RE: Nuance    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Nuance
Page: <<   < prev  15 16 17 18 19 20 21 22 [23] 24   next >   >>
Login
RE: Nuance - 1/16/2013 6:14 PM
patternflyer1
Score: 100
Last Login: 5/15/2013
Status: offline
I would guess less drag with the 90 degree. The more drag you induce in the tail, I would guess it would appear to stabilize the tail more.. I don't think I am a fan of inducing drag if we don't have to just to help with stability.
_____________________________
Team BJ Craft Team F3A Unlimited
Team Airtronics
Hide Signatures
(in reply to wildwillie3)
       Post #: 551
RE: Nuance - 1/16/2013 6:30 PM
F3A Unlimited
Score: 123
Last Login: 5/18/2013
Status: offline
BJ says the 95 degree will make the rudder less sensitive around neutral. I have not tried the fences yet so can't say how they feel between the 2 options.
F3A Unlimited
Hide Signatures
(in reply to patternflyer1)
       Post #: 552
RE: Nuance - 1/16/2013 6:31 PM
mups53
Score: 105
Status: offline
95 degrees provides more drag and increases the yaw stability.
 I've been told it has some adverse effects which I'm not familiar with.
 Dave Snow and Lockhart are the masters of trying devices on their planes to fix things. I'm not an expert.
 I've had the fences on 2 planes one was the Spark Dynamic the other a Mysteliptical. I have and had them at 90 degrees or parallel with the centerline of the top of the fuse.
 I found them to improve the stability of the plane in the yaw stability and tracking.
 Mike
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
       Post #: 553
RE: Nuance - 1/16/2013 7:31 PM
rcpattern
Score: 100
Status: offline
Having played with the fences at various angles, I felt that there is minimal difference between 90 and 95. I wont say there is zero difference, but there is minimal difference I could feel with identical fences. I could tell a difference in making fences larger at each angle, but it was very difficult to see a major difference between the same fences at varying angles. Now, to preface that, I was unable to test them on back to back flights on the same day as I had to go home and change them, but that is just my personal findings on the Nuance with stab fences. They do obviously work, as there is a significant difference with them on, and with them off.
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to mups53)
       Post #: 554
RE: Nuance - 1/16/2013 8:30 PM
rgreen24
Score: 100
Status: offline
once the best way to install them, double sided tape?
Hide Signatures
(in reply to rcpattern)
       Post #: 555
RE: Nuance - 1/16/2013 9:18 PM
rcpattern
Score: 100
Status: offline
I used silicon rubber glue. Easy to put on. Easy to take off.
Hide Signatures
(in reply to rgreen24)
       Post #: 556
RE: Nuance - 1/17/2013 1:34 AM
nonstoprc
Score: 110
Status: offline
I use two pieces of white masking tape, cut to the width of the fence plus extra 1/16" on either side. Put the tape on stab, top and bottom, then glue the fence onto the tape.
Arch,
Many thanks for showing the usefulness of the stab fences on FB. I tried it and like it a lot!
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
       Post #: 557
RE: Nuance - 1/17/2013 1:35 AM
rgreen24
Score: 100
Status: offline
Thanks Arch
Hide Signatures
       Post #: 558
RE: Nuance - 1/19/2013 4:17 AM
TonyF
Score: 108
Last Login: 5/17/2013
Status: offline
I've been flying the DTFS wings on my Nuance now for a while, so I thought I'd share my results.
After flying the wings for a while and trying all the stuff that was mentioned before like moving the CG forward and changing the expo settings, I was still not entirely happy with how the model was flying. I got out on a calm day and really started looking at how the model was tracking, particularly in yaw. With the stock wings I had added stab fences and that helped. But with the DTFS wings it seemed like there was not enough yaw stability. I don't know why, but after carefully watching what the model was doing, it seemed like it was OK in outside maneuvers but seemed to wander a bit in inside maneuvers. So I added additional fences, but just on the bottom of the stab. My reasoning is that fences below the stab are more effective in insides then in outsides.
I've flown them enough now to decide that they have improved the model. The DTFS wings are better in snaps and in spins. Also, it seems like I can do the rolling circles and loops along with the knife edge loops better with these wings. I don't know why, it just seems that way. Another benefit is that these wings have less drag so the speed is higher and I'm using about 300mAh less per pattern.
I still have it in the back of my head that many models these days are lacking in yaw stability. I think that we need to start looking at larger fins and distributing the fin area lower in the model. But stab fences do a very good job of adding that area without unnecessary drag.
Keep in mind I'm flying the Contra drive so a single prop may be different. But I still feel even with a single prop the fences will help and cannot hurt.
Here are a few pics of the fences on my model.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
TonyF - Team Horizon, Team BJ Craft, Team Contra Drive, Neu Motors
2010,2009 US Masters Champion,2011 Masters Also-Ran
Hide Signatures
       Post #: 559
RE: Nuance - 1/19/2013 5:27 AM
patternflyer1
Score: 100
Status: offline
Good info Tony. I was going to do 2 per side to test. I thought maybe 4 would be more effective. And I could always remove 2. Of course, flying a single prop.. But I did just get a Neu, so who knows. Maybe some day I will win the lottery and have 2 props. Haha..
Appreciate the info and pics.. See ya at your contest. Even though I don't have a classic plane.
C
Team Airtronics
Hide Signatures
(in reply to TonyF)
       Post #: 560
RE: Nuance - 1/20/2013 11:53 AM
cartercg
Score: 100
Last Login: 5/16/2013
Status: offline
Hi Tony and others,
The effect of the stab fences is very interesting. I've been flying my Citrin bipe for a while, and while it is a pleasure to fly, I find it does not have the directional stability of some of the mono planes I have flown, like the peridot and valiant. Moving the cg forward has not had a major impact. I find the plane can loose heading more easily, especially during loops, and in particular outside loops. The stab on the citrin is positioned fairly low. I wonder if the lower wing is blanking the stab when doing outside loops. I don't want to highjack this thread, but do you think that stab fences could improve this, and are worth a try? I am running a standard single prop setup.
Regards
Clint
Hide Signatures
       Post #: 561
RE: Nuance - 1/21/2013 12:45 AM
TonyF
Score: 108
Status: offline
Clint,
It would be my guess that stab fences would help your problem. It sounds like you're having a yaw stability issue and fences would help that issue. At the least they can't hurt.
I've gotten more flying in with my Nuance and I'm getting quite happy with how it's flying. It is much better in the reversing spins now and the snaps are definitely better. I'm still playing with throws and expos to get it better. BTW, my CG with the canopy off is maybe 1/8" in front of the tube center. I'm going to need the less swept LG legs as it is now a little tippy on the gear. Now if I can just get better at F-13 I'll be good to go! It take a month off of flying it and I get rusty quick!
Hide Signatures
(in reply to cartercg)
       Post #: 562
RE: Nuance - 1/21/2013 3:17 AM
shannah
Score: 105
Status: offline
My experience has been pretty similar to Tony's but I use the standard drive on mine. My issue with the yaw stability is a bit different. I noticed that it consistently wanted to yaw to the right when pulling out of a downline but never yawed to the left. I also had the same observation as Tony that it didn't seem to have this yaw when pushing out of a downline. Part of this issue may be thrust related (maybe I need more right thrust so that the rudder isn't taking over on the power off downlines), but it is still a bit odd that it does it on pulls and not on pushes. The yaw is pretty predictable and is the only odd thing I've noticed. I deal with it by using rudder as necessary, but I think I'll try the fences on the bottom of the stab.
Team BJCraft
Hide Signatures
(in reply to TonyF)
       Post #: 563
RE: Nuance - 1/21/2013 6:31 AM
cartercg
Score: 100
Status: offline
Hi guys,
Thanks for the feedback. My bipe is trimmed hands off for up and down lines, and in calm conditions it holds its line very well once on an up line. I'm not totally sure what is meant by "yaw stability", but what I experience is that in a cross wind if I pull or push onto a vertical up line the plane will yaw into the wind (as it should, but I will naturally need to help set the correct angle of yaw), but it will not hold that yaw angle if I leave the rudder input. If tends to over correct I.e. will yaw into the wind more than is required. The more it yaws the worse it gets. This means I need to put in a little opposite rudder to hold a straight vertical up line. It is pronounced on the up lines but I am sure is also occurring on 45s and level flight, but not too the same extent. Also the planes flies at a higher angle of yaw in cross winds (to hold the line) as compared to my previous models. From the threads on the topic it seems that "yaw stability" is also associated with the plane skidding, which I understanding would result in needing a higher angle of yaw to hold the line. It is especially noticeable when the plane gets slower, such as during landing. It may be that these characteristics are naturally associated with a bipe, but I wonder if stab fences will help. I'm going to make some up and temporarily install them to see what effect they have. Any recommendations on where on the stab they should be installed? I see the nuance fences sold by f3a unlimited are installed near the tips of the stab. But Tony has installed them near the mid point of the stab. I'm running a single prop setup, and am going to try installing them near the midpoint of the stab....unless you have any alternative suggestions. Thanks for the help.
Regards
Clint
Hide Signatures
(in reply to shannah)
       Post #: 564
RE: Nuance - 1/21/2013 8:24 AM
patternflyer1
Score: 100
Status: offline
Perhaps moving your cg forward would help also. I have seen that type of yaw when I flew more tail heavy Clint.
As for stab fence positioning, mine are going on at just over mid stab. I took the stabs off, traced them with pencil onto a piece of graph paper, drew what i wanted for the outside of the fence, then sized it down on my printer to 85 percent. I tried 70 all the way to 90 in 5 percent increments but settled on 85. I could scan it in and post it but I think my stabs are Episode stabs so they might not be the same.
Steve,
Most electric (outrunner) planes that I have had needed the left rudder to low throttle mix for down lines at first until I added more right thrust. I think tony and well, myself are talking about yaw in our pull or push on a downline. Most noticable with the new wing. More noticable in a pull than push. I feel the difference when doing a push is because there is more vertical stab under the plane than when upright. So I think tony is on to something with his second set of lower stab fences. I made mine today and made only one set, but I made the lower one much larger. Still have to mount them, but they are covered and ready to install. I almost want to wait until I have the Neu installed so I can see the difference from the Pletty.
Chris
Team Airtronics
Hide Signatures
       Post #: 565
RE: Nuance - 2/6/2013 1:21 PM
wagen017
Score: 100
Last Login: 5/8/2013
Status: offline
I could buy a Nuance unbuild and was wondering if there is any difference with those that currently ship from the factory.
Volkert
Club Saito member #371
Hide Signatures
       Post #: 566
RE: Nuance - 2/6/2013 1:24 PM
ram_z
Score: 100
Status: offline
I think that the only different is the new landing gear which is less swap...
Hide Signatures
(in reply to wagen017)
       Post #: 567
RE: Nuance - 2/10/2013 9:41 PM
wagen017
Score: 100
Status: offline
Thanks, good to know.
Volkert
Hide Signatures
(in reply to ram_z)
       Post #: 568
RE: Nuance - 2/22/2013 8:51 PM
OhD
Score: 100
Status: offline
Does anyone know what the built in right thrust is (in degrees) on the Nuance? I'll probably use a Contra and will need to take out the right thrust. I assume the down thrust should stay the same?
Jim O
Hide Signatures
       Post #: 569
RE: Nuance - 2/22/2013 8:56 PM
danamania
Score: 105
Status: offline
quote:
ORIGINAL: OhD
Jim O
The "Nuance 170 technical data" table in the designer's report lists "Thrust: R 2.5-3 degree / Up 0-1 degree."
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to OhD)
       Post #: 570
RE: Nuance - 2/22/2013 10:01 PM
OhD
Score: 100
Status: offline
Thanks, I missed that.
Jim
Hide Signatures
(in reply to danamania)
       Post #: 571
RE: Nuance - 2/24/2013 11:30 PM
shannah
Score: 105
Status: offline
Hi Jim,
If you don't already have a the Nuance, you can get it pre configured for a contra from the factory.
Team BJCraft
Hide Signatures
(in reply to OhD)
       Post #: 572
RE: Nuance - 3/21/2013 3:22 AM
underdw
Score: 100
Status: offline
Does anybody have any scraps of the Nuance Pink and Aqua covering material that they would be willing to mail to me? Only need a 2x12" strip of each.
(I borrowed a set of DTFS wings from a friend and some of the trim peeled off in flight. Would like to fix it before I return them PM me please.
Thanks, Dan
Hide Signatures
       Post #: 573
RE: Nuance - 4/11/2013 6:18 AM
Andy P.
Score: 110
Status: offline
I just got my Nuance finished, a fantastic flying airplane.
Im running the E Start C50 14XL motor on a PT 21 x 14E and the power is unbelievable. Im pretty settled on a 245mm CG from the canopy rear, the airplane feels very locked in yet extremely light to fly at this setting.
Many thanks to Chris at www.bondaero.co.uk for getting these in to Europe!
Regards,
Andy.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Andy P. -- 4/11/2013 8:34 AM >
When life hands you lemons, make lemonade!
Hide Signatures
       Post #: 574
RE: Nuance - 4/11/2013 9:42 PM
BHolsten
Score: 100
Status: offline
Here is my Nuance via Archie stafford,..Thanks' Archie.
Thank's to F3A Unlimited for having all the things I needed to complete my plane, great support. To BJ Craft for a great plane, even though it's not new, it's new to me..
I tried to post pic's but the site times out and fails to load,...I added some light blue and yellow, later on I will remove the pink and add Orange, yellow and blue in place of the pink.
Here is the list:
Futaba 14 MZ
R5014-G3 RX (R6008 FASST issues)
Elevator: Futaba 9650 mini (2)
Ailerons: Futaba 9350 (2)
Rudder: Savox SC- 1232-SG (1)
Castle Pheonix 80 HV (F3A Unlimited)
Hacker Q-80-14XS (F3A Unlimited)
Q80 nose mount kit (F3A Unlimited)
APC 21x14 (PT 21x14 L) (F3A Unlimited)
True Turn Turbo cool "blue" 2.75 FAI (F3A Unlimited)
Tech Aero dual regulators w/ switch (F3A Unlimited)
F3A Unlimited 900mah Rx lipo (F3A Unlimited)
Seacraft servo arms (F3A Unlimited)
Seacraft ball links (F3A Unlimited)
Weight with Zippy compact 25C-5000 (Hobby King USA) ready to fly.
4883grams w/ a PT 21x14EL
4935grams w/ a APC 21x14
Since this plane has over or near 300 flights, I found some maintenance things to watch out for, nothing major.
The tabs on the stabs, two were de-laminating from the root rib (right side) where the screw goes though. I made doublers like I did on my 39% Radiowave several years back.
Make sure the formers are still glued to the fuse good ( one was seperated). Had a few areas where the fiberglass was separating from the balsa on the inside near the phenolic tube area, thin CA and a baggie, rub it back in. That was it....... These planes are built light and we fly them hard in all sorts of conditions, so remember to look over the plane, even take the stabs off and check them once in a while.I also, tightened up the tube by using clear Mono-Kote cut in 1/4 strips and spirial wrapped it like a cand cane stripe, heated it with the iron. Worked great, usually I would use thin CA and sand to fit.
I added a 1/8 strip under the entire area the canopy sits on, as the balsa sides do not go all the way up and the top corners were buckling, easy fix. I will post pic's when the system lets me..
****NOTE TEAM FUTABA ON THE WINGS WILL SAY "GO TEAM FUTABA" for now it's staying,..maybe one day.*****
bholsten
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BHolsten -- 4/13/2013 2:59 PM >
Hide Signatures
(in reply to Andy P.)
       Post #: 575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
