Adjusting ASP 61
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> Adjusting ASP 61
Page: [1]
Login
Adjusting ASP 61 - 4/18/2002 5:07:02 AM
PieGuy-RCU
Status: offline
I bought a used Asp 61 at a local auction and I'm putting it on a 4 Star 60. It starts real easy but when I throttle down it takes several seconds to slow down. On the side where the cable is attached there is a 2nd needle valve. Is this a low speed adjustment? Also on the top ther is a screw with a spring under it. What is this for? I have some instructions from Just Engines but no picture that tells me what screw to turn. Thanks
_____________________________
"50 ft rolls must start at least 50 feet high"
       Post #: 1
Adjusting Carb - 4/18/2002 6:24:55 PM
ninefingers
Status: offline
Pie,
I'm not familiar with that particular engine but from your excellent description its sounds like all the rest! The adjustment opposite the needle valve (by the cable) is indeed the low end idle adjustment. The other one (with the spring ) is the "throttle stop" adjustment. If you screw that in and out SLOWLY while moving the throttle arm open and shut, you'll get a feel for what it does. You want it set so that it stops the barrel right when its shut all the way. That would be "engine off" position.
Thats what they all do, but as far as adjusting the high and then the low ends, that best left for a thread with the "engines" experts!
(in reply to PieGuy-RCU)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU5
