RE: Nuance    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Nuance
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Nuance - 12/30/2011 3:00 AM
patternflyer1
Score: 100
Last Login: 5/20/2013
Status: offline
I think this fuse is thinner than the De Ja Vu.. Tall though. Not sure what's optimal for the Contra. I'm confused by it really. Why can't any plane just be straight, with the right sized control surfaces and take full advantage of it? Doesn't make sense to me. Seems like that should work to me, but I haven't flown one obviously..
Chris
_____________________________
Team BJ Craft Team F3A Unlimited
Team Airtronics
Hide Signatures
(in reply to RByrd)
       Post #: 76
RE: Nuance - 12/31/2011 6:37 PM
patternflyer1
Score: 100
Status: offline
Just a question about how they mounted the servo arm. Shouldn't the servo arm be mounted 90 degrees with the rod, not 90 degrees with the servo?
Thx
Chris
Click to see fullsize image.
Click for fullsize
Team Airtronics
Hide Signatures
(in reply to patternflyer1)
       Post #: 77
RE: Nuance - 12/31/2011 7:30 PM
vbortone
Score: 100
Last Login: 5/24/2013
Status: offline
You will get a lot of mechanical exponential differential using that set up (a lot more in one side that the other). In order to make both sides equal the servo horn has to be parallel to the control horn line (line from hinge line to pivot point).
Vicente "Vince" Bortone
Hide Signatures
       Post #: 78
RE: Nuance - 12/31/2011 8:04 PM
Jason Arnold
Score: 100
Status: online
Yes, it should be at 90 degrees. Looks like you'll need to lengthen the linkage and find a spline that gives you 90 degrees. I normally use a Hitec servo programmer to set the pulse width to 1.5ms (centre) and then keep turning the servo horn until I get a setting at 90 degrees. The star horns are better for this i.e. Futaba.
BTW, I also use titanium turnbuckles to allow fast adjustment without having to undo everything... They are also strong and ultra light.
Cheers,
Jason.
Hide Signatures
       Post #: 79
RE: Nuance - 12/31/2011 8:29 PM
serious power
Score: 100
Status: offline
Hi Jason,
What ones do you use and where do you get them.
Brian
Hide Signatures
(in reply to Jason Arnold)
       Post #: 80
RE: Nuance - 12/31/2011 8:40 PM
Jason Arnold
Score: 100
Status: online
Hi Brian,
I use either 3mm or 4-40 titanium turnbuckles with Dubro ball joints. Do a search on Tower Hobbies for titanium turnbuckles and heaps will turn up at all different lengths and sizes. You need to determine what length is required first.. :-) I used to race RC cars and titanium was the bees knees for weight reduction while maintaining strength and rigidity.
I like the blue Associated ones but also use the Lunsford brand.
Another tip, you can also buy aluminium nylock nuts from Tower..
Regards,
Jason.
Hide Signatures
(in reply to serious power)
       Post #: 81
RE: Nuance - 1/1/2012 9:32 AM
flatlandmike
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: patternflyer1
Thx
Chris
This was designed to achieve a certain amount of throw and differential. If you use a different length servo arm you wont have the proper throw and differential that this setup was designed for with out losing resolution and mechanical advantage. His pdf pamphlet thingy stated that when you use this size arm with this geometry you will get the desired throw and desired differential.
www.jerseymodeler.com
Special thanx to The Crew Mike B. Jim Z. Ed J. Jim S.
Hide Signatures
       Post #: 82
RE: Nuance - 1/1/2012 9:45 AM
patternflyer1
Score: 100
Status: offline
Not looking to change the length of my servo arms, just wondering as I always thought it was mechanically best to keep the arm and control rod 90 degrees to have the same throws both ways. If you did ailerons that way you would have problems.
Thanks for the replies. Was double checking myself as I glued all my ca hinges in tonight and will do the linkages and most of the rest of the things tomorrow. Well, if I feel ok. haha
Thanks!
Chris
Team Airtronics
Hide Signatures
(in reply to flatlandmike)
       Post #: 83
RE: Nuance - 1/1/2012 10:16 AM
flatlandmike
Score: 100
Status: offline
If your ailerons required differential it can be done this way instead of programming in the differential. You would just have a small bit of trial and error to get the push rod the right length for the amount of differential you require.
Hide Signatures
       Post #: 84
RE: Nuance - 1/1/2012 3:58 PM
wattsup
Score: 100
Last Login: 12/18/2012
Status: offline
Hi Chris, Just a question or two for you. Are you sure you want to use a "z-bend" on the servo end of your rudder pushrod? Was this recommended by the builder in his manual? I haven't used a "z-bend" in more than 20 years. One thing for sure, you can't trust them. Hopefully you did not use them on your elevator or aileron servos! Thought I would ask__Everette
Hide Signatures
       Post #: 85
RE: Nuance - 1/1/2012 10:26 PM
Ryan Smith
Score: 103
Status: offline
quote:
ORIGINAL: wattsup
Hi Chris, Just a question or two for you. Are you sure you want to use a ''z-bend'' on the servo end of your rudder pushrod? Was this recommended by the builder in his manual? I haven't used a ''z-bend'' in more than 20 years. One thing for sure, you can't trust them. Hopefully you did not use them on your elevator or aileron servos! Thought I would ask__Everette
Everette,
I presume that you mean they can not be trusted for pattern applications? I use them every day, but I would never use them on a pattern plane because there is too much slop in the system for their use. I don't see how they can fail, but I can see easily how they can be less precise.
Now a 90-degree bend with a keeper is something I would never use.
Hide Signatures
(in reply to wattsup)
       Post #: 86
RE: Nuance - 1/2/2012 10:38 AM
pippy
Score: 100
Status: offline
Ryan, if I was still flying with IC engines I would agree to not using Z bends but they should be fine with electric due to lack of vibration. Nothing wears down like it use to. If the hole in the servo horn is drilled to the right size then there is no slop at all. I will keep a close eye on them and see how they go over time. Worse case I can either replace the servo arms or go to ball raced clevices etc.
Paul Houlihan
Hide Signatures
(in reply to Ryan Smith)
       Post #: 87
RE: Nuance - 1/2/2012 1:28 PM
pippy
Score: 100
Status: offline
As promised pics of my Nuance with Contra Drive installed. The spinner is about 2mm over all round but I think that wont affect its flying characteristics at all.. I just have to installed receiver and its battery and then work out where to place main battery for CG of 260mm.
Click for fullsize
Click for fullsize
Paul Houlihan
Hide Signatures
(in reply to pippy)
       Post #: 88
RE: Nuance - 1/2/2012 5:25 PM
jarvis johnson
Score: 100
Status: online
Here are a few photo's, of my Vanquish 2 meter and Steve Hannah's Nuance that will be on display at the NSRCA booth at the AMA EXPO this up coming weekend, they were shot
after a day of flying, out at the Riverside flying site. Man the weather was great, light breeze an almost 83 degree's, that Souhtern California in the month of December for you.
For those that have not seen a Nuance up close, it's a very nice pattern ship. The fuse is very tall, and the control surfaces are very thick, I'll be picking up a all white one the ARC
version, the photos are a side by side shoot,to show the size.
Vanquish
Canopy Height - 12'' tall or 320 mm
Aileron TE Thickness -3/16'' or 4mm
Elevator TE Thickness -3/16'' or 4mm
Rudder TE Thickness - 3/16'' or 4mm
Nuance
Canopy Height- 14'' or 360 mm
Aileron TE Thickness- 3/16 or 4mm
Elevator TE Thickness - 5/16'' or 10mm
Rudder TE Thickness - 5/8'' or 18mm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to pippy)
       Post #: 89
RE: Nuance - 1/3/2012 12:00 AM
shannah
Score: 105
Status: offline
Thanks for the pics Jarvis. You just don't get the same appreciation for the size difference from the pictures. The Nuance dwarfs the Vanquish in fuse height and volume, it is one tall fuselage for sure.
Team BJCraft
Hide Signatures
(in reply to jarvis johnson)
       Post #: 90
RE: Nuance - 1/4/2012 4:46 PM
papaone
Score: 100
Status: offline
Hello
See on BJcraft site :
Nuance's DTFSW (Double Taper Fast Snap Wing) This is Option Item.....
http://rcone.kr/board/index.html?id=bjair1&no=74
Click for fullsize
Hide Signatures
(in reply to shannah)
       Post #: 91
RE: Nuance - 1/4/2012 6:47 PM
woodie
Score: 100
Status: offline
deleted
Woodie
< Message edited by woodie -- 1/4/2012 7:08 PM >
"In theory there is no difference between theory and practice. In practice there is." Yogi Berra
Hide Signatures
(in reply to papaone)
       Post #: 92
RE: Nuance - 1/4/2012 8:41 PM
serious power
Score: 100
Status: offline
Hi,
Looks like 3 tapers to me.
Brian
Hide Signatures
(in reply to woodie)
       Post #: 93
RE: Nuance - 1/4/2012 9:09 PM
wagen017
Score: 100
Status: offline
3 ugly tapers if you ask me!
Volkert
Club Saito member #371
Hide Signatures
       Post #: 94
RE: Nuance - 1/4/2012 11:41 PM
Doug Cronkhite
Score: 105
Last Login: 5/22/2013
Status: offline
I kinda like it!
Doug Cronkhite
Hide Signatures
(in reply to wagen017)
       Post #: 95
RE: Nuance - 1/5/2012 6:39 AM
patternflyer1
Score: 100
Status: offline
I get a pretty violent snap without these wings.. I kinda think many of these fast snaps aren't really snaps anyhow, but to each their own I guess. So now that I have my Nuance almost complete, your telling me it doesn't snap fast enough? lol
Chris
Team Airtronics
Hide Signatures
       Post #: 96
RE: Nuance - 1/5/2012 11:43 AM
shannah
Score: 105
Status: offline
It snaps pretty darn well. But when you've gotten used to the whiplash inducing snaps of a Visa this seems like it is in slow motion. I am happy with it, but just a tad faster would be better. I think it does the opposite knife edge snaps better than my contra visa. But a single, horizontal snap isn't as impressive. However, since we don't have any knowns with just plain horizontal snaps, I guess it's kind of a moot point.
Get it done and fly it. You'll be happy.
Team BJCraft
Hide Signatures
       Post #: 97
RE: Nuance - 1/8/2012 4:15 PM
Zi-Chun Lin
Score: 100
Last Login: 5/13/2013
Status: offline
I just test my Nuance this weekend,Has about 10 flights on it!!
I love this plane so much,I decide that I will use this for Asia Cup 2012.....(in original I buy Toxiris for Asia Cup)
I use SAVOX 1251 for Ail and rud, SAVOX 1350 for elevator
For the motor,
I am now testing the newest inruner motor HYK 50
It run as good as my other Hacker C-50 14XL
The total weight with out battery is 3.61kg.......
I did some modify on this plane,Cheak the pic Hope you enjoy!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 98
RE: Nuance - 1/8/2012 4:31 PM
nonstoprc
Score: 110
Status: offline
Thanks for posting these pictures. may I ask the thick-ness of the PCB material(?) for motor mount?
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
(in reply to Zi-Chun Lin)
       Post #: 99
RE: Nuance - 1/8/2012 4:56 PM
Zi-Chun Lin
Score: 100
Status: offline
I think it is fiberglass plate!Not exactly sure what it's,Mu friend give it to me.
Hide Signatures
(in reply to nonstoprc)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.906RCU1
