3-D Flyer
Joined: 4/10/2003 From: Tinley Park, IL, USA Status: offline
Hey Guys.... still waiting to get mine in the air . Yesterday brought her out and had some throttle linkage problems,(could not bring the idol low enough) Took her home and corrected the problem, got it out in my yard to check it out and the zdz 80 twin ran great, however after adjusting the idol my elevators were flapping pretty hard and before i knew it i had a Hitec Digital 5645mg stripped out searching for center! I can not believe it stripped a metal gear! (yes everything is balanced) i am spinning a 24x10 mejlick prop and a dave brown spinner all factory drilled. The only thing i can blame this on (I HOPE!) is the fact that it was sitting on the concrete patio and the wings were not on. Am i correct in the fact that this will put a tremendous amount of undo vibration on the surfaces? But still i can not believe it took out the metal gear! I ordered a replacement gear set i hope to have by tomorrow, if so i'll go for the maiden this weekend. I hope to take this as a lesson learned, run it in the grass with the wings on!!! I know Hitec would warranty this but i do not feel like waiting a month for the turnaround! All this after i have just waited for 2 weeks to install 2 new warrantied servos(Hitec 5645mg's) in the right wing panel after our first maiden attempt. After setting up and checking everything out the right aileron went up then dropped and cooked itself!!! This also took out the second servo from the drag!! I am so dissapointed! My aeroworks Edge has these servos all the way around as well and after about 15 flights all is well so far, but after all these issues on the sukhoi i can not help but be paranoid!!! Hitec was real good about the warranty on the burned out servos.... it actually blew a hole out the side of the case!!! . I just hope i did not get a bad batch of these things! Or they are about tho cost me a $2500.00 airplane!!! Was that strip out my fault?? or do you guys think it should take more vibration?? Thanks all! Glad to hear yours are flying so well! Later.
