This is my first work wildthing mono    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> This is my first work wildthing mono
Page: [1]
Login
This is my first work wildthing mono - 12/21/2011 7:31 AM
fthmrcn
Score: 100
Last Login: 5/20/2013
Status: offline
hi everyone,
I' m from TURKIYE. This my first message in this forum and the first works. I hope my works finish soon.
Fatih MERCAN
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Fatih MERCAN/TURKIYE
http://www.modelteknikleri.com
Hide Signatures
       Post #: 1
RE: This is my first work wildthing mono - 12/21/2011 7:39 AM
fthmrcn
Score: 100
Status: offline
I ordered motor, rudder,  trim tabs, 200 A esc and prop ø42 mm. But motor mount and turn fins are hand made . Shaft tube is broken. How can i bend shaft tube? if you have a new ideas please help me. thanks for all.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to fthmrcn)
       Post #: 2
RE: This is my first work wildthing mono - 12/21/2011 2:46 PM
clockworkclock
Score: 100
Last Login: 5/19/2013
Status: offline
Wow that hull looks great!
I must say that the motor looks awfully small for a boat of that size, the esc might end up destroying it because of how much power it can handle.
Could you elaborate on how your shaft tube is broken?
You can use a pipe bender to get a nice curve along the tube. I've seen people also bend it by packing it with salt/sand or whatever other small particles and then gently bending it by hand. You could also use a rubebr mallet if you are VERY careful. The sand/salt keeps the tube from colapsing.
Good luck with your build.
Clock.
If it isn''t capable of turning itself into shrapnel, it needs more power!
Hide Signatures
       Post #: 3
RE: This is my first work wildthing mono - 12/21/2011 3:01 PM
fthmrcn
Score: 100
Status: offline
 thanks. motor type is BL3650 3300 KV. Is it not enough this model? i will use 3S lipo for this motor. i will try ur recommends
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to clockworkclock)
       Post #: 4
RE: This is my first work wildthing mono - 1/31/2012 7:53 PM
fthmrcn
Score: 100
Status: offline
All the parts are ok.I need the batery. Turn fins are hand made. i will paint when the weather is good.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: This is my first work wildthing mono - 1/31/2012 9:22 PM
Goldenduff
Score: 114
Last Login: 5/23/2013
Status: offline
Could you fill tube with water, freeze it then bend it? The ice would stop it from buckling? I don't know if that would work but I do know that is how they put the bends in a trumpet!!!
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
       Post #: 6
RE: This is my first work wildthing mono - 2/1/2012 5:58 AM
fthmrcn
Score: 100
Status: offline
 Thanks friend. i will try a new one.
Hide Signatures
(in reply to Goldenduff)
       Post #: 7
RE: This is my first work wildthing mono - 2/1/2012 11:25 PM
Uncle Vinnie
Score: 106
Last Login: 12/16/2012
Status: offline
You can give this way a try:
http://www.offshoreelectrics.com/info-pages/bend-brass-tubing.php
Or you can buy something like this:
http://hobby.dubro.com/videos/tech-tip-videos/tubing-benders_18
Here is a better one:
http://www.princessauto.com/pal/product/2910677/Tube-Benders/Tubing-Bender
Hide Signatures
       Post #: 8
RE: This is my first work wildthing mono - 2/2/2012 5:09 AM
Tundrahog
Score: 100
Last Login: 3/18/2013
Status: offline
Did you try to anneal the tube? Heat the bend area with a propane torch until it dis-colors. Let it cool. Then bend it. The anneal process will make the bend area softer and easier to bend.
Hope this helps.
John
Hide Signatures
(in reply to Uncle Vinnie)
       Post #: 9
RE: This is my first work wildthing mono - 2/13/2012 6:48 AM
fthmrcn
Score: 100
Status: offline
No i didnt yet. The weather is very cold. I cant work on the mono. Thanks man
Hide Signatures
(in reply to Tundrahog)
       Post #: 10
RE: This is my first work wildthing mono - 3/5/2012 10:54 AM
fthmrcn
Score: 100
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: This is my first work wildthing mono - 3/7/2012 3:15 AM
clockworkclock
Score: 100
Status: offline
That bend looks pretty sharp, if you can work that bend over a longer stretch of the pipe I`m sure you will find it far superior.
Also, could you please specify the length of your hull?
Also, back to the motor, from what I understand those BL 3650 signify 36mm diameter and 50mm length.
I think a relatively inexpensive upgrade would be a tacon, you can pick up a good one here : http://www.hobbypartz.com/96m811-36741300kv.html
same diameter but 2.4cm longer.
2400watts.
unfortunately this one does not come with a watercooling jacket so you would have to get something made or find one for this online somewhere.
good news is that this will give you way more power.
Clock.
Hide Signatures
       Post #: 12
RE: This is my first work wildthing mono - 3/9/2012 8:14 AM
fthmrcn
Score: 100
Status: offline
  Thanks for your comments. I changed angle of tube bend. The lenght of my hull is 750 mm. My friend is the use same motor. He hasn't got any problem.  Maybe cooling is not enough but i can a new one cooling system
Hide Signatures
       Post #: 13
RE: This is my first work wildthing mono - 3/9/2012 3:13 PM
Mikeup
Score: 105
Last Login: 5/13/2013
Status: offline
3650 3300 is a Turnigy inrunner annd i run mine on 2S with a 4 pitch prop like a  carbon fiber 440. Stuffing tube should be just alittle less bend except the stringer could use  a hair negative angle. Get a adjustable stringer or strut to the lenght of 72mm. Have 1 strake set extend right up to transom about 2" or 50mm down from keel. Sand strake flat to keel.
Hide Signatures
       Post #: 14
RE: This is my first work wildthing mono - 3/10/2012 4:25 AM
martno1fan
Score: 221
Status: offline
Bending brass tube is easy,install flex and bend by hand,never kinked a tube ever using this method.Do not heat brass tube to bend you will weaken it and it is not needed,its soft brass not steel.Also this hull does not need strakes it has enough lift as it is,what it does need however are spray rails at the chines which you havent done,this stops water running up the side of the boat causing drag.In the plans it shows to overlap the bottom with the sides then your suposed to leave a little overhang and shape this to form spray rails,this makes water disperse and the boat runs faster.
Mart
heres the one my 15 yr old son built for his school course work.
Click for fullsize
Click for fullsize
Click for fullsize
waveridermouldings
Hide Signatures
       Post #: 15
RE: This is my first work wildthing mono - 3/27/2012 3:05 PM
fthmrcn
Score: 100
Status: offline
  I made tube bender for ø5-6-7 mm brass tube. I will try tonight. I am going to share results again.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to martno1fan)
       Post #: 16
RE: This is my first work wildthing mono - 5/7/2012 7:23 AM
fthmrcn
Score: 100
Status: offline
Mono hull is painting..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: This is my first work wildthing mono - 5/8/2012 1:54 PM
fthmrcn
Score: 100
Status: offline
 New color...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 18
RE: This is my first work wildthing mono - 5/9/2012 7:18 AM
fthmrcn
Score: 100
Status: offline
 pictures...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 19
RE: This is my first work wildthing mono - 5/13/2012 6:28 AM
capnswanny
Score: 100
Last Login: 5/21/2013
Status: offline
Very nice boat..I admire all the hard work you've put into her. My son and I recently bought an old wild thing hull at a swap meet and converted it to fe.. Last weekend was our first run. The boat handled amazingly! Ours is 32 inches (813mm) and my 9 year old son is piloting in this video clip http://m.youtube.com/watch?v=FGDTURvjoVA
we are running an Ammo 2300 motor, aquacraft 60A ESC, 42mm prop, and all Spartan hardware on the transom. I have the throttle turned down on his TX in the clip, flat out it really moves. I think you picked a great hull...and darn sexy!
Good luck with your build!
Hide Signatures
       Post #: 20
RE: This is my first work wildthing mono - 5/17/2012 7:21 AM
fthmrcn
Score: 100
Status: offline
 pictures.........
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to capnswanny)
       Post #: 21
RE: This is my first work wildthing mono - 5/28/2012 11:19 AM
fthmrcn
Score: 100
Status: offline
http://www.youtube.com/watch?feature=player_embedded&v=zuEqTTj9gmU
Hide Signatures
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.514RCU1
