tamiya m05 setup    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> tamiya m05 setup
Page: [1]
Login
tamiya m05 setup - 12/7/2011 3:27 AM
magnum500
Score: 100
Last Login: 5/7/2013
Status: offline
i have a problem with my m05 . the problem is in a high speed sweeping turn the car starts to stutter , like it is breaking loose but instead of spinning out it just stutters or hops the car is new and everything is set to factory specs . stock motor stock shock weight no sway all 4 tires are s grip , backs are bald . any help is always appreciated .
Hide Signatures
       Post #: 1
RE: tamiya m05 setup - 12/7/2011 12:58 PM
The Mad Modder
Score: 341
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: magnum500
Perhaps it's not spinning out because the tires are too grippy. S compound is a pretty soft compound. Does it feel/look like an electrical problem? I'm not sure I understand what you mean by "stutter".
_____________________________
God bless America
Hide Signatures
(in reply to magnum500)
       Post #: 2
RE: tamiya m05 setup - 12/7/2011 2:01 PM
magnum500
Score: 100
Status: offline
thanks for the reply . i`ll try to explain , in a high speed sweeping turn you can hear the rear of the car shake or bounce . i can hear the body jigle and bounce on the posts . when the car exits the turn the noise goes away and the car sounds nice and quiet . it is not an electrical issue . it seems to be a traction issue maybe too much ????
Hide Signatures
(in reply to The Mad Modder)
       Post #: 3
RE: tamiya m05 setup - 12/7/2011 2:54 PM
The Mad Modder
Score: 341
Status: offline
quote:
ORIGINAL: magnum500
Yeah, since you're using s compound tires, it's probably grabbing at the pavement due to high traction. Putting small pieces of foam on the body posts between the body and lower pin helps with body rattle.
http://www.youtube.com/watch?v=91Q1IB9GwCA
< Message edited by The Mad Modder -- 12/7/2011 3:19 PM >
God bless America
Hide Signatures
       Post #: 4
RE: tamiya m05 setup - 12/10/2011 2:27 AM
magnum500
Score: 100
Status: offline
i think i`ll try to glue the sidewalls on the rear tires .
Hide Signatures
       Post #: 5
RE: tamiya m05 setup - 12/12/2011 6:56 AM
Andyjk
Score: 105
Last Login: 4/27/2013
Status: offline
Try S grip on the front only and the regular ones on the back
RS4 3 Evo-Elec., E-Sav, TT-01, DF-01, Slash, CC-01, M-05, M-04, TT-01Ra, HZ Champ, HZ Super Cub, Turnigy 118B, 2x Dark Impac
Hide Signatures
       Post #: 6
RE: tamiya m05 setup - 2/26/2012 8:01 PM
Tarheel1949
Score: 100
Last Login: 2/26/2012
Status: offline
Has anyone heard of the guy that sells the Tamiya red dot motors and if he still sells them? I would like to buy some for our spec class. Thanks in advance
Glenn
Hide Signatures
(in reply to Andyjk)
       Post #: 7
RE: tamiya m05 setup - 4/21/2012 3:03 AM
FNG RIDER
Score: 121
Last Login: 4/12/2013
Status: offline
Just finish M05 Pro build, with 17.5 for TCS Mini Pro racing.
I run S Grips or A hard and softs.
TRF shocks 50wt/50wt 3 hole
Blue/Yellow springs
camber front -1 rear -1
ball diff
cvd
1.5 rear tow
o front tow
pinion 20t
ive heard of red dot silver cans but opted for brushless for less hassle.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Traxxas Slash SSC LCG 4x4 MMP SCT, Tamiya TA05v2
Hide Signatures
(in reply to Tarheel1949)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
