What should kokam1200s draw on triton?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> What should kokam1200s draw on triton?
Page: [1]
Login
What should kokam1200s draw on triton? - 8/26/2003 12:55:42 AM
Reeb
Status: offline
Hi,
Just got delivery of my first lipo's - 2x 1200 HD kokams which I will be using on a pico stick slow flyer. I've bought a triton to charge them on. When delivered they are supposed to hold 50% capacity so I put them on a 0.6A charge, 7.4v with time limit 80 minutes, figuerd this should do it. Problem was that the charge current started at 0.1A, then after a few minutes went up to 0.2A then finally 0.3A where it sat for the duration of the charge. What gives? After 80 minutes the batteries had only taken 400mA.
I set the charger to charge at 0.6A and it only gave out 0.3A ! That's not very nice is it? So what's going on? I read somewhere that lipo's "draw" their own current from the charge, winding down the current as full charge is approached but should this happen so soon ? is the problem that it's the pack's first charge?
All help is graciously appreciated.
       Post #: 1
What should kokam1200s draw on triton? - 8/26/2003 11:19:51 AM
JJ HONG
Status: offline
This is not a matter of first lipo charging.Triton should have a constant current current-constant voltage control for lithium battery.
1)pls check individual cell voltage
voltage is nearly equal then you can start charging
pls make sure that pack voltage is over 6 volt.
2)pack is 50% charged but you don't need to set up 0.6A.
2 SERIES 1200mah cell is capable to accept 1.2AH cc-cv charging
3)check whether you selected voltage 7.4volt(2 series)
4)check you selected lithium charging mode.
In my opinion through your explanation,the charger works only cc mode so that when the pack arrives at 8.4 volt,the charger cut the voltage.
(in reply to Reeb)
       Post #: 2
What should kokam1200s draw on triton? - 8/26/2003 8:11:09 PM
Greg Covey
Status: offline
Reeb,
The Triton setting for current on Lithium cells is only a maximum value setting. If the pack voltage is high enough, you will get a current less than this value.
Remember that Lithium cells do not peak like NiCd or NiMH cells. Think of it as filling up a bucket of water. First, you turn on the faucet to the (current) limit and then you slowly turn off the water as it approaches the top of the bucket.
Typically, my cells have arrived with greater than 50% charge. I have also found the Triton capacity measurement to be inaccurate for Lithium packs. It does, however, charge them properly full.
Try flying it and see what you think...
_____________________________
Visit my Web Hangar at www.gregcovey.com/rc.htm
(in reply to Reeb)
       Post #: 3
What should kokam1200s draw on triton? - 8/26/2003 11:19:27 PM
Reeb
Status: offline
Thanks for the replies.
Yes the pack seemed fully charged. It's just a shame I can't ramp up the current a bit, even after depleting the pack and then putting it on charge. The voltage at initial charge was showing 7.4V
reeb
(in reply to Reeb)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.293RCU5
