RE: Quaker 84 Penn Valley Hobbies    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Golden Age, Vintage & Antique RC >> RE: Quaker 84 Penn Valley Hobbies
Page: <<   < prev  1 [2]
Login
RE: Quaker 84 Penn Valley Hobbies - 1/27/2012 1:53 PM
evan-RCU
Score: 105
Last Login: 5/23/2013
Status: offline
Yep, from many years ago. That shot was taken at the Festival of Giants in Deland Florida. It made it into the May 2004 issue of Model World, a UK magazine that fly-in. It was gas powered back then.
quote:
ORIGINAL: RocketRob
Evan, It just dawned on me that is the plane in your avatar....
_____________________________
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
Hide Signatures
(in reply to RocketRob)
       Post #: 26
RE: Quaker 84 Penn Valley Hobbies - 1/27/2012 8:50 PM
Brunox
Score: 100
Last Login: 3/9/2013
Status: offline
Hi SafeTwire,
I started this afternoon to build the fuselage of my quaker and I understand your pics and comments will be of great help ! Regarding the glue, I plan to use Titebond for the front of the fuse but don't know if it's waterproof ?
Here are some pics of the work completed so far...
Bruno
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to safeTwire)
       Post #: 27
RE: Quaker 84 Penn Valley Hobbies - 1/29/2012 7:53 AM
FNQFLYER
Score: 110
Status: offline
For answers on this model and other Antique models visit the SAM site.  We fly these and other models similar to it all over the world.  Mine has a CS version of an AMCO 3.5 diesel powering it.
Club Saito member 710
Hide Signatures
       Post #: 28
RE: Quaker 84 Penn Valley Hobbies - 5/5/2012 4:04 PM
Brunox
Score: 100
Status: offline
Hi, I'm back with my questions about the building of the quaker 84 : I'm trying to put the engine in place using an engine mount. The engine would be positioned like this (see picture). Can anyone tell me if it seems right ? Not too advanced ?
Bruno
Click for fullsize
Hide Signatures
       Post #: 29
RE: Quaker 84 Penn Valley Hobbies - 5/5/2012 4:07 PM
Brunox
Score: 100
Status: offline
Another picture of the position of the engine
Click for fullsize
Hide Signatures
(in reply to Brunox)
       Post #: 30
RE: Quaker 84 Penn Valley Hobbies - 5/6/2012 12:28 AM
H5487
Score: 117
Last Login: 5/6/2013
Status: offline
What size OS are you putting on it?
Harvey
Weather Geek
Hide Signatures
       Post #: 31
RE: Quaker 84 Penn Valley Hobbies - 5/6/2012 7:35 AM
Brunox
Score: 100
Status: offline
An OS .56. I wanted to buy a SAITO but it ain't easy to find here in Belgium (especially for replacement parts)...
Hide Signatures
(in reply to H5487)
       Post #: 32
RE: Quaker 84 Penn Valley Hobbies - 5/6/2012 9:41 AM
H5487
Score: 117
Status: offline
The .56 is reportedly an ideal size for the 84" Quaker. That's what I got for mine. (Which I have yet to begin.)
Harvey
Weather Geek
Hide Signatures
       Post #: 33
RE: Quaker 84 Penn Valley Hobbies - 5/7/2012 1:19 AM
evan-RCU
Score: 105
Status: offline
Looks like a good position and the .56 will be more than enough...
Hide Signatures
(in reply to H5487)
       Post #: 34
RE: Quaker 84 Penn Valley Hobbies - 5/8/2012 4:52 AM
countilaw
Score: 219
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Brunox
Bruno,   I'm not really  100 % sure,   but from past experience,  you may want to put   2 or  3 degrees of  down thrust.     Might ask some other members and see what they say.
Otherwise, it's looking great.
Frank
AMA # 5810
It''s a hobby, not a job.
Hide Signatures
       Post #: 35
RE: Quaker 84 Penn Valley Hobbies - 5/8/2012 8:53 AM
Brunox
Score: 100
Status: offline
Thanks for your answers ! Indeed, I put about  two degrees of down thrust on the firewall according to a previous post of Goldenage.
And a senior member of the club I was a member of  told me to put two little  washers (up and down) between the left side of the engine mount and the firewall (looking from the tail of the plane) to avoid the Quaker going on the left.
Hide Signatures
(in reply to countilaw)
       Post #: 36
RE: Quaker 84 Penn Valley Hobbies - 1/13/2013 8:10 PM
Brunox
Score: 100
Status: offline
Hi everyone,
I'm back with the building of the Quaker 84'...
I plan to vover it (with solartex) very soon.
But I still have a question with the area near the windows.
Since there are little longerons glued on both sides of the fuse, I can't unerstand how one is supposed to cover this area. First covering, and than gluing on the plastic staff ?
And what about fact that the covering will not be parallel to the fuse ?
Thanks !
Brunox
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: Quaker 84 Penn Valley Hobbies - 1/13/2013 8:20 PM
Brunox
Score: 100
Status: offline
I've got another question, regarding the distance between the tank and the engine.
In the documentation of the OS .56, they say the tank needs to be located as close as possible to the engine.
Since I guess balance of the quaker may be a little triggy, I plan to locate the battery as close as possible to the firewall.
If I do so, I need to move the tank about 3 centimeters towards the tail.
Anyone knows if this might be a problem ?
Thanks in advance for your attention
Bruno
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 38
RE: Quaker 84 Penn Valley Hobbies - 1/13/2013 9:41 PM
culver
Score: 100
Last Login: 5/17/2013
Status: offline
Brunox, put your equipment in and move it around to find balance before you cover. If you use film covering it will not have much weight, that is what I did for my Quaker Flash that was covered with Micafilm. The covering can attach to the window frame area or you can build up around the frame openings to attach covering (heavier) and attach windows with r/c 56 or similar adhesive.
Hide Signatures
       Post #: 39
RE: Quaker 84 Penn Valley Hobbies - 1/14/2013 12:07 AM
H5487
Score: 117
Status: offline
Brunox,
So far your Quaker is looking good!
The Saito instructions say to mount the tank close to the engine because it won't draw from a distance without a fuel pump. Nonetheless, muffler pressure should be sufficient to allow you to put the tank up to a few inches aft of the firewall. Since the center of the tank should be close to the same level as the carburetor, perhaps you have room to put the battery pack under the tank? If you choose to do so, you might want to add a trap door under the battery so you can get to it without having to dismantle your fuel system.
Harvey
Weather Geek
Hide Signatures
(in reply to culver)
       Post #: 40
RE: Quaker 84 Penn Valley Hobbies - 1/22/2013 1:02 PM
Brunox
Score: 100
Status: offline
Thanks for your responses !
Indeed, I made a little trap to be able to remove the battery without needing to remove the tank. But he battery is too high to put the tank above it, so it must be positionned at about 1 and 1/2 inches from the firewall.
I'll try to balance the plane without covering (solartex) to get a first idea ...
Bruno
Hide Signatures
(in reply to H5487)
       Post #: 41
RE: Quaker 84 Penn Valley Hobbies - 3/5/2013 3:19 AM
GoldenAge
Score: 105
Last Login: 3/5/2013
Status: offline
Good luck with your Penn Valley Quaker. They are a joy to fly!
Here's mine on a low and slow flyby.
Click for fullsize
Hide Signatures
       Post #: 42
RE: Quaker 84 Penn Valley Hobbies - 3/9/2013 8:26 PM
Brunox
Score: 100
Status: offline
Thanks. Wonderful plane ! I printed the pics of your plane  you posted (before covering was done) and they were of great help for the building of mine !
Here's a link towards an article (in french) and a video of a guy who says there is nothing for him like slow flying...
http://www.jivaro-models.org/buccaneer/page_buccaneer.htm
I would like to see some pics (or to get some builder's tips ?) of the windows on a quaker.
If anyone has some...
Bruno
Hide Signatures
(in reply to GoldenAge)
       Post #: 43
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
