RE: Spitfire Brotherhood (All Spitfires Welcome)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Spitfire Brotherhood (All Spitfires Welcome)
Page: <<   < prev  57 58 [59] 60 61 62 63 64 65 66   next >   >>
Login
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 3:38 PM
OldScaleGuy
Score: 120
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: WARBIRDRCER
The only concern I would have is additional weight.
How are you finishing the model, because that may effect your sheeting choices.
Weight is always a concern, i guess this will be a wait and see when we get into the builds.
Good question on the finish. My son's will be built for scale competition, mine will be built for everyday flying. Obviously C.O. will need to paint his. I am still on the fence whether to paint or use film. The goal is to have the two very similar so the flying characteristics are as close as we can get them. That being said, i may end up painting as well. Neither of us have engines yet, we are still discussing that point. Any suggestions are greatly appreciated.
_____________________________
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to WARBIRDRCER)
       Post #: 1451
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 4:46 PM
ARUP
Score: 134
Status: offline
Incrementally ballast the every day fighter to resemble the heavier one in order to gain experience with anticipated higher wing loadings.
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 1452
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 6:03 PM
Phat Reliant
Score: 100
Status: offline
quote:
ORIGINAL: OldScaleGuy
After reading about the weak sheeting, I am thinking about using additional sheeting on the undersides (between ribs) on the high contact areas. Will also be painting rather than covering, and using Solartex (or similar) on the control surfaces.
Spitfire Brotherhood #126
Hide Signatures
       Post #: 1453
WARBIRDRCER
Score: 118
Last Login: 5/20/2013
Status: offline
I am thinking you are considering fiberglass for the one to be painted, although I have a friend that details out and paints monokote and many ask if they were glassed. That being said, if glass is the method, then the thinner sheeting is not an issue.
Concerning the other method, once the wing is monokoted it adds strength, but a person just needs to treat it as an open bay wing and be careful how they are ground handled.
Concerning the like flight characteristics, as stated, you can add ballast over the CG and equal the wing loading.
Concerning the weight, I have found weight is less of a factor on them when with-in reason. Some actually fly and land better with the added weight once a person learns to land with additional speed as opposed to the standard sport plane landing speeds.
Once I had a re-re-re-repaired; does that make since, Dave Platt T-28 that weighed in at 17 pounds and flew on an Evolution 26 gasser. It landed like a low altitude military drop without excessive speed to touchdown.
As for the powerplant selection, I like the DLE-20’s for gas on these size birds, and the YS110 Sports for glow. The reason for the YS selection is I do not have to be concerned about fuel tank position because of the YS pressure system. However if fuel tank position is not a factor then any quality glow engine with enough power is fine.
Steve - Flight Leader - Warbirds Over Oklahoma
Spitfire & P-40 Brotherhood #1
Hide Signatures
(in reply to ARUP)
       Post #: 1454
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 6:04 PM
DougB1
Score: 112
Last Login: 5/21/2013
Status: offline
Hey guys I have a chance to buy a Yellow aircraft Spitfire that has everything included in it. The only draw back ( if you want to call it that ) is it has a Super Tiger 3200 in it. As far as the plane has anyone had one and what should I expect.
DougB1
Hide Signatures
(in reply to ARUP)
       Post #: 1455
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 6:18 PM
jet22b
Score: 110
Status: offline
Steve & Steve;
One thing I don't know is how long the kit sat in Tower warehouse before I pick it up from them!! I sit down and went through all the wood as I lay out the parts. When I got to the wings sheeting, the wood look bad, like it was un-finish. I pick out the best plank to make the sheeting. Where I had problem at, was the center sheeting. I did the bottom first and let that dry over night. The next day, I went to turn the wing over so I could sheet the top of the wing center section, as soon as there was any weight on the sheeting, I heard cracking!!! Where I had my finger at, ( LE & TE ), there was a crack. One thing we don't know is the shelf life balsa wood. There was a guy on eBay that sold a 40 year old Red Box Top Flite P-51.
I would love to know how that wood held up after sitting on the shelf for so long!! Now if are going to glass the wings like I will be doing, than I say go with the stock sheeting and be careful how you handle the wings. Now if you are going to use film to cover the model, I would go with the 3/32" balsa sheeting. It may add some weight, but, I don't think you will hear that cracking sound!! I hope this help on your build!!
Merry Xmas, Brothers!!!
Sonny
aka
jet22b
P-40 Brotherhood #52
Hide Signatures
       Post #: 1456
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 6:47 PM
Moggy
Score: 100
Last Login: 3/22/2013
Status: offline
Doug
Get rid of the Super Tiger and put in a 50cc gasser or G62. I have had nothing but problems with the big Tigers and lost planes with flame outs; the older ones in particular. Go to the Complete Yellow Spitfire thread here and you will get all the information you need to successfully build and fly a great airplane. I have two, one with a G62 and one with a 3W60. You will need ballast up front so it might as well be engine. Best of Luck!!!!
Moggy
Piece of Cake
Spitfire Brotherhood #121
Hide Signatures
(in reply to jet22b)
       Post #: 1457
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 6:54 PM
OldScaleGuy
Score: 120
Status: offline
I agree with Moggy on the engine choices for you YA Spitfire. A buddy of mine has had 2 of them and in both planes he has used Moki 1.8's. They fly ok but no extra power. The only way i found to be successful with the big ST's was with an OS 7D carburetor and an in flight needle valve control.
Hide Signatures
(in reply to Moggy)
       Post #: 1458
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 7:59 PM
Duplicator41
Score: 100
Status: offline
Run the S.T. on a test stand and see how it does, use a 18 x 8 or 18 x 6-10 prop and 5% fuel. Use either an O.S. F glow plug or a #8 plug. The suggestion to use an O.S. 7D carb with the insert removed is very good. (more power and a good idle) I use a McDaniel on board glow on my big inverted S.T.'s so no flame outs. A G62 is a great engine, but you'll have to hack up the nose on the Spitty to get it in. Having said all that, as long as the weight is around 25-28 lbs. it will fly just fine as long as the S.T. is in good shape.
So many planes, so little time
Hide Signatures
(in reply to DougB1)
       Post #: 1459
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 8:45 PM
Prekin
Score: 101
Status: offline
Hi all,
after some time, which I spent by thinking what will be my next project, I decided for the Brian Taylor Spitfire 83". Maybe I would built Mk VIII and Mk IX, because I don´t now which one is nicer.
No I´m in the drawing stadium. I have to draw the all ribs of the wing and fuselage, because I want to do it by CNC laser.
Does anybody know which one cockpit kit and pilot fit best for this Spitfire?
I also thinking about the paint scheme, does anybody know some good one? Here are some my candidates.
Prekin
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Duplicator41)
       Post #: 1460
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 9:13 PM
jet22b
Score: 110
Status: offline
Hi Prekin;
My vote is for the P-40 look!! I remember I was one website that had pictures of the Spitfire, ( can not remember what site it was ), and I said you put a P-40 in with the Spitfire. Now looking at one of your paint scheme candidates, what I saw was a Spit!!! I may have to go that route when I get ready to paint my TF Spitfire!!!
Sonny
aka
jet22b
Hide Signatures
(in reply to Prekin)
       Post #: 1461
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 9:16 PM
Moggy
Score: 100
Status: offline
Prekin
Bob Holman will laser cut all the ribs and he is very accurate, this will save you a tremendous amount of time. As far as paint schemes, that's the beauty of the Spitfire due to the many different schemes available. It's your choice.
Piece of Cake
Hide Signatures
       Post #: 1462
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 9:31 PM
Prekin
Score: 101
Status: offline
I know, that I can buy some kit and all the ribs, but there are three points.
1) I have to draw it, because it is my semestral homework.
2) When I draw it in 83" wingspan, I can cut it at my school department.
3) If I want to cut it at my school department, I have to build one wing in the real scale. This is a challenge for me!
We´ve just had one damaged Merlin engine, so I hope, that I add one wing
Hide Signatures
(in reply to Moggy)
       Post #: 1463
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 9:53 PM
glazier808
Score: 291
Status: offline
quote:
ORIGINAL: Prekin
Hi all,
after some time, which I spent by thinking what will be my next project, I decided for the Brian Taylor Spitfire 83''. Maybe I would built Mk VIII and Mk IX, because I don´t now which one is nicer.
Prekin
PM Chad Veich here on RCU. He has a cockpit kit that has to be seen to believe....I'm quite sure he has a shrink ray....lol
It's by far the nicest cockpit kit out there.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 1464
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/8/2012 10:31 PM
vasek
Score: 147
Status: offline
Hey Perkin, how are things... my vote goes to the Grey Nurse paint scheme
Cheers, Vasek
Remember: Speed is life!
Hide Signatures
(in reply to glazier808)
       Post #: 1465
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 12:57 AM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: glazier808
quote:
ORIGINAL: Prekin
Hi all,
Prekin
Casey
You're right there Casey! (We both have one[ ]) It was however designed for the fiber glass fuselage so will apparently need a few modifications to get it in a built up one.
Sure Chad will comment on fit.
Cheers,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
       Post #: 1466
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 2:26 AM
WARBIRDRCER
Score: 118
Status: offline
RPRCBuilder is on the move
Click for fullsize
Click for fullsize
< Message edited by WARBIRDRCER -- 12/9/2012 3:02 AM >
Hide Signatures
(in reply to Brad330l)
       Post #: 1467
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 2:39 AM
glazier808
Score: 291
Status: offline
Good to see you Brad! I've pushed my Spitfire build back until I get moved back to Hawaii. It's killn me lol...
I keep forgetting to weigh those 109 wheels, I will I promise!
Casey
Hide Signatures
       Post #: 1468
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 2:58 AM
FireBee
Score: 100
Last Login: 5/22/2013
Status: offline
DougB1, Go for the spit. Then like others said, your best long term solution is a 50-60 gas. My first spit (Pica 88") at 25 lbs had a super tiger 3000. Flew good scale speed etc. top of loops was a little critical. Then I put a Brison 3.2 ( 52cc) and it was then a true warbird large loops and faster fly bys.
My buddy (AeroFalcon) has a full tricked out yellow spit mk-14 with a DA-50. It never misses a beat. Good top end speed, all maneuvers are crisp and lands like on rails.
R, mike
Mike P.
Hide Signatures
       Post #: 1469
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 3:05 AM
FireBee
Score: 100
Status: offline
Prekin, your project sounds great.
Do not pick this one, it is my future Spit mk-IX.
Click for fullsize
Mike P.
Hide Signatures
(in reply to FireBee)
       Post #: 1470
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 5:21 AM
tclocs
Score: 100
Last Login: 3/19/2013
Status: offline
http://www.youtube.com/watch?v=9F6xhgDV3VA[youtube]
Not the maiden but finallt got some video of it. Enjoy !!!
Hide Signatures
       Post #: 1471
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 5:53 AM
jet22b
Score: 110
Status: offline
#1,
RPRCBuilder is doing a great job. The wings look good. Please let us know if he has any problem with the sheeting being to thin!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1472
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 7:44 AM
Prekin
Score: 101
Status: offline
OK FireBee, I will think about it and I will choose another one!
Hide Signatures
       Post #: 1473
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 11:33 AM
lovehydro
Score: 100
Status: offline
Here is the best 1/5 scale cockpit I knoq for a Spit. http://www.t-birds.be/products/cockpit.htm
Here is the MK19 I have built.
lovehydro #39
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1474
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/9/2012 11:56 AM
Prekin
Score: 101
Status: offline
Thank you very much. This cockpit looks good.
I saw this Spitfire together with FW-190. It was las summer on Aviation Fair.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to lovehydro)
       Post #: 1475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
