RE: Turnigy Titian 1/5 scale 4X4    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: Turnigy Titian 1/5 scale 4X4
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Turnigy Titian 1/5 scale 4X4 - 1/7/2012 2:03 AM
whittron
Score: 100
Last Login: 1/29/2012
Status: offline
Your better off being on thge safe side and just get the rear cnc box,bvecause if it does blowout your ring and pinion then your looking at around $50 plus you then bought a nutech plastic case $17 with shipping,and all the time it takes to pull it all back apart and replace.
Hide Signatures
(in reply to D_wilbur)
       Post #: 26
RE: Turnigy Titian 1/5 scale 4X4 - 1/7/2012 4:18 AM
cheezer1222
Score: 116
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: whittron
You have a point. I just wish being on the safe side didn't cost me $120. Plus if I lock the center diff, that's another $50.
So even the "upgraded" nutech plastic diff cases are not strong enough to withstand a normal engine? I can't imagine what they were like before the upgrade.
Hide Signatures
(in reply to whittron)
       Post #: 27
RE: Turnigy Titian 1/5 scale 4X4 - 1/9/2012 9:41 PM
cheezer1222
Score: 116
Status: offline
Got my Titan in today. Here's a couple pics:
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to cheezer1222)
       Post #: 28
RE: Turnigy Titian 1/5 scale 4X4 - 1/9/2012 9:42 PM
cheezer1222
Score: 116
Status: offline
I was a little confused by this:
Click for fullsize
Hide Signatures
       Post #: 29
RE: Turnigy Titian 1/5 scale 4X4 - 1/9/2012 11:16 PM
kg2mb
Score: 100
Last Login: 4/30/2013
Status: offline
its a nutech??looks great,does it have a 2 bolt or 3 bolt cylinder?
_____________________________
Hpi 5sc Ae SC8E rockstar
Hide Signatures
       Post #: 30
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 4:36 AM
cheezer1222
Score: 116
Status: offline
quote:
ORIGINAL: kg2mb
I haven't looked, but I'm guessing 2 bolt.
Like the others have said, this is supposed to be a (rebranded?) smartech titan. That's why I got confused when I saw "Nutech" on the box.
Hide Signatures
(in reply to kg2mb)
       Post #: 31
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 7:35 AM
bentley marshall
Score: 105
Status: offline
nutech own smartech now it all comes out of the same factory thats why its has nutech on the box
the truck is a smartech titan rebraneded by hk
it will have a smartech 28cc engine thats is a 3 bolt head engine
a cy or zenoah will bolt in on same mounts no problem
hope that clears up a few questions
owner www.rcinnovations.co.nz
Hide Signatures
       Post #: 32
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 7:43 AM
bentley marshall
Score: 105
Status: offline
and if you want to use a center diff locker from nutech you will need the center ring gear as well from the nutech as the smartech one is differnt and the locker wont bolt up
you allso might need the center drive cups from a nutech as well not 100% sure on that one
Hide Signatures
(in reply to bentley marshall)
       Post #: 33
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 1:41 PM
kg2mb
Score: 100
Status: offline
The box says "Nutech" so its not a Smartech rite?
Should be all Nutech parts.Wish Nutech would chime in on this..
Hide Signatures
       Post #: 34
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 2:27 PM
cheezer1222
Score: 116
Status: offline
quote:
ORIGINAL: bentley marshall
Thanks for clearing up those questions. I also have the same question as kg2mb. If Nutech owns Smartech, why are they still producing Smartech vehicles? You would think they would just discontinue the Smartech vehicles and only sell Nutech. Unless the Smartech line is supposed to be a budget vehicle?
Hide Signatures
       Post #: 35
RE: Turnigy Titian 1/5 scale 4X4 - 1/10/2012 6:19 PM
bentley marshall
Score: 105
Status: offline
they are still 2 differnt brand names the smartech line has been round for quite a few years and they make more models that nutech do
the quality is a lit better now that they come out of the nutech fatory i sell smartech ans nutech in my shop
its like ford and mazda in japan just about the same cars but differnt name
Hide Signatures
       Post #: 36
RE: Turnigy Titian 1/5 scale 4X4 - 1/11/2012 7:10 PM
D_wilbur
Score: 100
Last Login: 5/14/2013
Status: offline
Well I lost another screw and washer on the other steering knuckle this time. front steering knuckles seam to be the biggest problem with the truck. I received the parts I ordered last night. The new screws come with a lock nut I will se if ther is room for it in the stock knuckle. I will see if I have time to install the parts this week end.
Hide Signatures
       Post #: 37
RE: Turnigy Titian 1/5 scale 4X4 - 1/11/2012 7:17 PM
cheezer1222
Score: 116
Status: offline
quote:
ORIGINAL: D_wilbur
You'll have to let me know how that goes. Bentley marshall was mentioning that in order to lock the center diff, you need to also get the nutech center ring gear in order to get it to bolt up. Let me know of that's the case. I'm kind of waiting on your results to see what sort of order I should place.
Hide Signatures
       Post #: 38
RE: Turnigy Titian 1/5 scale 4X4 - 1/11/2012 8:41 PM
bentley marshall
Score: 105
Status: offline
heres a pic of the differnt gears and the diff locker you might allso need the drive cups
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 39
RE: Turnigy Titian 1/5 scale 4X4 - 1/11/2012 9:16 PM
kg2mb
Score: 100
Status: offline
www.jhchobby.com/< anyone ever order from this place?
Hide Signatures
       Post #: 40
RE: Turnigy Titian 1/5 scale 4X4 - 1/12/2012 12:36 AM
cheezer1222
Score: 116
Status: offline
What are people using for throttle servos? I noticed that the turnigy titan uses a steering servo sized servo for throttle/brake. I have a hs-5755 I plan on using for steering. I also have an extra 5755 that I could use for throttle/brake, but that seems like overkill.
Hide Signatures
(in reply to kg2mb)
       Post #: 41
RE: Turnigy Titian 1/5 scale 4X4 - 1/12/2012 12:47 AM
bentley marshall
Score: 105
Status: offline
i run a 5755 in my nutech and it stops great ..i had a 755 in there befor that was not so good
Hide Signatures
       Post #: 42
RE: Turnigy Titian 1/5 scale 4X4 - 1/14/2012 7:03 PM
D_wilbur
Score: 100
Status: offline
I running the stock servos that came with the truck. Throttle/ Break servo works fine the steraring servo is a bitt week. I'm using a 5 cell battery as well. I have a Futaba 3306 I will try it's over 300 in oz at 6 volts
Hide Signatures
       Post #: 43
RE: Turnigy Titian 1/5 scale 4X4 - 1/23/2012 2:34 AM
D_wilbur
Score: 100
Status: offline
I had time to work on the truck this afternoon. I did not order all the parts need to install the locking center diff. I installed the header the hole centers were off about 3mm. I drilled out the 2 holes to fit. The header and pipe don't fit the pipe is a about 1-1/2" short. I will weld an extention to to make it work. The center diff and rear diff part are the same. onle difference is the ring gear. I ordered the correct ring gear to fit the locking diff part. Not sure if I'm missing any more part to complete the mods.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to nutechracingusa )
       Post #: 44
RE: Turnigy Titian 1/5 scale 4X4 - 1/23/2012 4:49 PM
cheezer1222
Score: 116
Status: offline
quote:
ORIGINAL: D_wilbur
I had time to work on the truck this afternoon. I did not order all the parts need to install the locking center diff. I installed the header the hole centers were off about 3mm. I drilled out the 2 holes to fit. The header and pipe don't fit the pipe is a about 1-1/2'' short. I will weld an extention to to make it work. The center diff and rear diff part are the same. onle difference is the ring gear. I ordered the correct ring gear to fit the locking diff part. Not sure if I'm missing any more part to complete the mods.
Do you think you'll need the nutech center drive cups, or do you think the stock ones will be compatible? I ask because bentley marshall had mentioned that as a possibility.
Hide Signatures
       Post #: 45
RE: Turnigy Titian 1/5 scale 4X4 - 1/23/2012 4:51 PM
nutechracingusa
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: D_wilbur
From the picture it looks like you have the splined drive cups for the center differential which will not work with the Nutech center locking differential, you will need the center drive cups as well part # 057536.
Owner Nutech Racing USA, US Distributor For Nutech and Hurrax
Hide Signatures
       Post #: 46
RE: Turnigy Titian 1/5 scale 4X4 - 2/1/2012 2:55 AM
D_wilbur
Score: 100
Status: offline
Received the center gear and drive cups from Nutec. I'm having trouble with to much end play with the locking diff. any one know where I can get some shims. Need 2 more to go in-between the bearing and the center diff. The other problem is with the stearing knucles. I ordered what I thought was replacment screws and bushing. the stock ones are 4 mm the new ones are much smaller and don't fit.I hope I don't have to buy new knuckles they are $100.00 for a pair plus the C hub. A $500.00 truck is turning into $800.00 fast.
Hide Signatures
       Post #: 47
RE: Turnigy Titian 1/5 scale 4X4 - 2/7/2012 3:20 AM
oskygt
Score: 100
Status: offline
A friend of mine ordered a mustang onroad car early january, still has'nt recieved it, everytime he calls, gets a runaround from them, i'm also waiting on a body in the same order, wont buy anything else from them, they suck.
Hide Signatures
       Post #: 48
RE: Turnigy Titian 1/5 scale 4X4 - 2/8/2012 3:17 PM
D_wilbur
Score: 100
Status: offline
Hello oskygt
sorry to here that you are having trouble. I have had excellent service from Nutech with my problems. They have called me to make sure that I was ordering the correct parts and have been very helpful. Hope things work out for you and your friend. My issue is that the Turnigy truck and Nutech replacement parts are not exactly the same and I have had to order more that I wanted to spend money on. but it's not Nutech fault. Turnigy does not sell any parts at this time. At least I can get parts.
Hide Signatures
(in reply to oskygt)
       Post #: 49
RE: Turnigy Titian 1/5 scale 4X4 - 2/8/2012 3:29 PM
mooman007uk
Score: 105
Status: offline
quote:
ORIGINAL: oskygt
so would have absolutely nothing to do with the mail service then eh?
Bringing hurrax to N.America & beyond.
hurraxracing.com
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.314RCU1
