Unleaded or Diesel Engine for a TMaxx?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Unleaded or Diesel Engine for a TMaxx? Page: [1]
Login
Unleaded or Diesel Engine for a TMaxx? - 12/22/2011 8:59 PM
Exceptions1187
Score: 100
Last Login: 6/13/2013
Status: offline
Soooo im sick of paying 32 bucks a gallon for nitro and ive seen 2 stroke unleaded rc engines before but i dont know if there is a conversion kit for a tmaxx... Like a engine, engine mount, extra modifications and stuff
_____________________________
If it doesnt run..Its not mine
Hide Signatures
       Post #: 1
RE: Unleaded or Diesel Engine for a TMaxx? - 12/22/2011 9:07 PM
1QwkSport2.5r
Score: 155
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: Exceptions1187
I havent seen many (though there are some out there) gasoline engines small enough to fit a normal 1/8th or 1/10th scale truck. Most small gas engines that I've come across have been 15cc (.90ci) or larger, and they were for airplanes.
I get around paying $34-$36 a gallon by making my own fuel. I can mix 20% nitro/12%oil fuel for about $20 a gallon or a little less. 100% pure nitromethane is roughly $42 a gallon.
I can make airplane fuel for $8-$12 a gallon at 5% nitro/20% oil.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Exceptions1187)
       Post #: 2
RE: Unleaded or Diesel Engine for a TMaxx? - 12/22/2011 9:36 PM
pyromatic177
Score: 255
Last Login: 4/18/2013
Status: offline
This way works the best, you ready for it........Get Electric...LOL
but i have a t-maxx and the gas is expensive!!
!!!Bash Like There''s No Repair Bills!!!
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 3
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 2:13 AM
maxidodies
Score: 100
Last Login: 10/28/2012
Status: offline
No conversion kits, but it could make a fun DIY project if you took an old small weedwacker engine and tried to mount it to your maxx. It has been done before. If you really want gas, maybe look into a used Baja 5B. You could probably find one used for 700$.
Hide Signatures
       Post #: 4
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 1:04 PM
phmaximus
Score: 632
Status: offline
those little 4 stroke motors u are thinking of are expensive, dont rev, and are very under powered compared to the stock motor.
It will make ur Tmaxx heaps slower...not really a upgrade when u compare it to a electric conversion.
It has been done before but its nothing fast, those motors are ment for slow flying planes where the owner wants a more scale sound
Best bet, keep paying or convert to electric
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to maxidodies)
       Post #: 5
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 1:32 PM
controlliner
Score: 100
Status: online
"100% pure nitromethane is roughly $42 a gallon." There is no such thing.... Nitromethane has a minimum of 2% methanol in the product as a stabilizer. You have to find the exact % and work it into your math when you mix.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to phmaximus)
       Post #: 6
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 1:57 PM
Mclovin350z
Score: 115
Last Login: 8/9/2012
Status: offline
Go diesel! I'm sure you could find a little 3 cylinder somewhere.
Losi xxl, Picco 26 t-maxx 4907, Sirio s27 revo, revo 2.5 with modded 18tm, EMBE, mostly stock 4908 maxx, pos mini lst2.
Hide Signatures
(in reply to controlliner)
       Post #: 7
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 3:04 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: controlliner
''100% pure nitromethane is roughly $42 a gallon.'' There is no such thing.... Nitromethane has a minimum of 2% methanol in the product as a stabilizer. You have to find the exact % and work it into your math when you mix.
That statement came from Torco Fuels. They sell "100% pure nitromethane" for $42 a gallon. I have no way of proving one way or another what the actual percentage is... Just going off of what the company claims.
The stuff I've been using is an 80/20 Nitro/Methanol mix from FHS, but its almost $20 more expensive than the Torco stuff.
Hide Signatures
       Post #: 8
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 3:09 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Mclovin350z
Davis Diesel Development makes conversion diesel heads for glow engines, but the fuel is just as expensive or more unless you make your own.
If one could find a ringed car engine of appropriate displacement, it could be converted to gasoline. Some airplane guys convert big .90ci ringed engines to gas. The conrod needs needle bearings installed to use less oil, otherwise one still has to stick with standard oil content.
Also to note: Gasoline burns a good bit hotter than methanol. Model diesels run cooler, maybe cooler than a glow even.
Hide Signatures
(in reply to Mclovin350z)
       Post #: 9
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 5:26 PM
Mclovin350z
Score: 115
Status: offline
Yeah I was just joking anyway. The only practical way out of nitro is to give up entirely and go electric.
Hide Signatures
       Post #: 10
RE: Unleaded or Diesel Engine for a TMaxx? - 12/23/2011 9:27 PM
pyromatic177
Score: 255
Status: offline
yeah thats the easiest
Hide Signatures
       Post #: 11
RE: Unleaded or Diesel Engine for a TMaxx? - 1/4/2012 8:09 PM
Exceptions1187
Score: 100
Status: offline
Thanks guys for the reply any one know how much a electric con is xD
Hide Signatures
(in reply to pyromatic177)
       Post #: 12
RE: Unleaded or Diesel Engine for a TMaxx? - 1/4/2012 8:44 PM
LaTuFu
Score: 275
Last Login: 8/31/2012
Status: offline
Buy a Revo or EMaxx roller on ebay/craigslist.  ERBE rollers are $200-$300 depending on the condition and how much is included.
Pick up a 150a ESC/Brushless Motor combo from Hobbypartz, +/- $200
LiPo batteries, $30-$50 each (you will need 2, 2s 30c 5000 mAh minimum specs)
LiPo charger, $50ish
Somewhere in the $500-$600 range.
Or less, if you are patient and go the Craigslist/RCTech route and get everything used.
Like the Thunder Tiger MT4 G3? Check it out on wondertiger.com
Hide Signatures
       Post #: 13
RE: Unleaded or Diesel Engine for a TMaxx? - 1/4/2012 8:59 PM
pyromatic177
Score: 255
Status: offline
hey thats what im doing
Hide Signatures
(in reply to LaTuFu)
       Post #: 14
RE: Unleaded or Diesel Engine for a TMaxx? - 1/6/2012 4:33 AM
oldbugs
Score: 100
Last Login: 6/12/2013
Status: offline
I've had a classic maxx, then moved up to a 3.3 maxx. I got tired of the constant tuning and fussing with it so I bought an HPI 5B, liked it so much I bought a 5T. What do I have now??? Sold it all for a bad azz brushless E-maxx with a Novak HV Pro set-up. I gotta say... on 4s, it's just as awesome (and fast) as all the others but without the noise or mess. Kelly
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
