RE: Nuance    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Nuance
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: Nuance - 7/17/2012 11:18 AM
mups53
Score: 105
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: danamania
Sooo... How many Nuances going to the Nats?
Hmm good question.
_____________________________
F3AUnlimited Customer Service
1 800 591 2875
Hide Signatures
(in reply to danamania)
       Post #: 351
RE: Nuance - 7/17/2012 11:47 AM
rcpattern
Score: 100
Last Login: 5/19/2013
Status: offline
Well, I am taking two....
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to mups53)
       Post #: 352
RE: Nuance - 7/17/2012 1:46 PM
jayjayneri
Score: 103
Last Login: 5/4/2013
Status: offline
quote:
ORIGINAL: TonyF
Chip is such a hoot! Don't remember saying anything against him in my post and it's kind of hard to understand why he took some shots at me.
jayjayneri, since you wanted info to try to eliminate the throttle to rudder mix, I hope my info helped. I tried the throttle to rudder mix a while back with Chip's insistence, but I found for me it caused other problems and could be eliminated with careful adjustment of the side thrust/rudder trim. I think it's one of those things that in theory sounds good but in practice it's not needed. At least that's how I saw it but YMMV. Chip seems to feel it's needed but it just didn't seem that way for me.
I also noted your need for a throttle to aileron mix. What motor are you using and are you using any braking in the downlines? Also, are your ailerons centered at level trim? A lot of the Nuances I have seen and heard about the stock incidence settings require some aileron trim. I think you really need to get any roll trim out by adjusting the wing incidences. I installed adjusters in mine and I started with the incidences as originally built in to the model. The 1st few flights needed roll trim but I adjusted it out. That may be the source of your roll on downlines.
Now I guess I'll get to see what I said now that Chip didn't like!
Hi Tony, I did install wing adjusters in my Nuance and I will double check to see if my ailerons are centered. I am playing around with my side thrust and rudder trim. I do believe I have reduced or even eliminated my need for throttle to rudder mix. I can't be totally sure until I get a day with little or no wind. I am glad you and Arch were able to get rid of your downline rolls. That means I should be able to get rid of mine too by playing with the wing adjusters. I do agree with Chip that there is nothing wrong with using mixing when necessary but the less mixing you have the better. So I will continue to work hard to trim my Nuance. I am still not sure whether I will use the Nuance or Toxiris for the Asian Championships in September. Thanks again.
Hide Signatures
(in reply to TonyF)
       Post #: 353
RE: Nuance - 7/17/2012 1:48 PM
jayjayneri
Score: 103
Status: offline
Good luck to all in the Nats. Wish I were there to watch. One of these years, I will just show up in Muncie.....
Hide Signatures
(in reply to jayjayneri)
       Post #: 354
RE: Nuance - 7/17/2012 2:24 PM
danamania
Score: 105
Status: online
quote:
ORIGINAL: jayjayneri
...I did install wing adjusters in my Nuance and I will double check to see if my ailerons are centered. I am playing around with my side thrust and rudder trim. I do believe I have reduced or even eliminated my need for throttle to rudder mix. I can't be totally sure until I get a day with little or no wind. I am glad you and Arch were able to get rid of your downline rolls. That means I should be able to get rid of mine too by playing with the wing adjusters...
FWIW, I have no down line rolling with the wings simply corrected with aileron trim (1 mm offsets). Up lines are vertical as long as I apply the usual amount of right rudder with throttle at the pull to correct for P-factor, which can then be relaxed as the up line is established. I attribute this to a more-or-less correct thrust line. (The rudder is neutral.) Agreed that adjusting wing incidence is the correct way to dial out the aileron trim, but my Nuance flies so well right now that it does not seem worth it to convert the stock anti-rotation pins to an adjuster set-up. I may change my mind about this over time, but with 2 dozen flights over 3 weeks, I am already using it to learn the intermediate maneuvers since it is in good trim and eminently fly-able. Hope yours turns out well for you too. I could not be happier with my purchase for the kind of flying I need to do now to progress to the next level. Cheers!
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 355
RE: Nuance - 7/17/2012 10:47 PM
patternflyer1
Score: 100
Last Login: 5/15/2013
Status: offline
I need to borrow some glue if mine is to make it to the nats.. Anyone have a few gallons to spare?
Guess I'm glad I didn't have the money to make the trip to the nats this year.
Went down in the tomato field while they were watering.. All the electronics somehow ended up a foot down in the water.. Imagine that.
Sometimes life kicks ya when you are down. Today is definitely one of those days.
Chris
Click to see fullsize image.
Click for fullsize
Team BJ Craft Team F3A Unlimited
Team Airtronics
Hide Signatures
       Post #: 356
RE: Nuance - 7/17/2012 11:37 PM
TonyF
Score: 108
Last Login: 5/17/2013
Status: offline
Really sorry Chris. What happened?
TonyF - Team Horizon, Team BJ Craft, Team Contra Drive, Neu Motors
2010,2009 US Masters Champion,2011 Masters Also-Ran
Hide Signatures
(in reply to patternflyer1)
       Post #: 357
RE: Nuance - 7/18/2012 12:55 AM
patternflyer1
Score: 100
Status: offline
Thx Tony.
Still looking into the cause.
C
Team Airtronics
Hide Signatures
(in reply to TonyF)
       Post #: 358
RE: Nuance - 7/18/2012 12:58 AM
Dave Harmon
Score: 101
Status: offline
quote:
ORIGINAL: patternflyer1
Chris
WOW....that was a bad un'....really sorry to see that Chris...hang in there.
Forget Mixing Your Own Fuel....It''s Easy But No Longer Needed!
Hide Signatures
       Post #: 359
RE: Nuance - 7/18/2012 1:03 AM
danamania
Score: 105
Status: online
So sorry to see your bird down! It really sucks when that happens. Definitely sucks!
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to Dave Harmon)
       Post #: 360
RE: Nuance - 7/18/2012 1:44 AM
jayjayneri
Score: 103
Status: offline
Sorry to see that Chris.....please update us on the cause after your investigation.
Hide Signatures
       Post #: 361
RE: Nuance - 7/18/2012 3:24 AM
woodie
Score: 100
Status: online
Chris, what a bummer!!! Sorry to hear about this.... Hang in there.
Woodie
"In theory there is no difference between theory and practice. In practice there is." Yogi Berra
Hide Signatures
       Post #: 362
RE: Nuance - 7/18/2012 3:38 AM
patternflyer1
Score: 100
Status: offline
It was not airframe related. Electronics related. This is a good airframe, well built. I will get another when I can afford one.
Thx,
Chris
Team Airtronics
Hide Signatures
       Post #: 363
RE: Nuance - 7/18/2012 10:18 AM
mups53
Score: 105
Status: offline
Gezzz Chris you could use a break. Bad news hang in there, Mike
1 800 591 2875
Hide Signatures
       Post #: 364
RE: Nuance - 7/18/2012 3:47 PM
Surefire
Score: 100
Last Login: 5/16/2013
Status: offline
Chris - Hang in there man! That is such a drag for so many reasons but one big one is that you were flying it so well. That plane really fit you well. Don't give up!
Jon Carter
NSRCA #2354
Hide Signatures
       Post #: 365
RE: Nuance - 7/18/2012 5:08 PM
mups53
Score: 105
Status: offline
 Just in case anyone is interested in one for sale I just listed mine.
http://www.rcuniverse.com/market/item.cfm?itemid=857871&electric=0
 Thanks, Mike
1 800 591 2875
Hide Signatures
(in reply to Surefire)
       Post #: 366
RE: Nuance - 7/19/2012 7:34 PM
patternflyer1
Score: 100
Status: offline
Thx guys.. No biggie.. It happens. I appreciate the offers of planes to borrow. Pattern flyers sure are kind people!
Chris
Team Airtronics
Hide Signatures
       Post #: 367
RE: Nuance - 7/20/2012 3:46 AM
underdw
Score: 100
Status: offline
Guys,
The CG numbers you're quoting (260, 270, etc) are with the canopy off or on?
Hide Signatures
       Post #: 368
RE: Nuance - 7/20/2012 4:56 AM
ematech
Score: 100
Last Login: 5/3/2013
Status: offline
Hi all, Mine was measured with the canopy off. Sorry Chris about your plane...... In response to a previous post I am attending the nats with my Nuance. I am about 6 hours away, will be in on Friday. Anyone know where to practice? I have been on a great pattern trip with Hemet CA as the kick off then Boise ID followed by Victoria BC, and then Memphis MI then on to northern Main for about a week of practice and finally to the nats. The trip ODO on the truck reads 8120 since leaving the end of may! I have flown the Nuance in all sorts of weather and have been happy with the performance, I can see differences in performance/rates and speed with altitude and baro changes.
John Bentley
Hide Signatures
(in reply to underdw)
       Post #: 369
RE: Nuance - 7/20/2012 5:21 AM
patternflyer1
Score: 100
Status: offline
Mine was canopy on.
I was trying a more rearward cg for the past, should I say it's last 2 days and I really didn't like it as much as I did when it was a bit more nose heavy. I added a touch of positive to the wings also and had straightened the wings out to get rid of the aileron trim. To me, it made a big difference. I had noticed it rolling out on down lines because of the trim it carried at mid throttle for normal flight.
John, good luck at the nats. Sounds like a very fun trip you are having! I love the nats. It's a great overall experience. More so than just the flying. Seeing everyone from different parts of the country, and seeing how they do things a bit different is a learning experience for me. I always try to watch the more "talented' flyers (of course the most talented are in D7 ) and take something away from their flights that I could see that would be an improvement to my flights.
Take it all in, enjoy it, and have fun!
Chris
Team Airtronics
Hide Signatures
       Post #: 370
RE: Nuance - 7/20/2012 11:00 AM
danamania
Score: 105
Status: online
quote:
ORIGINAL: underdw
Guys,
Canopy on, in fact, the whole thing up on a balance. 270 from wing TE. Good luck to all going to the Nats. Cheers!
Good Flying! Dana
4449NSRC AMA
Hide Signatures
       Post #: 371
RE: Nuance - 7/21/2012 4:12 AM
jarvis johnson
Score: 100
Status: offline
Hey John
Good Luck, you'll do just fine. You can try Madison County Flying site, it's about 30 min's away from Munice, Jerry Budd is there I think, so able you can hook up with him.
For Advanced, go to site 4, that is where you will be flying, it's sometime busy.
Good luck, an tell your wife I said hello
Jarvis
Hide Signatures
       Post #: 372
RE: Nuance - 7/21/2012 5:09 AM
ematech
Score: 100
Status: offline
Thanks Jarvis!!! Will tell Annie you said HI! Wish you were here. will head out to the Madison field in the AM
John
Hide Signatures
(in reply to jarvis johnson)
       Post #: 373
RE: Nuance - 7/27/2012 7:01 AM
danamania
Score: 105
Status: online
quote:
ORIGINAL: rcpattern
Arch
Congrats on the win Arch. Any new insights on the Nuance?
Good Flying! Dana
4449NSRC AMA
Hide Signatures
(in reply to rcpattern)
       Post #: 374
RE: Nuance - 7/27/2012 12:19 PM
rcpattern
Score: 100
Status: offline
Dana,
Very happy with the setup I am using. Even in Muncie winds it performed great. I am very happy the Masters guys kept our finals line moving so we didn't have to fly in the crap that rolled in later in the afternoon.
Arch
Hide Signatures
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.297RCU1
