So I picked up a Aquacraft V24, now what?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> So I picked up a Aquacraft V24, now what?
Page: [1]
Login
So I picked up a Aquacraft V24, now what? - 11/28/2011 3:30 AM
nitrousjunky
Score: 100
Last Login: 7/1/2012
Status: offline
Well I know nothing of RC boats, Im a RC car/truck guy but looking to expand my rc collection. A friend of mine had this boat sitting up in his garage and just wanted it gone, I only gave $50 for it RTR. now it does need a few things to get up and going again but for $50 i couldnt pass this up! All in needs is a bolt and bushings for the rudder and a top cowl thing. I found all the parts on Towerhobbies.com for $52.
Parts Bought include:
AquaCraft Machined Aluminum Rudder Control Arm .46-1.0
AquaCraft Machined Aluminum Rudder Support Assembly .46
AquaCraft Fiberglass Cowl w/Cowl Lock V24
AquaCraft GrimRacer Speed Grease Drive Cable Lube
AquaCraft GrimRacer Radio Box Seal Boot 2/56-4/40 (2)
I got it home and cleaned all the dust off of it, installed some fresh batteries and everything came to life! The radio and servos all work, throttle lnkage is a little wack (to be attended to), The motor turns over freely with good compression and it has spark. once all the replacement parts arrive ill gas her up and see how she runs.
I do have a few Questions.
What is a good mixture to use when mixing fuel, and brand ot premix?
What is this thing worth in running condition?
what (bigger) motor could I use to get more speed out of it?
thanks,
eric.
Hide Signatures
       Post #: 1
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 4:22 AM
rcguy1411
Score: 105
Last Login: 5/19/2013
Status: offline
for the price not a bad grab this hull was never a great one and the engine tends to crack at the exhaust port for a better engine a zenoha 26cc would be a great choice sale price running mabe $200.00 the good news your only into this for $100.00 run it till it dies (it will) then if you enjoy this side of the hobby you can get better products good luck have fun it gets addicting
Hide Signatures
(in reply to nitrousjunky)
       Post #: 2
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 6:41 AM
Ron Olson
Score: 1175
Status: offline
What is a good mixture to use when mixing fuel, and brand to premix?
I use Honda HP-2 or Amsoil Sabre but most synthetic oils for 2-strokes should work fine. Eight ounces to a gallon.
Not much as when they discontinued production they were going dirt cheap. Run it until it dies or falls apart.
A Zenoah 260. AquaCraft should have the parts that should bolt right on from their Rio 51-Z that would make the conversion easier.
Get that strut down as it's tilted up too high. It should be parallel with the bottom of the hull.
Do a search on this forum for your boat, you should be able to find a lot of info both good and bad.
_____________________________
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to rcguy1411)
       Post #: 3
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 10:21 AM
drummer62161
Score: 100
Last Login: 2/26/2013
Status: offline
I have one listed on this site that would bolt right in, with header $295 shipped
Hide Signatures
(in reply to Ron Olson)
       Post #: 4
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 1:59 PM
01VIPER27
Score: 105
Last Login: 5/17/2013
Status: offline
Ditch the radio box it will fail you on its first sinking.  Close up the big gaping hole on the transom and run a 90* or 105* 7/8" header and tuned pipe on either a 26 cc or 30 cc zen, sikk, or RCMK engine.  Stick some floation on that hatch.  It will sink to the bottom of the lake fast.  I loved mine.  I learned a lot from it.  When setting the drive, set your boat on the table on its keel and line up the stinger horizontal with the table.  That is the neutral setting position for the stinger on that boat.  For the trim tabs set the boat flat on either side and and adjust the tabs flat with the table.
Enjoy...
I am on the 13th year of my 2nd childhood and I REFUSE TO GROW-UP!
Hide Signatures
(in reply to drummer62161)
       Post #: 5
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 2:02 PM
nitrousjunky
Score: 100
Status: offline
Thanks guys, I see there's lots to be learned, im hopping to get this running this weekend but well see!
Hide Signatures
(in reply to 01VIPER27)
       Post #: 6
RE: So I picked up a Aquacraft V24, now what? - 11/28/2011 11:07 PM
coyv10
Score: 102
Last Login: 3/24/2013
Status: offline
Before you even think about running iy make shure you install pool noodles for flotation
Hide Signatures
       Post #: 7
RE: So I picked up a Aquacraft V24, now what? - 12/6/2011 2:46 AM
nitrousjunky
Score: 100
Status: offline
well after a week of Cleaning, fixing, loctite, and lube. I discovered that its has no exhaust gaskets and needs rear pushrod seals that go to the rudder. I cant find replacement parts anywhere and Im giving up. Putting up for sale locally and hopfully can make a buck on it.
I did get it to start and run. Simply Gas, prime and fired up on the second pull and ideled. WOW after a good year or better of sitting and it all still works.
Gas is just not for me. Im still thinking about getting a Brushless boat, something in the 24-36'' range that is capiable of 40-50mph area. but well see.
Hide Signatures
(in reply to coyv10)
       Post #: 8
RE: So I picked up a Aquacraft V24, now what? - 12/6/2011 6:41 PM
Ron Olson
Score: 1175
Status: offline
You shouldn't need exhaust gaskets, many run without them. The reasoning behind that is that it helps to transfer heat to the water-cooled flange.
If you really need some, I can send you a few free.
269 Racing Team
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
