aftershock 8e wheel? do i need different gears or motor setup    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> aftershock 8e wheel? do i need different gears or motor setup
Page: [1]
Login
aftershock 8e wheel? do i need different gears or motor... - 12/9/2011 8:19 PM
chevyb
Score: 105
Last Login: 2/3/2012
Status: offline
i have the aftershock 8e and wanted to put bigger wheels on it the stock size is aprox. 4.5" tall x 1.75" wide the ones i have are aprox 5.75" tall x 3.5" wide i had to change axles and hexes not a big deal as i have the stuff i ran the truck with them on and noticed shorter run times and it seemed to get hot and cutoff so i switched back to normal size tires my question is what will i need to change i.e. motor, gears or whatever to run these tires without any issues
< Message edited by chevyb -- 12/11/2011 4:58 PM >
_____________________________
redcat aftershock 8e
redcat rs10 xt
Hide Signatures
       Post #: 1
RE: aftershock 8e wheel? do i need different gears or ... - 12/11/2011 4:36 PM
chevyb
Score: 105
Status: offline
this is what im going for if this helps......someone has to know something
Click to see fullsize image.
Click for fullsize
redcat rs10 xt
Hide Signatures
(in reply to chevyb)
       Post #: 2
RE: aftershock 8e wheel question - 12/11/2011 5:04 PM
fahaka
Score: 100
Last Login: 6/19/2013
Status: offline
Do you have the heat sink or cooling fan option for system? I've taken my Aftershock and run it with Avalanche/Monsoon tires with no problems. I do run the fan and heat sink on my setup.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3
RE: aftershock 8e wheel question - 12/11/2011 5:08 PM
fahaka
Score: 100
Status: offline
I've done the reverse as well.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to fahaka)
       Post #: 4
RE: aftershock 8e wheel? do i need different gears or m... - 12/11/2011 5:12 PM
chevyb
Score: 105
Status: offline
esc has fan as far as motor no fan or heatsink
redcat rs10 xt
Hide Signatures
       Post #: 5
RE: aftershock 8e wheel question - 12/11/2011 5:14 PM
chevyb
Score: 105
Status: offline
what are the size of your tires compared to mine
redcat rs10 xt
Hide Signatures
       Post #: 6
RE: aftershock 8e wheel question - 12/11/2011 5:22 PM
fahaka
Score: 100
Status: offline
The Avalanche tires not pictured are over 6" tall and 3.8" wide.
Hide Signatures
       Post #: 7
RE: aftershock 8e wheel question - 12/11/2011 5:24 PM
chevyb
Score: 105
Status: offline
ok did you run axle extensions
redcat rs10 xt
Hide Signatures
       Post #: 8
RE: aftershock 8e wheel question - 12/11/2011 5:31 PM
fahaka
Score: 100
Status: offline
Yeah I put the Redcat extensions, / 17mm conversion, on and they were enough to run the larger tires. At top speed that tire is probably more like 9" tall and 0.5" wide. The Earthquake flies on that lager size.
Hide Signatures
       Post #: 9
RE: aftershock 8e wheel question - 12/11/2011 5:38 PM
chevyb
Score: 105
Status: offline
ok yea my wheels ar 14mm so i have 1.5" extensions with 14mm hexes that slide over axles but i also have redcats 17mm conversion kit just no 17mm wheels....my wheels are from a tamiya
redcat rs10 xt
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
