RE: Seagull Super Tucano    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Seagull Super Tucano
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Seagull Super Tucano - 9/25/2012 2:44 PM
Guijs
Score: 100
Last Login: 5/21/2013
Status: online
 Excellent video!
So you found out that the 15x12 prop is the best option for this engine?
I plan to use 3 blade but i`ll start with 2 blade until I get used to the plane.
Hide Signatures
(in reply to ceecrb1)
       Post #: 51
RE: Seagull Super Tucano - 9/25/2012 4:55 PM
ceecrb1
Score: 120
Last Login: 5/20/2013
Status: offline
No, I didnt find it to be the best option... I found it to be an option that FITTED without hitting the ground so I have kept with it!!
_____________________________
Goldwing MX2 & DLE 30 + Harris smoke pump
Seagull Super Tucano 91 & DLE 20
Hide Signatures
(in reply to Guijs)
       Post #: 52
RE: Seagull Super Tucano - 9/25/2012 5:41 PM
Guijs
Score: 100
Status: online
But did you find it better than 15x8 that is recommended by DLE for this engine?
I am considering 3 blade 14x9. I have found good results with this web calculator:  http://personal.osi.hu/fuzesisz/strc_eng/index.htm
The prop is this one:  http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRF49&P=0
Static thrust = 186.59 oz = 5.29 kg
Perimeter speed = 167.48 m/s
Required engine power = 2.397 HP
Estimated flying speed = 76.7 mph  = 66.6 Knots
Hide Signatures
       Post #: 53
RE: Seagull Super Tucano - 10/12/2012 10:16 PM
rlbomber
Score: 100
Last Login: 5/14/2013
Status: offline
It seems that my wheel inserts will not fit into the opening even after they get trimmed down.  Did anyone here have this same problem and have to trim the opening a little larger?
Otherwise, I may have the wrong wheel inserts in the package.
Hide Signatures
(in reply to rk212)
       Post #: 54
RE: Seagull Super Tucano - 10/13/2012 10:47 AM
ceecrb1
Score: 120
Status: offline
Can you be a little clearer as to the exact problem? not really sure from your email and here if you mean the nose wheel, wing wheels..... or if your talking about the plastic former that goes inside the wheel or the wooden mounting blocks.....
These are custom addons, they will (and mine did) need a little modification and work to make them fit... tbh it wasnt anything that made me stop and think too much..
Hope this photo can clear things up.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to rlbomber)
       Post #: 55
RE: Seagull Super Tucano - 10/13/2012 12:42 PM
rlbomber
Score: 100
Status: offline
I'll see if I can take pictures later and post them here so that you can see my dilemma.  It seems that the inner part of the plastic inserts will not fit into the wing openings.
Hide Signatures
       Post #: 56
RE: Seagull Super Tucano - 10/14/2012 12:33 PM
rlbomber
Score: 100
Status: offline
Got them in but they didn't go easy.  It seems that they were a little deformed.
Hide Signatures
       Post #: 57
RE: Seagull Super Tucano - 10/22/2012 5:20 PM
rlbomber
Score: 100
Status: offline
Where did you guys install the ignition module?  I'm thinking about putting it right behind the fuel tank and running the cables along the side of the tank.  I was thinking about making another opening in the firewall to allow the cables to come out.
Hide Signatures
       Post #: 58
RE: Seagull Super Tucano - 2/15/2013 12:40 PM
Krasherjack
Score: 100
Last Login: 5/16/2013
Status: offline
Iwasa,
I have an ASP 90 in mine, Nice fit in the cowl..I'm not worried if it is on the slow side, as I have other fast propjets...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to BWIwasa)
       Post #: 59
RE: Seagull Super Tucano - 3/18/2013 10:26 PM
Guijs
Score: 100
Status: online
Have you decided about your ignition placement?
I did exactly what you said. My IE is behind the fuel tank, with the cable running on the side wall and I have made another opening at the side of the firewall.
But I didn't turned to engine on yet. S oI don't know If i'll have any interference issues.
Hide Signatures
       Post #: 60
RE: Seagull Super Tucano - 3/19/2013 1:08 PM
rlbomber
Score: 100
Status: offline
Guijs,  I ended up placing the Ignition Module behind the firewall along side the fuel tank. I cut a hole alongside the engine mount for the spark plug and the magneto wire to come from.
A couple of other mods, I used the E-flite 90-120 electric retracts and used a servo for the front steering.  I did not use the wire strands but used an actual wire.
My first flight with the armament went beautiful, very little trim.  She lands so smooth, although fast.  I need to get the flaps adjusted so that I can use them on landings.
The only issue I have is that the armament is very flimsy and they are no broke.  I cannot find replacements for them since Seagull does not sell them separately.
Hide Signatures
(in reply to Guijs)
       Post #: 61
RE: Seagull Super Tucano - 3/19/2013 6:56 PM
Guijs
Score: 100
Status: online
rlbomber, I think i'll do the same and put the IE right behind the firewall. This will give me more room for rx placement.I also have E-flite retracts and I'm using the rudder servo for the steering with a hard wire.What prop are you using? I'll start with APC 15x12 2 blade but I plan to use MA 14x9 3-blade and then I'll test some carbon 3-blade until I find the one with best performance.Too bad that seagull don't sell them separatedly. I wont use them in my first flights.
Hide Signatures
       Post #: 62
RE: Seagull Super Tucano - 3/19/2013 10:24 PM
rlbomber
Score: 100
Status: offline
With the electronic ignition behind the firewall, I had to add abit of weight to the ass end of the plane.  I put the weight in the compartment hatch towards the back, underside of the fuselage.
I find that the APC 15-8 works real well for the DLE 20 but let me know how that 3 blade prop works out.  I wasn't comfortable running a wire from the rudder servo all the way up to the front gear.  That's why I used a seperate servo  and put it right were the front retract servo would have gone.
If you go to our clubs facebook page and scroll down, you will see my Tucano coming in for a landing in the snow.
https://www.facebook.com/pages/Pine-Barren-Modelers-RC-Club/423381327734047?ref=hl
Hide Signatures
(in reply to Guijs)
       Post #: 63
RE: Seagull Super Tucano - 3/20/2013 12:12 AM
Guijs
Score: 100
Status: online
Nice landing!
I'll try to fit the rx or EI battery at that tail compartment to balance the weight. Are you using a servo for the choke?
I already have some props to try: 2 blade MA 15x8, 15x10, APC 15x12 and 3 blade MA 14x9. I`ll let you know wich one is the best.
Hide Signatures
       Post #: 64
RE: Seagull Super Tucano - 3/20/2013 2:57 AM
rlbomber
Score: 100
Status: offline
 For the choke, I just reach up under the cowling, I added a 2 inch screw to the choke arm and it's easy to reach.
Im telling you, this plane lands beautifully.  On one of my flights, the throttle linkage came off and using my opto kill switch was able to line up the landing and kill the motor.  She glided right in!
Hide Signatures
(in reply to Guijs)
       Post #: 65
RE: Seagull Super Tucano - 3/20/2013 3:22 PM
Krasherjack
Score: 100
Status: offline
Guijs,
Have you got some pics of your nose wheel steering setup?
Jack
quote:
ORIGINAL: Guijs
Hide Signatures
(in reply to Guijs)
       Post #: 66
RE: Seagull Super Tucano - 3/20/2013 4:06 PM
Guijs
Score: 100
Status: online
Jack,
I don't have right now but I'll take some on the weekend.
Hide Signatures
(in reply to Krasherjack)
       Post #: 67
RE: Seagull Super Tucano - 4/15/2013 3:44 AM
Guijs
Score: 100
Status: online
 rlbomber, do you have pics of your steering servo setup? I didn't had time to maiden yet and this weekend I realised that using the rudder servo for the steering would not work.
So I have added a servo for the steering but I can't figure a way to set my futaba 8fga to "turn off" the servo when the gear is up. How are you doing this?
Krasherjack I did not took the pictures because it was not working as I suposed it would.
Hide Signatures
(in reply to Guijs)
       Post #: 68
RE: Seagull Super Tucano - 4/15/2013 1:55 PM
rlbomber
Score: 100
Status: offline
What retracts are you using?  I have the E-flite retracts in and the front gear uses a setup where as when the gear is up, the stearing rod moves up and down the retract shaft.  I will try to take a picture of the gear later and post it.
Hide Signatures
(in reply to Guijs)
       Post #: 69
RE: Seagull Super Tucano - 4/15/2013 1:58 PM
rlbomber
Score: 100
Status: offline
I must say, this plane flies beautifully with the DLE 20 motor.  It handles so well in the air and the landings are so easy because of the way she glides in.  The only downside to this plane is she comes in fast, not much to slow her down so I have to get the flaps setup so that I can use them to help slow her down.
Hide Signatures
       Post #: 70
RE: Seagull Super Tucano - 4/15/2013 2:42 PM
Guijs
Score: 100
Status: online
 rlbomber, I also have eflite retracts. Thanks for reply but I do not need the pics anymore. I just realised how to do it. I will setup my radio futaba 8FGA to deactivate the steering servo when gear is up. I broke the retract shaft when turning the servo with gear up... Just bought the replacement in ebay.
I set my flaps for 15 and 45 degree and added servo signal delay from hobbyking, so it will move slowly.
Hide Signatures
       Post #: 71
RE: Seagull Super Tucano - 4/15/2013 6:22 PM
Guijs
Score: 100
Status: online
What control throws are you using? The manual says up/down for aileron and elevator and left/right for rudder. I assume it is wrong because I never saw this before. The correct would be low rate/high rate.
Some models use down aileron with different rate than up aileron, but they say left rudder 40mm and right rudder 20mm.
Hide Signatures
(in reply to Guijs)
       Post #: 72
RE: Seagull Super Tucano - 4/15/2013 9:17 PM
rlbomber
Score: 100
Status: offline
What they are referring to in the manual is low / high rates.  Elevator and aileron are set for 15mm low rate and 20mm high rate.  The rudder is set for 25mm low rate and 40mm high rate.
I don't know about anyone else, but this plane takes a bit to get off the runway, it literally floats off the ground but once she's in the air, my god she is fast!
Hide Signatures
(in reply to Guijs)
       Post #: 73
RE: Seagull Super Tucano - 4/15/2013 9:23 PM
Guijs
Score: 100
Status: online
Check the position of your nose wheel. If the nose is too low it will be hard for the plane to takeoff. In other hand, it will be easier to stop when landing.
I plan to add brakes in the future and also a nose gear door with sequencer.
Hide Signatures
       Post #: 74
RE: Seagull Super Tucano - 4/15/2013 9:27 PM
rlbomber
Score: 100
Status: offline
It's not hard to take off it's just that it takes time to build up the speed.  I had the Seagull Dewotine with the same DLE20 and the plane would lift off the ground in 20 feet.
It looks like it needs more runway due to the small wings compared to the plane size.
Hide Signatures
(in reply to Guijs)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
