RE: Yellow F22 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Yellow F22 Build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Yellow F22 Build - 11/24/2011 4:16 AM
bigbri
Score: 102
Last Login: 5/22/2013
Status: online
Ok John your killing me with that neat tidy install ! I am NEVER gonna take the canopy off mine when you are around! I really Love flying my yellow f-22. you are gonna have a great plane when you are done!
Later
Brian : )
Hide Signatures
(in reply to Square Nozzle)
       Post #: 26
RE: Yellow F22 Build - 11/24/2011 9:14 AM
Ian R
Score: 100
Last Login: 5/21/2013
Status: offline
gunnradd
Further to my last email re thrust vectoring install
Not sure what the latest  instructions say about the servos for the thrust vectoring, but if you can install them on the lower side of formers near the  floor of the model and then linked to the bottom of the vector units. mine are on the top each side of  the thrust tube and hence why it is a pain to install, can be done but better and easier on the bottom
hope this helps
Ian
Hide Signatures
(in reply to bigbri)
       Post #: 27
RE: Yellow F22 Build - 11/24/2011 9:56 AM
Pat Barnes
Score: 100
Status: offline
I have the Christian Diffusion F22 - great flying model! You'll love it! The speed envelope is fantastic - with 15kts or so, my jet will hover with about 20 alpha, and with the tap open it gets moving very nicely! One thing that I noticed about most model Raptors is that the pilots are too large! The Raptor is a huge aircraft - worth putting a smaller scale bust in the cockpit to get the look right! Enjoy the build and the flying.
Cheers - Pat
Hide Signatures
(in reply to Ian R)
       Post #: 28
RE: Yellow F22 Build - 11/24/2011 12:23 PM
gunradd
Score: 120
Status: online
Jon thanks for the pics! I know the plane is stealth but install pics have been stealth also lol.
Ian my thrust vectoring I got has the servo connections on the top. I didnt know that you could get them on the bottom. Yellow Aircraft is not making the thrust vectoring at this time and I was lucky to get what I got. Charles told me the guy that made them is not doing it anymore. So those of us that have it we are lucky!!!
I got the gear all painted white. And I am trying to run the engine today on the test bench.
_____________________________
Loving my Kingtech Turbine!
Hide Signatures
(in reply to Pat Barnes)
       Post #: 29
RE: Yellow F22 Build - 11/24/2011 6:20 PM
Ian R
Score: 100
Status: offline
Ok re vector servos at the top , It is just getting in there even with average size hands.
Once installed I have had no issues.
 I did build a little lite ply shield painted with a couple of coats of heat shield between the servos and the pipe just to reduce chance of  radiated heat.
As I said no problems in operation.
Pat B I do agree re pilot size I have "adjusted" mine since the photos I posted earlier
Ian
Hide Signatures
(in reply to gunradd)
       Post #: 30
RE: Yellow F22 Build - 11/24/2011 9:47 PM
YellowAircraft
Score: 181
Status: offline
Ian,
Thanks very much for the kind words. It's always a pleasure to serve you.
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
(in reply to Ian R)
       Post #: 31
RE: Yellow F22 Build - 11/24/2011 11:06 PM
FMRR
Score: 100
Status: offline
quote:
ORIGINAL: gunradd
Hmmm that would be a problem for a new builder.gunradd can you post some three view pics of what you have so we can try and reproduce it if need be.For those that cant can send the pic's to tam or trusted builder to fabricate.This way the entire thrust vector system would not have to be re engineered. I might even want to scale it down for my Fei bao kit. ....unless Shawn can give me a great deal on a new yellow kit. tomorrow is Black Friday !
< Message edited by FMRR -- 11/24/2011 11:31 PM >
Hide Signatures
       Post #: 32
RE: Yellow F22 Build - 11/25/2011 3:28 AM
Square Nozzle
Score: 105
Status: offline
Gunradd, there is an very good and extensive thread on the F-22 that I used while building my plane. Look for "Yellow F-22 CG hinges pics". Good reference for paint color codes, gear door reinforcing, equipment installation etc. I'd put the link on this note but I'm not sure how to do that. Just copy "Yellow F-22 CG hinges pics" and paste it into the search engine block.
John
Hide Signatures
(in reply to FMRR)
       Post #: 33
RE: Yellow F22 Build - 11/25/2011 12:16 PM
jkirkon
Score: 100
Status: offline
Here you go.
http://www.rcuniverse.com/forum/m_7087598/anchors_7087598/mpage_1/key_/anchor/tm.htm#7087598
Hide Signatures
       Post #: 34
RE: Yellow F22 Build - 11/25/2011 1:50 PM
Square Nozzle
Score: 105
Status: offline
Thanks jkirkon. That's the one. I also learned how to get that link based on your posting.
John
Hide Signatures
(in reply to jkirkon)
       Post #: 35
RE: Yellow F22 Build - 11/26/2011 9:55 PM
FMRR
Score: 100
Status: offline
jkirkon,Thanks for the link.clguru really put up a really nice build thread(nice work).There were some photos of the vector exhaust I found interesting.looks like a well design and assembled unit.What the story on that? was it after market piece that is no longer available....or can you get it from Shawn or Charles.I beleive gunnradd said he got the last one.And if you have one does it just bolt in..just curious.
Hide Signatures
       Post #: 36
RE: Yellow F22 Build - 11/26/2011 10:57 PM
gunradd
Score: 120
Status: online
It might be a temp problem at yellow. But charles said the guy that made the thrust vector kit is no longer with them. So at some point in time they will probably get them back. And yes its a very well made unit. Not sure how it attaches yet....... need the plane lol.
Update on the engine runs................... I have a bad ECU and a broken brush on the starter motor. So engine runs are set back a for a while.
Hide Signatures
(in reply to FMRR)
       Post #: 37
RE: Yellow F22 Build - 11/26/2011 11:32 PM
smchale
Score: 115
Status: online
Bummer Kris, hopefully that's not the reason you got a good deal on the turbine and the seller helps you get it running as expected.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
       Post #: 38
RE: Yellow F22 Build - 11/27/2011 5:03 AM
I-NAV
Score: 100
Last Login: 5/5/2013
Status: offline
The closest I've come to duplicating the F-22 paint is to mix the standard FS (dark and light grey) with silver. Use 5 parts silver to one part grey. It will look too bright until you shoot the semi-flat clear which really tones it down.
Mike
Oahu, Hawaii
Hide Signatures
(in reply to smchale)
       Post #: 39
RE: Yellow F22 Build - 11/27/2011 8:21 AM
Ian R
Score: 100
Status: offline
Hi
Vector unit works very well and is first class, engineered and build.
The thrust vector unit attaches by four self tapping socket screws to the rear bulk head. screws are fed in between the outer scale petals and the inner thrust tubes.
The two units are actuated by heavy duty ball links from servos by metal push rods.  To retrofit you do need the specific thrust tube that feeds the vector pipes which sit outside the main thrust tube.
Ian
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to I-NAV)
       Post #: 40
RE: Yellow F22 Build - 11/27/2011 2:46 PM
tp777fo
Score: 103
Status: offline
Ian, Just a small point. The real Raptor only has thrust vectoring in the pitch axis. I origanally had mine set up like yours and when I found out I inhibited the roll...but.....if it feels good just do it! What a great jet!
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to Ian R)
       Post #: 41
RE: Yellow F22 Build - 11/27/2011 5:12 PM
ddennison
Score: 103
Status: online
I am glad to see interest in this F22 again!
I am still flying my 2008 version which has no thrust vectoring. The only thing I have had to do to the plane is change the tires and replace/repair the main door hinge.
I would suggest to those building it to make the main gear door wood hinge mechanism removeable rather than glued in. I screwed mine in with a few reinforcements. it is simple and maintenance is easy this way.
Watch the nose gear mount, with the main gear so far back the nose doesnt touch lightly (no tlike an F15...)
I am not sure if I am envious of the thrust vectoring or glad I dont have the extra weight? I wont be changing mine.
Good luck to those who are getting into this plane, it is stable, fun, has a wide speed envelope and requires little maintenance and had great landing gear!
Dave
Hide Signatures
(in reply to tp777fo)
       Post #: 42
RE: Yellow F22 Build - 11/27/2011 6:30 PM
Ian R
Score: 100
Status: offline
Hi Tom
The photo was just for effect. I don't use anything like that movement.
yes I have programmed it for both elevator and roll, but todate  have only used it in elevator. Was not aware the real 22 only used it it in pitch.
Dave thanks for the feedback, mine has had zero issues so far.
My main doors are removable.
any help I can provide to the others with their 22's let me know
Ian
Hide Signatures
(in reply to ddennison)
       Post #: 43
RE: Yellow F22 Build - 11/27/2011 6:43 PM
Ian R
Score: 100
Status: offline
shaun
Did you get my RCU pm earlier in the week?
Ian
Hide Signatures
(in reply to Ian R)
       Post #: 44
RE: Yellow F22 Build - 11/27/2011 9:58 PM
tp777fo
Score: 103
Status: offline
My main doors are removable also. I keep a set of spare hinges.....and need them evey now and than. I boofed the landing gear on mine the last time out and needs repair. I will move the CG back about 1" when I do the repairs. I really think we have it way too far forward at 6.5" I dont get the response from the VT as I would expect.
Tom Perry
Hide Signatures
(in reply to Ian R)
       Post #: 45
RE: Yellow F22 Build - 12/6/2011 6:42 PM
gunradd
Score: 120
Status: online
Small update.
I got the new ECU from jet central and a new starter and the engine fired up right away. Made plenty of power and is ready to go!!
I hope to have the airframe in the next few weeks to get cranking on the build.
EDIT
Just called yellow and they wont have the airframes until the first of January. Not very excited to say the least. 3 month wait for a kit is a bit much. But still glad I didnt get the jetlegend F22. Yellow looks much more scale. So I guess I wait.
< Message edited by gunradd -- 12/6/2011 8:50 PM >
Hide Signatures
       Post #: 46
RE: Yellow F22 Build - 12/6/2011 8:46 PM
smchale
Score: 115
Status: online
Great news Kris!
Don't you just love waiting.
Sean McHale
Hide Signatures
       Post #: 47
RE: Yellow F22 Build - 12/6/2011 11:29 PM
tp777fo
Score: 103
Status: offline
Trust me...it is well worth the wait!
Tom Perry
Hide Signatures
       Post #: 48
RE: Yellow F22 Build - 12/6/2011 11:34 PM
k_sonn
Score: 123
Last Login: 5/17/2013
Status: offline
Awesome Kris.  I bet you've built and flown the F-22 at least 100 times in your dreams.   The wait will be well worth it.
Kirk
Schubeler USA Demo Team
"Schubeler - The Future Of Electric Jets"
Hide Signatures
       Post #: 49
RE: Yellow F22 Build - 12/6/2011 11:57 PM
gunradd
Score: 120
Status: online
quote:
ORIGINAL: tp777fo
Tom do you think one could build and fly the F22 in primer in a month and a half?? With the wings being glassed already what is the most time consuming part?
I am going to order some carbon fibre plates and make the trays for the engine componets and get all that done now that the engine is dialed in. Tom is the trays Shaun made for the F22 ARF the way to go for easy access? I think I will copy his but in carbon instead.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.094RCU1
