Shockwave turns off on full throttle    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Shockwave turns off on full throttle
Page: [1]
Login
Shockwave turns off on full throttle - 12/31/2011 10:43 PM
y2kcurt
Score: 100
Last Login: 12/31/2011
Status: offline
 New to RC cars and new to RedCat Shockwave. Set the gear mesh, tuned it (best I knew how), set the appropropriate carb setting (1mm), figured out charging/testing glow plugs, and broke in the engine per manufacturers recommendations, etc (most of it by trial/error)...however the one last thing that I cant seem to figure out is why when I run it at full throttle the engine dies on me? Engine stays running on full break and everything inbetween a full throttle, but once I max it out, it dies on me. I am sure it is an easy adjustment, but not exactly sure what to adjust.
Thanks in advance for your help
Signed, total noob
Hide Signatures
       Post #: 1
RE: Shockwave turns off on full throttle - 12/31/2011 11:14 PM
nitrosportsandrunner
Score: 296
Last Login: 5/19/2013
Status: online
sounds like you may need to adjust the high-speed needle. it may be rich, or may be lean.
is it easy to restart when it dies?
If the motor idles well, and has good low-end power then the idle gap and low speed needle are set pretty good.
It can also be a bad glow plug. sometimes they will still light up when you test them, but not give enough heat to run 100%
but 1st try tuning the high speed. make small adjustments, and remember where you started.
after you make an adjustment, do 2 or 3 high speed passes.
also, when you hit full throttle...just before the motor dies...is there a good trail of smoke coming from the exhaust? If not, then the motor is lean and you need to richen up the high speed(turn counter-clockwise)
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to y2kcurt)
       Post #: 2
RE: Shockwave turns off on full throttle - 1/2/2012 3:02 AM
runner1514
Score: 100
Last Login: 1/20/2012
Status: offline
When the engine dies at full throttle it is usually because the engine is too lean. Try turning the high speed needle counter-clockwise a bit. Keep in mind that the engine will run leaner as the gas in the tank decreases. You should be able to tell the difference when you have about 1/4 of a tank left. So if you make adjustments when the tank of nitro is between half and full and you find a good setting, you might find yourself running too lean towards the end of the tank.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
