New to me B4 issues    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> New to me B4 issues
Page: [1]
Login
New to me B4 issues - 1/10/2012 4:49 PM
aglaser
Score: 100
Last Login: 4/3/2013
Status: offline
Hi all! Im new to r/c cars but have experience with nitro planes and boats. I recently aquired an associated B4 buggy dirt cheap. Ive had a couple issues with is as to be expected from a used rc.. The screw that holds the servo arm has fell out. How in the world am I supposed to get it back in the servo?? Also I think I have an issue with my rx/ esc. I can run fine for a while and then the car acts like it loses signal for a second thenk I regain control.. Ive noticed if I flip the connection between the esc and battery I can cause this problem.. Any ideas on this? Again I am a total newbie to cars and electric! Thanks a lot!
Hide Signatures
       Post #: 1
RE: New to me B4 issues - 1/10/2012 7:09 PM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
To put the servo screw back in, you take the servo out, and then put the screw in, and reinstall the servo.
If this is a car with a Tamiya plug, cut it off and throw it in the garbage and solder a Deans or Traxxas plug on it. The Tamiya plugs are horrible and once they get a bit of wear to them, they lose their connection and that would explain what you experienced with your car.
If the servo is a Hitec, you need an M2.6x8mm screw. Otherwise it'll be an M3x8mm screw. If it's plastic geared, chances are good that the threads are pulled out of the splined output shaft.
_____________________________
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
(in reply to aglaser)
       Post #: 2
RE: New to me B4 issues - 1/10/2012 7:22 PM
proanti1
Score: 341
Last Login: 1/6/2013
Status: offline
Careful with the servo mounts, they are ridiculously easy to strip.
Her name was Lola. She was a show girl.
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 3
RE: New to me B4 issues - 1/10/2012 7:28 PM
ThunderbirdJunkie
Score: 1040
Status: offline
ThunderbirdJunkie never really had that issue.
*EDIT*
Nevermind, RTR has plastic
Hide Signatures
(in reply to proanti1)
       Post #: 4
RE: New to me B4 issues - 1/11/2012 11:16 PM
aglaser
Score: 100
Status: offline
Update... Got the servo screw back in.. It looked harder than it was to remove the servo.. Ended up cracking one of the crappy servo mounts so a hobby shop trip is in order.. ALso the connecter on the esc is a deans connecter already.. Should I try cutting off a cm or so, stripping and resoldering it back to the esc or just buy a new one?
Hide Signatures
       Post #: 5
RE: New to me B4 issues - 1/12/2012 3:41 AM
ThunderbirdJunkie
Score: 1040
Status: offline
Nope, because Deans (at least real Deans) don't normally wear out. If there's any question on whether they're real or fake Deans, pop down to your LHS and get a new pack of them and compare them. The fake Deans are normally a redder red and a different material that one can dent with their fingernail.
Hide Signatures
       Post #: 6
RE: New to me B4 issues - 1/15/2012 6:50 AM
aglaser
Score: 100
Status: offline
Update 2.. After taking the car to the hobby shop and finding my esc was messed up, I replaeced it and got some servo mounts.. Got the car running and it runs great! The only issue I have is after i put it into reverse even for a second, I cant go foward for a few seconds, on the other hand I can be going foward and just slam it into reverse at any time.. Im pretty sure this is bass ackwards because of a built in esc braking sequence or something.. Any ideas? Can I switch the polarity on the engine and servo reverse to fix it or is this a way to let the magic smoke out of my setup?
Hide Signatures
       Post #: 7
RE: New to me B4 issues - 1/15/2012 3:14 PM
proanti1
Score: 341
Status: offline
Something is backwards. Your forward is reverse. There is a servo reversal switch on your remote, hit that, then re-program your ESC (refer to the manual). It should now be going backwards when you pull the trigger. To fix this, reverse the polarity to your motor.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
