 224
RE: BJCraft Episode - 12/24/2012 8:22 PM
TonyF
Score: 108
Status: offline
I would start with the 10.16 ratio gears and a 22x20 on the front cut to 21.5 length. On the rear I would use a 22x22 cut to 21 length. I've run that a lot on the Nuance and it seems a good way to go. I doubt if the Episode wants to be flown any faster then the Nuance. It might even want to be flown a little slower. If so you can run the same props with either the 10.33 ratio or the 10.56.
I'm supposed to be getting an Episode soon so I'll know more after I get a chance to fly it with the Contra.
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
