RE: Spitfire Brotherhood (All Spitfires Welcome)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Spitfire Brotherhood (All Spitfires Welcome)
Page: <<   < prev  24 25 [26] 27 28 29 30 31 32 33   next >   >>
Login
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/21/2012 2:46 AM
jet22b
Score: 110
Last Login: 5/25/2013
Status: offline
Looking very good!! Please keep the pictures comming!!!
Sonny
aka
jet22b
_____________________________
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
(in reply to TA152)
       Post #: 626
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/21/2012 5:12 AM
more10cc
Score: 100
Status: offline
This is my yellow spitfire.
http://low-guns.blog.so-net.ne.jp/archive/c2302904937-1
Toshi
Hide Signatures
(in reply to TA152)
       Post #: 627
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/21/2012 11:14 PM
moto-x
Score: 100
Status: offline
I was able to maiden the Pica spitfire last friday.The DA 50 was plenty of power for 26 lbs. As I was running down the runway I was thinking nose over so I had held a little up in the elevator. Well at about 5/8ths throttle and half way down the runway she started to lift off. Not enough speed so she started to wag back and fourth. I poured on the gas and climbed out to a good altitude and made my turn. Once she went stable I was able to relax a little. Had a six minute flight and decided to come in. Sat down a bit hard and the oleos dropped all the down. Popped one of my wheel skirts but other than that no damage. Next flight I will bring her in with a bit more speed. Its all worth it when a plan comes together.
It's about to get real ugly.
Hide Signatures
(in reply to more10cc)
       Post #: 628
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/21/2012 11:37 PM
lovehydro
Score: 100
Last Login: 5/24/2013
Status: offline
MOTO-X
Were is your CG. There is so many answers to were the CG should be on these PICA Spits.
lovehydro
Hide Signatures
(in reply to moto-x)
       Post #: 629
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/22/2012 1:24 AM
jet22b
Score: 110
Status: offline
moto-x;
When I starting reading your post, my heart start pounding!! I have seen more warbird and or any plane come off of the ground before its time and the end is not good! Very good save on your bird and the maiden flight. Sorry about the landing!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 630
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/22/2012 4:32 AM
albsurfer
Score: 100
Status: offline
Moto-X, glad you got the maiden done. Congrats.
Hide Signatures
(in reply to jet22b)
       Post #: 631
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 12:40 AM
markhamregular
Score: 111
Last Login: 5/22/2013
Status: offline
I have an H9 Spitfire 60. I have a problem with the flaps. They are under the wing and mine are a little hard so the servo is binding all the time. I am using a standard 3003 Futaba. Can I fix the problem by installing a high torque servo? Anyone having the same problem?
What''s rudder?
Hide Signatures
(in reply to albsurfer)
       Post #: 632
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 2:15 AM
moto-x
Score: 100
Status: offline
Im at 5 inches from the leading edge at the fuse. when rolled inverted, it took very little down input to stay level. Thats right where I like it.
Hide Signatures
(in reply to lovehydro)
       Post #: 633
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 6:52 AM
albsurfer
Score: 100
Status: offline
quote:
ORIGINAL: markhamregular
markhamregular,
what do you mean by "... a little hard..."? Do mean they are stiff? If so, is it because of the CA Hinges being stiff? What did you use to glue them in?
Mine are OK, but if you try to extend the two flap arms full open as far as they will travel, it is difficult to get them to go to that position. The flap arms don't need to go full throw to work fine. If they are binding because the flap arms don't go full throw, you can cut a little balsa out of the wing in the arm slot for more travel. If you CA'd the hinges and they are binding, you may have to remove the CA from the bad flap and then re-glue it.
Hide Signatures
(in reply to markhamregular)
       Post #: 634
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 1:38 PM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: more10cc
Toshi
Good job on the repairs there Toshi. Now, do tell, is that the static spinner for the kit converted to a flying spinner?
This is what I have done with mine and yours looks very similar.
Cheers,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
       Post #: 635
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 3:41 PM
markhamregular
Score: 111
Status: offline
Albsurfer,
I used hinge gel as the manual request. I have it on a switch because it was very difficult on a knob.
Although I have it to go only about 50%, it still makes the buzzing sound continously.
Someone told me to use alcohol on the hinges, but I am not sure if the alcohol will affect the hinges.
What''s rudder?
Hide Signatures
(in reply to Brad330l)
       Post #: 636
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 4:22 PM
more10cc
Score: 100
Status: offline
Hi Brad
I use aluminum spinner when fly.
Toshi
Hide Signatures
       Post #: 637
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 4:28 PM
jet22b
Score: 110
Status: offline
Albsurfer,
markhamregular,
Remove the rod from the horn on the flaps and see if the buzzing stop. If it does, the servo was not at the end of it throw. I have the H9 Spit and I had to play with the rod length to stop the servo buzzing. Also play with your flap servo ATV's Please post and let me know if this help!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 638
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 5:49 PM
markhamregular
Score: 111
Status: offline
Jet22b
I did thatalready. No buzzing when I take off the rod. I centralize the servo and I tried to place the horn in different positions, but it buzzes on all of the positions, like it can only go just a little bit, anything over 10 degrees, and it start buzzing.
What''s rudder?
Hide Signatures
       Post #: 639
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 6:09 PM
lovehydro
Score: 100
Status: offline
Thanks moto-x. I have so many conflicking Cg's.
lovehydro
Hide Signatures
       Post #: 640
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 8:37 PM
jet22b
Score: 110
Status: offline
Jet22b
I was just in my workshop looking at my H9 Spit wing and remember one thing to stop the servo buzz. The hangar 9 setup on the flaps, one servo move both flaps, as you know, and it was a pain in the "A" to get the clevises the right amount of turns. I found the right flap rod was not the same lenght as the left one. So I had to play with the turns on the clevises to stop the buzz. Now here come the fun part, hook up one side at a time and see if that side buzz. If not, hook up the other side and see what happen. If that side buzz, play with the turns on the clevise to stop it.Then hook up both side and see if the buzz come back. Also check that both flaps come down equally. I know the next H9 Spit will get two flaps servos setup.
I hope this help, but to tell you this plane land very good with not flaps.
Sonny
aka
jet22b
Hide Signatures
       Post #: 641
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 10:44 PM
moto-x
Score: 100
Status: offline
Yes there are. I had read many post on the correct c/g and thought I would just use the one I had read worked the best. It is not fun at all to maiden a unbalanced airframe. I have several with not good results. I am totally satisfied at 5 inches though. I hope it works for you.
Hide Signatures
       Post #: 642
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/23/2012 11:44 PM
Lifer
Score: 148
Status: offline
Mine had the same problem; buzzing servo. I simply used an old 180 degree retract servo with a 1/2 inch arm. No proportional flaps, but no buzzing or stalled servo drain.
Hide Signatures
       Post #: 643
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 12:33 AM
lovehydro
Score: 100
Status: offline
Thanks, I will set mine for the 5" also.
lovehydro
Hide Signatures
       Post #: 644
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 12:42 AM
lovehydro
Score: 100
Status: offline
It is probably time to up date the brotherhood on my progress, I have posted several photos of the rebuild on this plane a couple of months ago. Here is the painting photos. I am waiting for my dry transfers from 'GetStencles' right now. Vicky at Get Stencles is wonderful to work with, I highly recommend her for your graphics. I am doing the east asian MK XIX Spit with the black Panther on the side and her work is wonderful. After I get it cleared and the balance of the weathering, I will post some more.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 645
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 12:45 AM
lovehydro
Score: 100
Status: offline
Here are some more photos
lovehydro
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 646
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 12:47 AM
lovehydro
Score: 100
Status: offline
Just more phots, I know I like seeing photos on this thread.
lovehydro
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 647
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 1:03 AM
WARBIRDRCER
Score: 118
Status: offline
The plane is looking great!
Steve - Flight Leader - Warbirds Over Oklahoma
Spitfire & P-40 Brotherhood #1
Hide Signatures
       Post #: 648
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 2:38 AM
mistermnkim
Score: 100
Status: offline
Just picket up a PICA Spitfire!! would love to join the brotherhood!! I plan to use a MOKI 1.8 I have on hand what do you guys think? She feels very heavy hope its enough! Ill try to load a pic if rcu will allow tonight...
club saito #625 CG Ultimate brotherhood #19 SPITFIRE brotherhood #91
Hide Signatures
(in reply to WARBIRDRCER)
       Post #: 649
RE: Spitfire Brotherhood (All Spitfires Welcome) - 5/24/2012 3:17 AM
DGUY
Score: 115
Last Login: 4/5/2013
Status: offline
JORDY200,
You have one fine plane.
Spitfire Brotherhood #28
AMA # 919758
Hide Signatures
(in reply to TA152)
       Post #: 650
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
