RE: 50th Anniversary Flight - Pageboy    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> RE: 50th Anniversary Flight - Pageboy
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: 50th Anniversary Flight - Pageboy - 3/18/2012 1:34 AM
Tee Bee
Score: 100
Last Login: 5/19/2013
Status: offline
Press on with your project. I may or may not get my 50th Anniv flights done by the 24th due to high winds and life issues. It'll happen sooner or later.
_____________________________
Tee Bee
Hide Signatures
(in reply to nitroairplane)
       Post #: 26
RE: 50th Anniversary Flight - Pageboy - 3/18/2012 11:13 PM
exocet-RCU
Score: 100
Status: offline
Got all the parts cut out today. May be able to glue up fuse or wing tonight.
Question: How do I hold the ribs down while sheeting the wing? There doesn't seem to be enough room to pin down the ribs to the board and there's no spar or anything to glue them to in order to keep them from moving.
Tim
Hide Signatures
(in reply to Tee Bee)
       Post #: 27
RE: 50th Anniversary Flight - Pageboy - 3/19/2012 1:13 AM
soarrich
Score: 136
Last Login: 5/17/2013
Status: offline
I'm not sure it's how I did mine, but in the past I've dusted 3M77 on the plans then put wax paper over the plans. After you have that down spray the wax paper with 3M77 and stick the ribs down. You can put CA on the ribs then put the skins on, or use wood glue on the ribs and weigh the skins down with sand bags.
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
(in reply to exocet-RCU)
       Post #: 28
RE: 50th Anniversary Flight - Pageboy - 3/19/2012 1:19 AM
skaliwag
Score: 100
Status: offline
Build the wings upside down??
Real Airplanes have Round Engines and Two Wings.
Hide Signatures
(in reply to soarrich)
       Post #: 29
RE: 50th Anniversary Flight - Pageboy - 3/19/2012 1:27 AM
Tee Bee
Score: 100
Status: offline
It's been a while but I think I tacked each rib at the leading edge with the trailing edge hanging a little over the edge of the table, then carefully pulled the skin down and tacked it to the rear of the ribs. After setting, I removed it from the table and finished gluing the ribs to the skin with CA. Working carefully, it can be done without warping it. Good luck.
Tee Bee
Hide Signatures
(in reply to skaliwag)
       Post #: 30
RE: 50th Anniversary Flight - Pageboy - 3/19/2012 3:00 AM
exocet-RCU
Score: 100
Status: offline
Tee Bee, I ended up doing it just the opposite. I pinned the front of the ribs down over the plan and then put some medium ca on the back, carefully gluing the sheeting down on the back 1/4 inch only. Then I pinned that edge down, pulled the pins from the front, used medium ca on the rest of the rib lengths, and pressed the skin down. Worked well.
Hide Signatures
       Post #: 31
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 3:19 AM
soarrich
Score: 136
Status: offline
Test flew mine for the first time since the fall. Blew the prop off, mines got a little electric motor in, it that uses 5x2 props that I glue on the 1mm prop drive. It'll be roaring on the 24th.
Hide Signatures
       Post #: 32
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 5:44 AM
exocet-RCU
Score: 100
Status: offline
Got the wing done last night. Had to work tonight so didn't have a chance to work on it. Will build the fuse tomorrow night.
Regarding the finish, I just thought I would use some clear, low shrink butyrate dope. I'd like to thin it but not sure how far I can go with it. I plan on brushing it on. I thought two or three thinned coats would be best with light sanding in between to knock down the bumps. What suggestions does anyone have on the ratio of thinner to dope? ...Or does the TLAR (that looks about right) method work?
Tim
Hide Signatures
       Post #: 33
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 8:11 AM
Rendegade
Score: 105
Status: offline
Guess what arrived at work today lads!
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
       Post #: 34
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 10:43 AM
Toysareforkids
Score: 100
Last Login: 5/8/2013
Status: offline
  I did mine basically the same way Tee Bee did his. But then I put 1/32 sheeting on the bottom also. I raised, and rounded the leading edge, and added ailerons too.
 I've ordered the motor, but don't know when it'll get here. I still have to clear it, and add some color trim.
 I built mine while I was scratch building the DR-1
  Pat
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Rendegade)
       Post #: 35
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 12:43 PM
Rubbernecker
Score: 105
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: exocet-RCU
Tim
If you are using model dope 25% thinner should work o.k. If you are using Randolph Dope, about 50% should be fine. I have found that Randolph out of the can is quite a bit thicker than model. Brush fast and the streaking will disappear.
John
Hide Signatures
       Post #: 36
RE: 50th Anniversary Flight - Pageboy - 3/20/2012 12:58 PM
soarrich
Score: 136
Status: offline
@ Toysareforkids
Ailerons?
You going to do a thread on the Triplane?
Hide Signatures
(in reply to Rubbernecker)
       Post #: 37
RE: 50th Anniversary Flight - Pageboy - 3/22/2012 4:03 AM
exocet-RCU
Score: 100
Status: offline
so what throws should I have for this plane? It was originally designed for rudder only but I added elevator. Any thoughts? Also, where should he CG end up? Top of the arch in the wing chord?
Tim
Hide Signatures
       Post #: 38
RE: 50th Anniversary Flight - Pageboy - 3/22/2012 10:32 AM
Toysareforkids
Score: 100
Status: offline
Ailerons?
  I added ailerons because I like to beable to do rolls, and to level the wings on landings, and I like to fly inverted. I took out the dihedral, and also added a elevator to it.
  Been thinking about it. I took a bunch of building pictures of it.
   Pat
Hide Signatures
       Post #: 39
RE: 50th Anniversary Flight - Pageboy - 3/22/2012 1:29 PM
Tee Bee
Score: 100
Status: offline
Tim, mine balances at about 1 3/16" back. Can't remember the throws. Can check them tonight when I'm home.
Tee Bee
Hide Signatures
(in reply to Toysareforkids)
       Post #: 40
RE: 50th Anniversary Flight - Pageboy - 3/22/2012 2:06 PM
Andrew
Score: 105
Status: online
Pat -
That's a slick way to set up aileron horns - I've never seen that before. Are you using tubing or wire insulation. For light weight applications, I would bet that silicone insulation from the high strand count wire would work nicely - very flexible and not too prone to fatigue cracking.
andrew
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
       Post #: 41
RE: 50th Anniversary Flight - Pageboy - 3/23/2012 2:47 AM
Toysareforkids
Score: 100
Status: offline
Andrew,
     Yep, it's wire insulation from some small high temp wire I have. I believe it's silicone. soft yet strong enough, and holds tight! It's easy to adjust, but stays where you put it. Best thing is it's a light weight setup.
  Pat
Hide Signatures
(in reply to Andrew)
       Post #: 42
RE: 50th Anniversary Flight - Pageboy - 3/24/2012 1:38 AM
Tee Bee
Score: 100
Status: offline
Tim, sorry for the late reply regarding the throws. I got mine down from the ceiling tonight to check it out and prep it for flying tomorrow for the 50th anniversary. Anyway, I realized that I never got around to programming it to the DX8. I used to use a DX6i and I didn't save the previous data when programming all the planes to the new transmitter. Sooo, now I've got to start over adjusting the hi/lo rates. That's a shame since I had it dialed in the way I liked it last time out.
Sorry about that. I hope to do some testing/tweaking tomorrow and get it dialed in again.
Tee Bee
Hide Signatures
       Post #: 43
RE: 50th Anniversary Flight - Pageboy - 3/24/2012 3:51 AM
Rubbernecker
Score: 105
Status: offline
I'm ready to go but they are calling for heavy rains here tomorrow. Maybe there will be a break in it. Will also be the maiden. Didn't want to break it before the anniversary flight.
John
Hide Signatures
       Post #: 44
RE: 50th Anniversary Flight - Pageboy - 3/24/2012 8:29 PM
Rubbernecker
Score: 105
Status: offline
I did my flight today. Will try to post video. Have 2. I boinked the first one. Kept pulling that up stick. [>:] Second one was better. Way too windy.
John
Says it doesn't support AVI. Will try to post on other site.
Hide Signatures
       Post #: 45
RE: 50th Anniversary Flight - Pageboy - 3/25/2012 1:32 AM
soarrich
Score: 136
Status: offline
I did mine, too windy for fun though. I messed up starting my new GoPro HD camera and broke the prop on landing so no second try.
Hide Signatures
       Post #: 46
RE: 50th Anniversary Flight - Pageboy - 3/25/2012 1:45 AM
Tee Bee
Score: 100
Status: offline
I got two flights in on mine today. Woohoo! I tried to run the prop backward as Ken Willard did but it kept flying off during the startup. Then I attached it normally and flew it in "high gear".
One of our club members shot the video for me. After I get it loaded, edited, and uploaded I'll post the link.
Click for fullsize
Tee Bee
Hide Signatures
       Post #: 47
RE: 50th Anniversary Flight - Pageboy - 3/25/2012 5:06 AM
Tee Bee
Score: 100
Status: offline
And here's the video:
http://www.youtube.com/watch?v=LBIYnTu72JM&feature=plcp&context=C4c2144bVDvjVQa1PpcFPb8R24lJrj4d3ZOVrS-r9DHYCYSNa1Bzk%3D
What a neat hobby!
Tee Bee
Hide Signatures
       Post #: 48
RE: 50th Anniversary Flight - Pageboy - 3/25/2012 5:15 AM
Andrew
Score: 105
Status: online
Doggies!! That looked more like a Pylonboy rather than a Pageboy. Good show and a good flight. Congrats.
andrew
the "other" andrew
Hide Signatures
       Post #: 49
RE: 50th Anniversary Flight - Pageboy - 3/25/2012 5:30 AM
skaliwag
Score: 100
Status: offline
And Ken Willard flew a Pageboy just like this one, with a Gold Case, Zero tolerance TD .010 on rudder only trusting a rubber band.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
