Build desk necessities    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Build desk necessities Page: [1]
Login
Build desk necessities - 1/7/2012 10:02 PM
dogginfox
Score: 100
Last Login: 12/8/2012
Status: offline
I am setting up a build station after being away from the hobby for over 15 years. I am starting from scratch so I would like some input as to what I need to have at my desk for most builds. Currently my desk is topped with a hollow core door covered in wax paper. I have a large assortment of pins, sanding paper razor knives and glues, a heat gun and basic hand tools. What else do I need? Tips can you give me?
Hide Signatures
       Post #: 1
RE: Build desk necessities - 1/7/2012 11:04 PM
JNorton
Score: 149
Last Login: 5/17/2013
Status: offline
This might be overlooked but when I built mine I used two 15 amp circuits powering separate strip outlets. Now I can have two set of covering irons going at once and still be able to use a a soldering iron or magnifying lamp without blowing a circuit breaker.
John
_____________________________
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to dogginfox)
       Post #: 2
RE: Build desk necessities - 1/7/2012 11:15 PM
vicman
Score: 189
Last Login: 5/18/2013
Status: offline
The stick-um sandpaper, self healing cutting surface, and a decent battery drill. The hinge tool is a pretty dang handy little tool too.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to JNorton)
       Post #: 3
RE: Build desk necessities - 1/7/2012 11:22 PM
Zor
Score: 181
Status: offline
quote:
ORIGINAL: dogginfox
Hello dogginfox,
It is difficult to give you tips based on your above description of what you have.
Some items I can mention you may have already but I will mention tools that are not typically in a household.
They can be acquired as the need shows up.
A surface in which you can push pins by hand. (I do not have that becasuse I use very few pins).
A Bremel high speed rotary hand tool with some drill bits, cutting disks, abrasive drums of different diameters.
A small vertical drill press with a chuck up to 3/8" capacity.
A rotary and belt sander that use a 6" dia abrasive disk of different grits and the belt part using 3" but preferably 4" wide belts. Very useful for trimming parts to exact size and fit. Should have adjustable tables to set angles.
A table saw. Size depending on other type of work you may do.
Place to store wood if you scratch build.
Good illumination (fluorescent ligts) coming from all around to avoid shadows while fitting parts.
Lots of clamps including "clothes pins" .
Other fellows here will no doubt give their outlook as well.
One thing for sure _ _ _ you do not need $10,000.00 worth of tools and machinery  _ _ _  _ _ _  .
Enjoy the proper tool when needed.
Zor
P.S.: I was typing while others posted. I had not seen their postings.
Hide Signatures
       Post #: 4
RE: Build desk necessities - 1/7/2012 11:52 PM
G8er
Score: 105
Last Login: 3/2/2013
Status: offline
I am in the same boat as you dogginfox, I am short on garage space, and mine is neither cooled or heated and here in phoenix I dont want to be roasting instead of building/playin. So I am useing a spare room and as it will be used as a place for someone to sleep in if need be when the time comes around I need to keep it somewhat clean. So I am using a folding 6' plastic plastic cafateria style table, and going to lay a peice of either 1" or 1/2" rigid foam board over that so I can use T pins and if some glue leaks threw clean up will be easy. Useful tools I have found were table top caddys for storage of x-acto blades and misc stuff, as well a multi arm aligator clamp is useful for times of need when you wish you had 11 fingers. Also a handy tool that wasnt really avail back when you were building is a handy glue holder that wont tip over, I tried to find a link, but for somereason I can't find the dang thing.
Hide Signatures
(in reply to Zor)
       Post #: 5
RE: Build desk necessities - 1/8/2012 12:29 AM
Minnreefer
Score: 195
Last Login: 5/19/2013
Status: offline
I just spent most of Friday at a friends house and we largely scratch built 2 20 size stik planes. The only things we used were 2 hollow doors, a small table top scroll saw, a few sharp exacto knives, glue, home made plans, and a pile of balsa. I guess we also had a couple squares and straight edges. I wish we had a band saw or table saw, but we managed.
I guess my point is one does not need much.
I feel good about it since I have not built a kit in 20 years, granted my friend has built 30 in the last 20 years.
Good luck.
Jon
Tiger 2 brotherhood #14
The Common flyer, best of the lousiest, and lousiest of the best.
Hide Signatures
(in reply to G8er)
       Post #: 6
RE: Build desk necessities - 1/8/2012 3:20 AM
dogginfox
Score: 100
Status: offline
Thanks for all the quick responses. Looks like the only thing I am missing is a small scroll saw, I'll have to check out what harbor freight has tomorrow
Hide Signatures
(in reply to Minnreefer)
       Post #: 7
RE: Build desk necessities - 1/8/2012 12:18 PM
Toysareforkids
Score: 100
Last Login: 5/8/2013
Status: offline
   I can't go without my Lasy susan tool holders, That way I have most, of the most often used stuff on my bench all the time, with a handle. Except for my 3 different xacto knives, and junk holders, that sit on the work bench.  And it gives your helpers more room, so that their not in your way!
   Pat
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: Build desk necessities - 1/8/2012 2:13 PM
carrellh
Score: 179
Status: offline
If you are not cutting your own kits the scroll saw is low on the list of needed items. I bought a variable speed Ryobi a few years ago and used it once or twice.
- Carrell
Hide Signatures
       Post #: 9
RE: Build desk necessities - 1/8/2012 3:12 PM  1 votes
LesUyeda
Score: 151
Status: offline
"I bought a variable speed Ryobi a few years ago and used it once or twice."
I have a whole garage FULL of stuff that I have only used once or twice, but when you need it, there is nothing else that does the job as well.
Les
Hide Signatures
(in reply to carrellh)
       Post #: 10
RE: Build desk necessities - 1/8/2012 3:14 PM
LesUyeda
Score: 151
Status: offline
Les
Hide Signatures
       Post #: 11
RE: Build desk necessities - 1/8/2012 3:45 PM
sonsight
Score: 100
Status: offline
Gotta get a Dremel/ with the sanding drums!
Hide Signatures
(in reply to LesUyeda)
       Post #: 12
RE: Build desk necessities - 1/8/2012 4:02 PM
JNorton
Score: 149
Status: offline
quote:
ORIGINAL: dogginfox
Actually you have all the basics. Make sure the door is flat. I'd put something on top of the door like sheetrock or ceiling tiles so the pins are easier to use. Or use a magnetic system as decribed here. http://www.airfieldmodels.com/information_source/how_to_articles_for_model_builders/tools/magnetic_building_board/index.htm Everything else is stuff that makes building easier. I use my scroll saw a lot. I also love having a dremel.
I can spend hours reading every techique Paul uses at his web site. http://www.airfieldmodels.com/index.html
John
Hide Signatures
       Post #: 13
RE: Build desk necessities - 1/8/2012 4:36 PM
vicman
Score: 189
Status: offline
I use my dremel often too. I have one of those dingleberry looking burrs that I like better than the drums.
Hide Signatures
       Post #: 14
RE: Build desk necessities - 1/8/2012 7:49 PM  1 votes
Jetdktr
Score: 110
Status: online
Delete
Hide Signatures
(in reply to vicman)
       Post #: 15
RE: Build desk necessities - 1/8/2012 7:58 PM
Jetdktr
Score: 110
Status: online
CUPHOLDER to hold that large chilled beverage while thinking "why did I want to build this thing"?
Hide Signatures
       Post #: 16
RE: Build desk necessities - 1/9/2012 3:07 AM
saramos
Score: 121
Status: offline
quote:
ORIGINAL: dogginfox
Hi Dogginfox,
Here's a couple of site recommendations. One that has a lot of tips and techniques for building, tools and materials is a great site run by Paul Johnson (Known as cafeenman here on RCU) is
Check it out. I'm sure it'll become one of those sites that you will return to often. I use his magnetic build system.
For a good selection of modeling tools, check out
www.micromark.com
For good deals on fasteners, check out these two sites
www.rtlfasteners.com
www.microfasteners.com
If you get into scale building, chances are you will end up doing some fiberglass coverings and possibly fiberglass parts. These sites are good for glass and carbon supplies
www.cstsales.com
http://www.acpsales.com
Hope these help
Scott
Hide Signatures
       Post #: 17
RE: Build desk necessities - 1/9/2012 6:22 PM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
To help control balsa sanding dust, I bought a 20 inch box fan and duct taped a 20 inch furnace filter to it. Get the fan going before you start to sand to set up an airflow pattern in the room. It's surprising how much gets sucked into the filter.
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to saramos)
       Post #: 18
RE: Build desk necessities - 1/9/2012 8:53 PM
G8er
Score: 105
Status: offline
quote:
ORIGINAL: kenh3497
I am going to do something very similar for a indoor painting booth, for when I use my airbrush with lacquer paints, except I am going to use a box with a whole cut on the bottom and tip it on its side and run a duct out a window. I will think about upgrading the fan size to double as a dust collection.
Hide Signatures
(in reply to kenh3497)
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
