RE: New OXAI CITRIN by Wolfgang and Roland Matt    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: New OXAI CITRIN by Wolfgang and Roland Matt
Page: <<   < prev  1 2 3 4 [5]
Login
RE: New OXAI CITRIN by Wolfgang and Roland Matt - 1/18/2013 10:10 PM
andreyengin
Score: 100
Last Login: 5/19/2013
Status: offline
Another photo of Citrine with a brocken nose, happened on the world cup in a Chech Haven,on line 45 upwards a motor fly out  from fuse and flew away,motor was without back support Motor is Q-80
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to NicolasG)
       Post #: 101
RE: New OXAI CITRIN by Wolfgang and Roland Matt - 1/19/2013 3:32 PM
najary
Score: 100
Status: offline
quote:
ORIGINAL: andreyengin
In my opinion the is no need for a rear support to the Q-80.
In some modeles you my need to reinforce the nose like I did in my Xigris, see post 300.
http://www.rcuniverse.com/forum/m_9305653/mpage_12/key_/tm.htm
Best regards,
Isaac Najary
Hide Signatures
(in reply to andreyengin)
       Post #: 102
RE: New OXAI CITRIN by Wolfgang and Roland Matt - 1/19/2013 7:33 PM
andreyengin
Score: 100
Status: offline
Yes,the best way to reinforce nose with carbon for Q-80 they have a lot power and gyroscopic efekt ,but with rear suport better.For Hacker С-50 sufficiently thickness nose.
I am looked in three my friends, the same situation nose of airplane(other f3a models) with Q-80 brocken,after of strengthening of nose and install of back support  fly until now.
Hide Signatures
(in reply to najary)
       Post #: 103
RE: New OXAI CITRIN by Wolfgang and Roland Matt - 5/14/2013 4:53 PM
adrielmesias
Score: 100
Status: offline
Hi guys,
I just finished my Citrin and maidened it. It is really a great flying plane, nice and relaxed flight but the aggresive side is there when you need it. The only issue I have is that it is quite a lot tail heavy, if I use batteries such as the lightest TP4400, it surely won't balance out. I'm usinh the hacker C50-13XL. Any suggestions?
Regards,
Adriel Mesias
Hide Signatures
       Post #: 104
RE: New OXAI CITRIN by Wolfgang and Roland Matt - 5/15/2013 7:03 PM
cartercg
Score: 100
Last Login: 5/16/2013
Status: offline
Hi Adriel,
That is not surprising. With a light motor, spinner and prop you will struggle to get the CG forward to the recommended spot using a light flight battery. You need to get everything as far forward as you can. That is all you can do, and if the CG is still too rearward then consider using a heavier prop.
I installed my Rx and switch as far forward as I could, and have the Rx battery right next to the motor. Even with a 1130g flight pack the end of the pack is within 3cm of the back of the motor.
Regards
Clint
Hide Signatures
(in reply to adrielmesias)
       Post #: 105
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
