RE: Spitfire Brotherhood (All Spitfires Welcome)    Gallery
Logged in as Guest
Users viewing this topic: goalie40, facia, jet22b
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Spitfire Brotherhood (All Spitfires Welcome)
Page: <<   < prev  63 64 [65] 66 67 68 69 70 71 72   next >   >>
Login
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 1:59 PM
WARBIRDRCER
Score: 118
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: facia
Nice progress on the build RPRCBuilder.
It's looking real good.
I am making some progress with the rivets on my Hangar 9.
I am using the syringe method with canopy glue.
It dries opaque, let's the color of the monokote look through and is easy to apply.
If I make a mistake, I can wipe it off while it's wet or just peel it off when it's dry.
This is the first time for me doing anything like this and trial and error
is the name of the game.  Hopefully I am learning something for the next one.
It should look aok once I apply the flat clear.  Hope that it will protect the rivets that way as
well.
Unfortunately I am not able to get a hold of topflite flat clear here in Canada.  Somehow the LHS can't
import it, nor can I order it in from USA internet stores.  Some sort of freight issues.
So I am thinking about using Testors Dullcote which is available in the LHS.
Have any of the brothers got experience with this dull clear spray?
Andreas
Happy building and flying.
facia,
The rivets are really looking good. Be sure to post a photo when complete.
I am sure you have thought of this, but try some on a test part and see how it works. I have started painting with latex paint and have learned there is now flat clear latex. It is said you can paint latex over any other materials because it is water base.
I especially like the water cleanup. I use to spend along time cleaning my guns with expensive thinners, but now all water.
_____________________________
Steve - Flight Leader - Warbirds Over Oklahoma
Spitfire & P-40 Brotherhood #1
Hide Signatures
(in reply to facia)
       Post #: 1601
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 3:51 PM
Bob Pastorello
Score: 126
Last Login: 5/18/2013
Status: offline
Fellas - this plane looks like some ****-ized P-4o-sorta-P51 kinda like a Spitfire in the wrong "colors" (country).
Other than those things - is this a bona fide Spit ?  Would it work with a DL 30 RA ?  or not enough there?
Any and all comments appreciated.... http://thewingsmaker.com/airplane_details.php?name=Spitfire 160
It really shouldn''t be this hard....
Hide Signatures
(in reply to WARBIRDRCER)
       Post #: 1602
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 3:52 PM
facia
Score: 100
Status: online
 Thanks for the suggestion WARBIRDRCER,
I'll check out the local hardware store for a waterbase flat clear.
Brands like Minwax or Varathane come to mind.  Will give that a test try
and see.
If it doesn't work on my plane, I am sure that I will be using it on the
next kitchen corner bench project that my wife has for me.
Andreas
Spitfire Brotherhood #130
Hide Signatures
       Post #: 1603
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 3:57 PM
glazier808
Score: 291
Status: offline
For the money I would go with the smaller ESM Spitfire, your engine is about the right range as well. One thing is for sure...the ESM plane looks much better than that one. Although it is Spitfire like, it's pretty wrong.
Just my opinion...
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to Bob Pastorello)
       Post #: 1604
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 3:59 PM
glazier808
Score: 291
Status: offline
Facia, what's gonna happen the first time you need to tighten up the covering?
Casey
Hide Signatures
(in reply to facia)
       Post #: 1605
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/21/2012 6:47 PM
Phat Reliant
Score: 100
Status: offline
Bob,
This is also sold by the World Models as the GS 160 Spitfire. I had one of these and it is put together fairly well. I had it fitted out with a Moki 210 and Jtec wrap around muffler. The Canopy was awful looking and would have replaced it had I kept the plane
The Wing was good and sturdy and might have benefited from a little extra dihedral , 3 servo's in each panel: Aileron, Flap and Retract.
Covering needed only light touches and heat gun to shrink it back.
Tail feathers were Pull/Pull
Fuselage bottom, aft of the wing is flat...
Stab was also a problem being that it's shape appeared to be a mix of different marks.
It's sold as a Spitfire, the wing looks very good and the fuse not so, just looks like a cousin
Markings on the wing are post WWII, and on the fuse roundels of WWII - maybe they were trying for the Spiteful.....
For my money, I'd splash out on the ESM model
< Message edited by Phat Reliant -- 12/21/2012 9:21 PM >
Spitfire Brotherhood #126
Hide Signatures
       Post #: 1606
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/22/2012 5:00 PM
facia
Score: 100
Status: online
 Hi Casey,
I was wondering about that myself and did a test iron tightening on my scrap p51 fuslage.
It seemed to work.  That was with the testors dullcoat.  However, it was a test on monokote that
had been put onto balsa and due to age might not wrinkle or shrink much any more.
I have a scrap wing and I will use testors dull coat and satin varathane water base side by side.
This will show me what happens to unsuported painted monokote between the ribs when it shrinks.
It'll depend on the flexabliity of the applied clear coat.
Will see how that works.  If it doesn't, then I have the fun time of taking the rivets back off.
That, I did test and they come off without any markings on the monokote, as it is canopy glue.
I will give some updates once more testing has been done.
Andreas
Hide Signatures
(in reply to glazier808)
       Post #: 1607
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/22/2012 8:15 PM
DougB1
Score: 112
Last Login: 5/19/2013
Status: offline
WOW I made it into the brotherhood, number "155" Here are a couple of pictures of my Yellow Spitfire I got, I will have to replace the canopy and will take out the S.T. 3200 and put in a DL50 in it's place.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to facia)
       Post #: 1608
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/22/2012 8:23 PM
OldScaleGuy
Score: 120
Status: online
Hey Doug, we have a great field here in Seymour if you would like to bring up to fly it. I am sure you could use some help.....
Steve - Spitfire Brotherhood #144
Full size airplanes are real, our models are too.
Hide Signatures
(in reply to DougB1)
       Post #: 1609
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/22/2012 8:28 PM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: OldScaleGuy
Will be looking forward to flying it at different fields this summer. I'll bring Tevans55 and his Spitfire too.
Hide Signatures
(in reply to OldScaleGuy)
       Post #: 1610
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 2:27 AM
john josey
Score: 110
Status: offline
This is built from the DB kit, is 81" span powered by a zenoah g38 with stainless exhaust.
Click for fullsize
Hide Signatures
       Post #: 1611
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 6:32 AM
albsurfer
Score: 100
Status: offline
John,
that is a great looking Spitfire. Love the details like the gun ports..
Hide Signatures
(in reply to john josey)
       Post #: 1612
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 6:59 AM
mad web tv scientist
Score: 237
Last Login: 5/16/2013
Status: offline
[/quote]ORIGINAL: WARBIRDRCER
I know things are going to get busy very soon, so while it is on my mind; Merry Christmas everyone
[/quote]
Merry Christmas to you too, and to all of the Brotherhood! I think we all know exactly what your statement means this time of the year, but I can't help sharing what jumped into my mind when I first read it. Being the WARBIRD enthusiast that you are, I'm thinking you probably saw the movie, "The War Lover" staring Steve McQueen as the charismatic psychopath "Buzz Rickson." Anyway, it was that scene near the end of the movie where our hero was desperately busy trying to get his shot up B-17 to fly high enough to clear the "White Cliffs of Dover." I may have been somewhat influenced by a certain cliff that is getting close and closer according to the media. So, maybe turning as much contemporary reality as we can into an opportunity to enjoy WWII nostalgia can help us deal with the inevitable.
And as Happy a New Year as circumstances will allow compliments of Spitfire pleasures, to all!
Spitfire Brotherhood (All Spitfires Welcome) #64 - Post #407 - Battle of Britain & Winston Churchill relevancy to modeling - http://www.rcuniverse.com/forum/fb.asp?m=11007416 PLEASE SEE POST 852 (Page # 35) on Spit thread for FANTASTIC INFO. See why we fight - www.goodfight.com
____________________________________________________________________________________
FIGHTERS - AVIATION'S ULTIMATE CALL TO GLORY, HONOR, AND IMMORTALITY - http://community-2.webtv.net/RICHARDPORTER4/CALLTOGLORY/
_____________________________________________________________________________________
The following URL brings up the most concise, non-technical (with technical references) discussion about the revolutionary THORIUM PLASMA BATTERY technology I have found on the web. ENJOY! Oh what fun we are going to have in the future of flight!
http://www.ecocarforum.com/ev-forums/posts/rumours_news/thorium_plasma_battery_can_power_most_any_car_truck_train_or_boat_for_10_years_without_a_recha.html
''mad thorium batteries'' typed in Yahoo and/or Google brings up some great information about thorium plasma batteries.
Hide Signatures
       Post #: 1613
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 7:39 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: albsurfer
John,
Thank you for the very kind words....the gun ports are just two different sizes of brass tube, but quite effective.
Hide Signatures
(in reply to albsurfer)
       Post #: 1614
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 7:17 PM
jet22b
Score: 110
Status: online
john josey;
May I also say what a sweet looking Spit you have!!! Also good to have a Brother from the UK!! Welcome my Brother!!!
Sonny
aka
jet22b
P-40 Brotherhood #52
Hide Signatures
       Post #: 1615
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/23/2012 11:50 PM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: DougB1
WOW I made it into the brotherhood, number ''155'' Here are a couple of pictures of my Yellow Spitfire I got, I will have to replace the canopy and will take out the S.T. 3200 and put in a DL50 in it's place.
I like it.
Happy Christmas to all the brothers, (or holidays or whatever floats your boat) It is Christmas Eve here now and we had a big thunder storm come over last night guaranteeing a humid couple of days (read hot and humid) so while a lot of you will be shovelling snow I will be sweating my butt off. Hope you all get Spitfires for Christmas.
Cheers,
Brad
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
       Post #: 1616
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 12:02 AM
glazier808
Score: 291
Status: offline
Lol Brad,
Happy holidays to you too! Hope you enjoy your soggy Christmas!
Happy Holidays squadron, and all of RCU
Casey
Hide Signatures
(in reply to Brad330l)
       Post #: 1617
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 5:39 AM
john josey
Score: 110
Status: offline
quote:
ORIGINAL: jet22b
john josey;
Sonny
aka
jet22b
Thank you for the warm welcolm and a merry xmas and happy new year to you all !
Hide Signatures
(in reply to jet22b)
       Post #: 1618
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 7:42 PM
Prekin
Score: 101
Status: online
Hi all,
here is a small present for you. You can use it as a sticker (label) on your car or equipment box.
So Marry Xmas and happy new year!
Click for fullsize
Hide Signatures
       Post #: 1619
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 8:04 PM
jet22b
Score: 110
Status: online
Prekin;
Thank you!!! That will look good in the back window of my Ford Escape!!
Merry Xmas!!!
Sonny
aka
jet22b
Hide Signatures
(in reply to Prekin)
       Post #: 1620
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 8:41 PM
jet22b
Score: 110
Status: online
Brothers,
One quick question. As you well know, I am glassing my Spit and the cloth came today!!! What is a good epoxy resin to use?? The last time I did glass work was back in the late 70's!!
Thanks Brothers and Merry Xmas to all!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1621
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 8:47 PM
OldScaleGuy
Score: 120
Status: online
Most seem to be using Zap or West Systems. I have used Zap with good results. I have done some testing with Minwax Polycrylic and i believe when the time comes i will use Minwax.
Hide Signatures
       Post #: 1622
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 8:58 PM
vasek
Score: 147
Status: offline
quote:
ORIGINAL: Prekin
Hi all,
good job Perkin, you could make money making vanes and selling them, I had to get mine in the UK last year.
Click for fullsize
Remember: Speed is life!
Hide Signatures
       Post #: 1623
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 9:04 PM
OldScaleGuy
Score: 120
Status: online
quote:
ORIGINAL: Prekin
Hi all,
Or you could it on the wall in your workshop. Thanks Prekin.
Click for fullsize
Hide Signatures
       Post #: 1624
RE: Spitfire Brotherhood (All Spitfires Welcome) - 12/24/2012 10:12 PM
jet22b
Score: 110
Status: online
Thanks Brother Steve!!
I will look at all three. Now you see how long I been out of the loop!!!
Thanks again and Merry Xmas!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 1625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
