Hardest to fly jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
BVM eBandit - RTF
Seller:  pbusa1400
Details:   $7,500.00   |  5/25/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Hardest to fly jet
Page: [1] 2   next >   >>
Login
Hardest to fly jet - 12/13/2011 10:09 PM
airraptor
Score: 130
Last Login: 5/25/2013
Status: offline
What is the hardest, or most technical, or highest landing speed, or shortest wheelbase or all the above jet to fly, takeoff and land out there.
Maybe F-104 F-105 F-18 with flying stabs or any other?
_____________________________
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 1
RE: Hardest to fly jet - 12/13/2011 10:17 PM
STKNRUD
Score: 110
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: airraptor
The last one I crashed.
I didn''''t say it was the plane''''s fault. I said I was blaming the plane.
Hide Signatures
(in reply to airraptor)
       Post #: 2
RE: Hardest to fly jet - 12/13/2011 11:06 PM
FalconWings
Score: 121
Status: offline
Not from personal experience, but I've heard that the F-18E and the F4 are a handful to land.
Yes I know, anyone can eventually master the technique, but overall I heard there is deffinetely a learning curve.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to STKNRUD)
       Post #: 3
RE: Hardest to fly jet - 12/13/2011 11:16 PM
rcjets_63
Score: 144
Status: offline
The Gripen was pretty tough since there were so few people who were succesful with them and there wasn't any significant experience out there to ask advice which is why I started the Gripen Owners/Build thread. However, by trial and error we worked together to figure out the best setup and now it's a breeze to fly and land.
Regards,
Jim
Hide Signatures
(in reply to FalconWings)
       Post #: 4
RE: Hardest to fly jet - 12/13/2011 11:52 PM
j.duncker
Score: 121
Status: offline
Lockheed F104 Starfighter flown WITHOUT the tip tanks.
Ask me how I know this.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to rcjets_63)
       Post #: 5
RE: Hardest to fly jet - 12/14/2011 12:12 AM
schroedm
Score: 103
Status: offline
Any jet not setup properly.
Is any model really that hard to fly once sorted?? Look at the post above re the Gripen as proof.
Hide Signatures
       Post #: 6
RE: Hardest to fly jet - 12/14/2011 11:41 AM
DominicM
Score: 101
Status: offline
quote:
ORIGINAL: airraptor
Any under powered EDF jet conversion with an excessively large lipo load. Sorry, just had to get that off my chest.
Hide Signatures
(in reply to schroedm)
       Post #: 7
RE: Hardest to fly jet - 12/14/2011 11:59 AM
schroedm
Score: 103
Status: offline
quote:
ORIGINAL: DominicM
quote:
ORIGINAL: airraptor
Dom,
Yep agreed - so I'll reiterate.... "Any jet not setup properly" - what were you thinking
Hide Signatures
(in reply to DominicM)
       Post #: 8
RE: Hardest to fly jet - 12/15/2011 12:16 AM
as722
Score: 100
Status: offline
British lightning.
Carden Aircraft
Hide Signatures
       Post #: 9
RE: Hardest to fly jet - 12/15/2011 12:50 AM
hooker53
Score: 100
Status: offline
quote:
ORIGINAL: DominicM
quote:
ORIGINAL: airraptor
Dom. Plus one. I had one. Passed PartHad. Ha. Ha.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
       Post #: 10
RE: Hardest to fly jet - 12/15/2011 1:51 AM
tp777fo
Score: 103
Status: offline
As a general rule a model will fly very closely to its full size counterpart. There are differences caused by airfoil, wing loading, balancing and so forth but an F-4 would be expected to be more more difficult than an F15...just like the real ones
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to hooker53)
       Post #: 11
RE: Hardest to fly jet - 12/15/2011 2:40 AM
rhklenke
Score: 129
Status: offline
quote:
ORIGINAL: FalconWings
My old F-4 was really fairly easy to land. It sort of "arrived" with little tendency to bounce.
The hardest jets to land that I've ever flown were the PCM Models L1011 and the BVM T-33. Both had to be landed nose high at just the right airspeed or a bounce scenario started that ended with the model at close to zero airspeed, 30+ degrees nose up, and 2+ feet off the ground. The next thing that happened was the pilot carrying the model back to the pits with the gear hanging by the air hoses, if he was lucky, and up through the top of the wing if he was not.
Bob
Hide Signatures
       Post #: 12
RE: Hardest to fly jet - 12/15/2011 3:15 AM
S HARRIS
Score: 100
Status: offline
Bob I'm with you!! PCM L1011 top of list for me. Not sure why I still have mine. Guess a little luck helps. Scott
Click to see fullsize image.
Click for fullsize
If it works use it,USA JWM TEAM MEMBER
Hide Signatures
(in reply to rhklenke)
       Post #: 13
RE: Hardest to fly jet - 12/15/2011 3:24 AM
Randy M.
Score: 100
Status: offline
better to be lucky than good...
Silence is golden,,, but duct tape is silver.
Hide Signatures
(in reply to S HARRIS)
       Post #: 14
RE: Hardest to fly jet - 1/13/2012 8:03 PM
Baron35R
Score: 100
Last Login: 5/21/2013
Status: offline
Scott
does that mean you want to sell yours?
Andy
Hide Signatures
(in reply to Randy M.)
       Post #: 15
RE: Hardest to fly jet - 1/13/2012 8:18 PM
bigplumbs
Score: 120
Last Login: 12/20/2011
Status: offline
quote:
ORIGINAL: DominicM
quote:
ORIGINAL: airraptor
Very true indeed
It ain''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Hide Signatures
       Post #: 16
RE: Hardest to fly jet - 1/13/2012 8:29 PM
Billy
Score: 100
Last Login: 4/25/2013
Status: offline
I wouldn't call it the "the hardest" but it does demand the most concentration and has a small window of error on the landing. The Firebird. Had about 80 flights on mine. On or about the 25 th flight I got a little too comfortable on the landing and she did the bounce. Fixed her up and learned my lesson.
Billy
Hide Signatures
(in reply to bigplumbs)
       Post #: 17
RE: Hardest to fly jet - 1/13/2012 8:33 PM
JohnMac
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: as722
British lightning.
Based on what evidence? I have seen several fly perfectly sweetly.
Hide Signatures
(in reply to as722)
       Post #: 18
RE: Hardest to fly jet - 1/13/2012 8:49 PM
ron Sweeney
Score: 100
Last Login: 5/18/2013
Status: offline
JL Grippen and Tom Cooke F4 off grass at 26 pounds. Ron.
Hide Signatures
       Post #: 19
RE: Hardest to fly jet - 1/13/2012 8:59 PM
HORNET FLYER
Score: 100
Status: offline
+1 firebird.......brain must be dialed in to land that one......maybe larger flaps would help slow her down!
Click for fullsize
rchobbyshop.com
"best little hobby house in texas"
Hide Signatures
(in reply to ron Sweeney)
       Post #: 20
RE: Hardest to fly jet - 1/13/2012 10:30 PM
bevar
Score: 142
Status: offline
Hmmm...I heard the Surrender Jet was pretty tough too!
Beave
quote:
ORIGINAL: rcjets_63
Regards,
Jim
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jetcat and EVO Jet Rule!
Allied Scale Squadron
Hide Signatures
       Post #: 21
RE: Hardest to fly jet - 1/13/2012 10:33 PM
Henke Torphammar
Score: 100
Status: offline
Any jet you pilot that you think cost alot seem to make it self very glitchy in the air :-)
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to bevar)
       Post #: 22
RE: Hardest to fly jet - 1/13/2012 10:50 PM
basimpsn
Score: 120
Status: offline
quote:
ORIGINAL: schroedm
So true because I use to think my F-18C was a handful hard until we change the C/G, what a differences, even comes in slower than my Euro.
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
       Post #: 23
RE: Hardest to fly jet - 1/14/2012 4:42 AM
Molnar142
Score: 100
Status: online
quote:
ORIGINAL: basimpsn
quote:
ORIGINAL: schroedm
Just curious...what F-18C and what was the CG move (for or aft)?
Cincinnati Jet Club
Hide Signatures
(in reply to basimpsn)
       Post #: 24
RE: Hardest to fly jet - 1/14/2012 3:20 PM
flyinfool1
Score: 100
Last Login: 5/24/2013
Status: offline
None of them are hard to fly.
It is the point where you want them to stop flying but still be flyable that is hard on some.
As was mentioned repeatedly above, once you develop the skill set for your jet, AND get it set up properly, none of them are hard to fly.
< Message edited by flyinfool1 -- 1/15/2012 2:23 PM >
Jeff Borowski
RAMS Club President
Hide Signatures
(in reply to Molnar142)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
