RE: Hostetler Lancair ES Build with retracts.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Hostetler Lancair ES Build with retracts.
Page: <<   < prev  1 2 3 [4] 5 6 7 8 9   next >   >>
Login
RE: Hostetler Lancair ES Build with retracts. - 7/31/2012 12:29 AM
sebo
Score: 111
Last Login: 5/19/2013
Status: offline
I like to kit bash.  I have the ES plans and am building around the larger wing.  It is a fun project but the summer flying season and yard work season is upon us here.
I hope that the flaps offer some slowing down of the plane so that I can land it.
Hide Signatures
(in reply to chasrb)
       Post #: 76
RE: Hostetler Lancair ES Build with retracts. - 7/31/2012 11:32 AM
chasrb
Score: 105
Status: offline
I agree with the flaps on this airframe, even though Hosteller says thay aren't needed. I know I'll be adding them on mine! How old are your plans? My plans came with both the ES and the IV build.
When I pickup my L-IV I got th fiberglass fuse, foam core wings and horz stab (obiechi wood), but since I have not tacked a foam core like this, I had a full wood kit cut so I can use the built up wing. I have begun to think about using "fliteskin" instead of balsa sheeting and then fiberglassing, the fliteskin looks like it'll do a nice job, plus if I decide to use the foam core it will work on those too.
I am looking to start this build hopefully soon. Need to get a 32x80 hollow core door to build this one ...
Thanks for posting your pics, they are helpful.
_____________________________
Chasman
Hide Signatures
(in reply to sebo)
       Post #: 77
RE: Hostetler Lancair ES Build with retracts. - 8/1/2012 2:22 AM
sebo
Score: 111
Status: offline
My plans are so old that they are carved in stone....they must be among the first sold.....
I will keep on with the build but it is going to be slow.
Good luck with your build....why not start a thread on it so that other methods can be seen?
I am using a standard door for the build....it fits.
Hide Signatures
       Post #: 78
RE: Hostetler Lancair ES Build with retracts. - 8/1/2012 2:28 PM
chasrb
Score: 105
Status: offline
I may just start a thread on my build. First need the 32x80 door to build on lol...
Chasman
Hide Signatures
(in reply to sebo)
       Post #: 79
RE: Hostetler Lancair ES Build with retracts. - 8/2/2012 4:54 PM
sebo
Score: 111
Status: offline
Maybe an 8 foot by 34 inch door would be easier to find.  Try local hardware stores for damaged doors.....mine was only about 15 dollars and I have had it for 30 years.  I guess they would cost more now.....better get one soon before the government outlaws them.
Hide Signatures
       Post #: 80
RE: Hostetler Lancair ES Build with retracts. - 8/2/2012 6:06 PM
chasrb
Score: 105
Status: offline
Well, after a few hours of looking I found exactly the door I wanted to use! I found it at Stock Supply, its a 32"x80" exterior flush steel slab no drill door for $68.00. I did find one at HD but it was pre hung and in a sash for $116. I would have had to throw away the sash and to that was a big waste. I'll be picking the door up on Wed next week.
I am planning on using it as a large magnetic building board + I can use ceiling tile or other material on the other side should I want to build with pins and such.
This should end up pretty versatile
Chasman
Hide Signatures
(in reply to sebo)
       Post #: 81
RE: Hostetler Lancair ES Build with retracts. - 8/3/2012 4:04 AM
sebo
Score: 111
Status: offline
Sounds good!
Hide Signatures
       Post #: 82
RE: Hostetler Lancair ES Build with retracts. - 8/5/2012 8:36 AM
sebo
Score: 111
Status: offline
Another sleepless night in Jacksonville.
Since it is my first time with fowler flaps I sure was hesitant in cutting away the wing that looked so goodl
Measure and re-measure.......
Cut.......Came out ok; still have some shaping to do.   Flap is just right on one end byt not thick enough on the other....Have to add some sheeting to the bottom to thicken it.
Here is what I did tonight.
This should be set number 3
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 83
RE: Hostetler Lancair ES Build with retracts. - 8/5/2012 8:39 AM
sebo
Score: 111
Status: offline
Here are more pictures of tonights' progress.
This should be set number 1
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 84
RE: Hostetler Lancair ES Build with retracts. - 8/5/2012 8:40 AM
sebo
Score: 111
Status: offline
This should be set number 2
Yet More........sorry the pictures are out of sequence........too early on the morning to be doing this.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 85
RE: Hostetler Lancair ES Build with retracts. - 8/5/2012 8:40 PM
chasrb
Score: 105
Status: offline
Looking good, Did your plans come with the detail to add flaps? Mine did not. We may want to trade photos of the plans we each have.
Chasman
Hide Signatures
(in reply to sebo)
       Post #: 86
RE: Hostetler Lancair ES Build with retracts. - 8/6/2012 4:13 AM
sebo
Score: 111
Status: offline
No. Not on plans......I am just going along by instinct. I haven't drawn any plans for the flaps either.....just measure and cut.....
worked on it tonight too. nothing to show for this evening...just cut and shape.  Using spackling to fill the gaps.
It is a fun project.
Hide Signatures
       Post #: 87
RE: Hostetler Lancair ES Build with retracts. - 8/6/2012 9:03 PM
sebo
Score: 111
Status: offline
The ultimate in Fowler Flaps.
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 88
RE: Hostetler Lancair ES Build with retracts. - 8/22/2012 7:51 AM
sebo
Score: 111
Status: offline
It took a lot of thinking but I figured out how to put the flap mechanism into the flap.
It is probably easy for those of you who have done it before.
The following pictures will show my slow progression.
While I was doing this I was rebuilding 2 planes that I re-kitted this past month.
Have to keep them flying.
So, here goes.....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 89
RE: Hostetler Lancair ES Build with retracts. - 8/22/2012 7:53 AM
sebo
Score: 111
Status: offline
Continuing.........
The rectangular pieces are of 1/8 inch plywood to allow for a good solid hold.
I USED 30 MINUTE EPOXY TO SECURE THE PLYWOOD.
YES, THERE ARE GAPS BECAUSE I DIDN'T CUT THE PLYWOOD PERFECTLY.......THAT'S WHY THEY INVENTED SPACKLING COMPOUND.........'SPECIALLY FOR BUILDERS LIKE ME.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 90
RE: Hostetler Lancair ES Build with retracts. - 8/22/2012 7:56 AM
sebo
Score: 111
Status: offline
Make sure there is room for the slide to move freely..
Next I will drill pilot holes for the 4 screws that hold the hinge in place.
The next one should be much quicker to install.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 91
RE: Hostetler Lancair ES Build with retracts. - 9/7/2012 9:09 AM
sebo
Score: 111
Status: offline
Two hinges installed and one more to go......in the middle.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 92
RE: Hostetler Lancair ES Build with retracts. - 9/7/2012 9:13 AM
sebo
Score: 111
Status: offline
The reason that this thread is going so slow is because I am working on a Hostetler Cessna 150 at the same time as well as doing all the household chores and yard work...getting some flying in too....
Hide Signatures
(in reply to sebo)
       Post #: 93
RE: Hostetler Lancair ES Build with retracts. - 9/10/2012 2:16 AM
chasrb
Score: 105
Status: offline
Looks good Sebo. I have not had a chance to start my build yet. Where did you get the hinges?
Chasman
Hide Signatures
(in reply to sebo)
       Post #: 94
RE: Hostetler Lancair ES Build with retracts. - 9/10/2012 3:20 AM
sebo
Score: 111
Status: offline
Robart.
Hide Signatures
       Post #: 95
RE: Hostetler Lancair ES Build with retracts. - 9/20/2012 9:10 AM
sebo
Score: 111
Status: offline
Planning to stasrt work on it again tomorrow.
Hide Signatures
(in reply to sebo)
       Post #: 96
RE: Hostetler Lancair ES Build with retracts. - 9/22/2012 2:03 PM
sebo
Score: 111
Status: offline
Middle flap hinge completed.........If you go for 3 hinges, make sure that they are all in alignment so binding won't occur.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sebo)
       Post #: 97
RE: Hostetler Lancair ES Build with retracts. - 9/23/2012 5:08 AM
invertmast
Score: 193
Last Login: 5/20/2013
Status: online
Im watching! Ive got the urge to take one of these and either modify it into a lancair evolution, or a lancair Iv-P with a wren turboprop
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to sebo)
       Post #: 98
RE: Hostetler Lancair ES Build with retracts. - 9/23/2012 7:18 PM
sebo
Score: 111
Status: offline
If you do, You are welcome to add your construction to this thread if you want.........I'd surely be interested in your mods and construction techniques..
Hide Signatures
(in reply to invertmast)
       Post #: 99
RE: Hostetler Lancair ES Build with retracts. - 9/24/2012 1:40 AM
invertmast
Score: 193
Status: online
Will do.. right now i'm still in the debating stages. I've got so many other "large" models that my trailer has run out of room so convincing the wife to let me have another is kind of difficult.. specially since the trailer is full and one of the spare bedrooms has partially completed projects, kits, ARF's and a ton of plans and balsa wood sitting in it. lol
Thomas W.
Hide Signatures
(in reply to sebo)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.766RCU1
