RE: Top Flite Giant Corsair ARF Disappeared.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Top Flite Giant Corsair ARF Disappeared.
Page: <<   < prev  18 19 [20] 21 22 23 24 25 26 27   next >   >>
Login
RE: Top Flite Giant Corsair ARF Disappeared. - 7/19/2012 12:24 AM
n8622t
Score: 101
Last Login: 6/19/2013
Status: offline
thanks Booker...Fiberclassics is only 20 miles away so Ill take mine to them and make the comparison...Ill let ya know
_____________________________
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to booker-RCU)
       Post #: 476
RE: Top Flite Giant Corsair ARF Disappeared. - 7/19/2012 12:27 AM
n8622t
Score: 101
Status: offline
Computer is well lubricated Capt. G Nice design and will welcome the set up on my Corsair. Are you going to use G-Pete vinyl rivets? I have quite a few on hand for this plane and plan on using them.
Jimmy
Hide Signatures
(in reply to Capt G)
       Post #: 477
RE: Top Flite Giant Corsair ARF Disappeared. - 7/19/2012 12:37 AM
n8622t
Score: 101
Status: offline
I called Fiberglass Specialties just now and I have to give him the firewall measurements where the cowl mounts to the fuse then he will compare it to what he has for the kit. He said there are two versions for the kit, one with and one without the cooling flaps open. Know more tomorrow.
Jimmy
Hide Signatures
       Post #: 478
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 9:27 PM
alb1661
Score: 100
Last Login: 6/18/2013
Status: offline
Question for all TF Corsair 50cc ARF Builders.
Did anybody reverse the position of the flap servos, so they both face the same way. If I did this I could use a Y harness for the flap system. The hard mount for the control horn will still be in the correct position. This is the way the TF P-47 50cc ARF flap servos are installed. I built this plane also. I am trying to use a 9 channel Rx and I don't want to Y the elevators or use a reverse gizmo on the flap system. I am going to Y the rudder and tail wheel together. Thats 9 because I also want to use one channel for my choke.
Steve
Team Clamtown
Hide Signatures
(in reply to n8622t)
       Post #: 479
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 9:33 PM
Hellcat716
Score: 116
Last Login: 6/10/2013
Status: offline
I installed the flap servos the way the manuel said to and used a y harness with no problems, so I do not know why you need to reverse the servo installation.
Hide Signatures
(in reply to alb1661)
       Post #: 480
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 9:46 PM
bushong572
Score: 100
Status: offline
Yes, I changed the installation of 1 of the flap servos so I could use a y harness. I did the same thing on the Top Flite .60 size P-47. If you don't make this change, the flaps will operate in opposite directions (unless you mix 2 channels together). I am flying this plane on 7 channels. I tried to y the elevators together and could not get the same amount of throw. I gave up and used 2 ch and mixed them together. I also had to install a manual choke.
BTW:
I am thinking of buying the TF Giant P-47 or P-40................any recommendations or tips?
Hide Signatures
(in reply to Hellcat716)
       Post #: 481
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 9:55 PM
alb1661
Score: 100
Status: offline
Hellcat 716
If you install the flaps servos per page 9 para 14 (repeat steps 1-13 for the left wing panel), one of the flap servos will need to be reversed. Let me know how you did it with a Y without reversing one of the servos. Maybe I am not reading the directions correctly.
Steve
Team Clamtown
Hide Signatures
       Post #: 482
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 9:59 PM
alb1661
Score: 100
Status: offline
Bushong 572
Check out Wyliewarbirds.com, great article and pictures of the TF P-47
Regards
Steve
Team Clamtown
Hide Signatures
       Post #: 483
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 10:08 PM
Capt G
Score: 100
Last Login: 6/20/2013
Status: offline
How i did it with my 9 ch 9503x is: two ch for elev, 2 ch for flaps (reverse one in TX), one ch with Y for rudder & TW steering, one ch for ailerons with Y, one thro, one choke, one gear. Mixing is not reqd as the TX has provisions to use 2 ch for flaps and elev. in the programming.
Hide Signatures
       Post #: 484
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 10:16 PM
alb1661
Score: 100
Status: offline
Thanks Capt G
Steve
Team Clamtown
Hide Signatures
       Post #: 485
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 10:23 PM
bushong572
Score: 100
Status: offline
quote:
ORIGINAL: alb1661
Bushong 572
Regards
Steve
Thanks...................
Hide Signatures
       Post #: 486
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 11:13 PM
RICK9303
Score: 100
Last Login: 6/16/2013
Status: offline
On my Corsair, I did a mix with the flap and aux 4 on my JR 12x. This is the same way you do with ailerons and elevator so you have a slave channel and a master. Once you have this set you go to servo reversing and switch direction of one flap servo. This makes it so both servos can be mounted in the same way and no y harness. I realize some radios don't have all the bells to do this, but there are also companys that sell a servo reverser. You want to keep the flap servo facing toward fuse, so you are toward end of flap where it goes to mate to center flaps. Hope this helps
Rick
Hide Signatures
(in reply to bushong572)
       Post #: 487
RE: Top Flite Giant Corsair ARF Disappeared. - 7/25/2012 11:23 PM
alb1661
Score: 100
Status: offline
Thanks RICK9309
I have a 11x with a 921x Rx. I'm out of channels unless I purchase a 12 channel Rx, just trying to save 200 bucks on a 12 channel Rx ,by using a Y on the flaps
Regards
Steve
Team Clamtown
Hide Signatures
(in reply to RICK9303)
       Post #: 488
RE: Top Flite Giant Corsair ARF Disappeared. - 7/28/2012 9:31 PM
Hellcat716
Score: 116
Status: offline
Flew the maiden flight this morning with no issues. Three clicks of left aileron trim and five clicks nose down trim. No mix needed with flaps. Another great flying airplane from Top-Flite.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 489
RE: Top Flite Giant Corsair ARF Disappeared. - 7/28/2012 9:33 PM
Hellcat716
Score: 116
Status: offline
A few more pictures.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 490
RE: Top Flite Giant Corsair ARF Disappeared. - 7/28/2012 10:34 PM
Capt G
Score: 100
Status: offline
pictures look great!
Hide Signatures
       Post #: 491
RE: Top Flite Giant Corsair ARF Disappeared. - 7/30/2012 1:33 AM
tlroliff
Score: 100
Status: offline
Well done! Looks great.
Hide Signatures
       Post #: 492
RE: Top Flite Giant Corsair ARF Disappeared. - 8/1/2012 8:40 PM
alb1661
Score: 100
Status: offline
I was having an issue with installing the new robart 148E electric retracts.
When I installed the mount in the wing the rear of the actuator motor was hitting the rear aluminum support plate in the retracted position , even throught I had the mount fully forward to the leading edge of the wing.
I called Robart and there is a fix for this. They are sending me 4 new bushings, (#7) (on your parts diagram)actuator spacers, that will be oblong so that the motor actuator cannot move rearward to contact the aluminum support plate when it retracts.
They advised me that all new production models will have these new oblong bushings
See Attached
Click for fullsize
Team Clamtown
Hide Signatures
(in reply to tlroliff)
       Post #: 493
RE: Top Flite Giant Corsair ARF Disappeared. - 8/1/2012 11:52 PM
Capt G
Score: 100
Status: offline
Mine have been working ok so far. Don't know which bushings i have.
Hide Signatures
       Post #: 494
RE: Top Flite Giant Corsair ARF Disappeared. - 8/16/2012 10:17 AM
handyman 220
Score: 100
Status: offline
I bought the retractable tailwheel from Earl Aune. It looks really nice and should raise the tail to look more scale than the Robart retractable tailwheel. I'm not sure how robust the Earl Aune unit will be,only time will tell, but it does look sweeeett.
Do it right the first time, or not at all!
Hide Signatures
       Post #: 495
RE: Top Flite Giant Corsair ARF Disappeared. - 8/16/2012 11:05 AM
vatechguy3
Score: 100
Status: offline
Got any pics of that tailwheel or a link??
Tony
Hide Signatures
(in reply to handyman 220)
       Post #: 496
RE: Top Flite Giant Corsair ARF Disappeared. - 8/16/2012 10:06 PM
handyman 220
Score: 100
Status: offline
Will try to get some pics up later I have to charge the batteries. I did read the directions, the tail wheel comes with a lifetime warranty to the original owner. I wonder if that covers less than perfect carrier landings
Hide Signatures
(in reply to vatechguy3)
       Post #: 497
RE: Top Flite Giant Corsair ARF Disappeared. - 8/17/2012 10:07 AM
handyman 220
Score: 100
Status: offline
Here is a pic of the retract from Earl Aune You can contact him at earlaune@comcast.net. He is very helpful and responds quickly to e-mails. He shipped mine out the same day I ordered it. Best part is it is made by veterans in the USA
Click for fullsize
Hide Signatures
       Post #: 498
RE: Top Flite Giant Corsair ARF Disappeared. - 8/17/2012 5:45 PM
oriole
Score: 100
Status: offline
Handyman,
I see no electric motor or pneumatic cylinder. What powers it to retract?
Oriole
Hide Signatures
       Post #: 499
RE: Top Flite Giant Corsair ARF Disappeared. - 8/17/2012 6:18 PM
bushong572
Score: 100
Status: offline
Handyman 220.................
Please post pics of the tailwheel install. I saw that tailwheel the week after I finished my corsair.
I'm still interested in one, though.
Hide Signatures
(in reply to oriole)
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
