What size cells?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> What size cells?
Page: [1]
Login
What size cells? - 8/24/2003 6:49:45 PM
Snowball1952
Status: offline
You always hear about how many cells, but how do you determine what size?
Kevin
       Post #: 1
What size cells? - 8/24/2003 7:37:09 PM
sierra gold
Status: offline
The mah rating of cells determines the "size of the tank" of the battery pack. Thus, how long a pack will fly a given airplane and motor/prop.
If you're referring to your Slow Stick, you probably want 7-8 cells in the 800-1100 mah size. With the stock motor, an 1100 mah pack should give 10-15 mins. of flight.
(in reply to Snowball1952)
       Post #: 2
cell size aa-Sub-C and so on. - 8/24/2003 10:09:31 PM
Snowball1952
Status: offline
I understand that. I was wondering like AA -Sub-C and so on.
Kevin
       Post #: 3
What size cells? - 8/24/2003 11:09:22 PM
sierra gold
Status: offline
I find the "size" you are referring to as quite confusing also.
I therefore don't try to remember them. I go by the mah rating. The higher the mah, the larger the cell is. Each mah rating corresponds to a cell size - AA, AAA, 4/5C, etc. I buy my cells by mah rating.
A quick browsing of any Web site that sells batteries will show the relationship.
       Post #: 4
ok Thanks - 8/25/2003 12:15:27 AM
Snowball1952
Status: offline
       Post #: 5
What size cells? - 8/27/2003 3:56:48 AM
red91sit
Status: offline
but nimh are smaller and have the same mah. but u can use them in place of nicd of same mah and you'll end up with a lighter plane :-D or use nimh of same weight and get longer run time :-D
       Post #: 6
What size cells? - 8/27/2003 4:25:36 AM
Dr Kiwi
Status: offline
Here is a useful link giving sizes for batteries of all sorts!
http://www.powerstream.com/index.html
Good luck in sorting out all of it!
Cheers, Phil
_____________________________
Dr Phil Millener, Chattanooga, TN
       Post #: 7
What size cells? - 8/27/2003 5:17:10 PM
Matt Kirsch
Status: offline
[QUOTE]Originally posted by red91sit
but nimh are smaller and have the same mah. but u can use them in place of nicd of same mah and you'll end up with a lighter plane :-D [/QUOTE]
Incorrect, most of the time. The physical size of the cell is a good indicator of its internal resistance, which in turn is a good indicator of how much current it can produce. Bigger cell == lower internal resistance == higher current.
We are often pushing NiCd cells to their limits as far as draining current from them. If you replace a NiCd cell with a smaller NiMH of the same capacity, you often end up with a NiMH that can't handle the current (Amps) your motor/gearbox/prop setup is drawing. You will notice that you don't have as much power as you did with the NiCds. You will notice that the batteries are VERY HOT after a flight. You will notice that the NiMH cells will no longer hold a charge after a few flights like this.
As a general rule of thumb, you should replace NiCds with NiMH cells of the same PHYSICAL SIZE, that is a 2/3A NiCd should be replaced with a 2/3A NiMH. The advantage is not lighter weight, but additional flying time...
or use nimh of same weight and get longer run time :-D [/QUOTE]
There ya go
       Post #: 8
What size cells? - 8/27/2003 11:14:31 PM
red91sit
Status: offline
oops good to know i was just about to buy a 8 cell aaa pack :EDIT: to replace my 8 AA pack
       Post #: 9
What size cells? - 8/28/2003 3:11:19 AM
Dr Kiwi
Status: offline
Another rule of thumb - because NiMH cells, even of the same physical size as NiCd, have higher internal resistance [i.e. don't give up their electrons as readily], you should replace a 6-cell NiCd pack with a 7-cell NiMh pack, and a 7-cell NiCd pack with an 8-cell NiMh pack................
Cheers, Phil
       Post #: 10
What size cells? - 8/28/2003 5:10:38 PM
Matt Kirsch
Status: offline
Again, another myth that won't die
That used to be true with older NiMH cells, but the most popular NiMH cells these days actually have LOWER internal resistance than their NiCd counterparts. Adding the extra cell is generally not necessary.
KAN1050's, for example, have a punch that's as good as or better than the 600AR/600AE NiCds they'd be replacing.
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
