RE: Side Pocket Article    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Side Pocket Article
Page: <<   < prev  1 2 [3]
Login
RE: Side Pocket Article - 3/2/2012 6:30 PM
Jim_Purcha
Score: 120
Last Login: 5/22/2013
Status: offline
The Wing Mfg Sport Canopy was used on quite a few models in the RCM plans catalog. Revenger, Side Pocket, Double Eagle (60 & 40 versions I think).
Jim
_____________________________
Ultra Sport Brotherhood #30
Hide Signatures
(in reply to doxilia)
       Post #: 51
RE: Side Pocket Article - 3/3/2012 1:11 PM
Free Bird
Score: 105
Last Login: 5/24/2013
Status: offline
David: Good to know that canopy will work with your plans of the SP.
Jim: Equally good to know that the canopy is the same for the Revenger. That model is on my radar!
FB
Hide Signatures
(in reply to Jim_Purcha)
       Post #: 52
RE: Side Pocket Article - 3/3/2012 10:31 PM
abozzie
Score: 100
Last Login: 2/3/2013
Status: offline
Looks like I wasn't taking many pictures at the time I was flying the Side Pocket and Hammer and the ones I did have were pre-digital. The original SP finally met its demise in early 2000 and the second one was build over the next winter. The original had a build up canopy using bulkheads and stringers covered with chrome covering. Two wide red stripes were added to the bottom of each wing and a large red band on the aft fuselage to help with orientation. Pulling up hard and sending all the controls hard over would make the plane snap into some pretty wild flips and rolls.
I purchased the Wing canopy and cockpit for the second one but the metallic blue top over white bottom covering was used again.
The Hammer is shown on a set of "snow floats" in Jan 2000. Not much trouble picking this one out in the sky.
A couple of more pictures of SP #2 modifications to accept an extra landing gear mount ahead of the wing and custom wing fillets. Duct tape in picture is wrapped around tank to help pull it out. I also noticed that the entire plane was treated with balsarite and perforated with pin holes prior to covering. This was done with three pieces of 1/4 dowel taped together with a pin set in each one. It takes a bit of time but the end result is a good bond for the covering and no bubbles.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by abozzie -- 3/3/2012 11:28 PM >
AB
Hide Signatures
       Post #: 53
RE: Side Pocket Article - 3/4/2012 3:26 PM
Free Bird
Score: 105
Status: offline
AB,
Smart looking SP you have there. Sorry that your first one met an untimely end, but glad to see that you built another one! Thanks for posting the pics!
FB
Hide Signatures
(in reply to abozzie)
       Post #: 54
RE: Side Pocket Article - 3/4/2012 5:01 PM
doxilia
Score: 136
Status: online
quote:
ORIGINAL: abozzie
I knew there was a good reason why I liked this airframe! I hope to make some further progress on the CAD this coming week. Have a couple of days off.
quote:
ORIGINAL: abozzie
AB, that is a cool looking cockpit in the second picture. Worth keeping a partly cleared canopy with those innards! Was it offered by Wing Mfg. at the time?
quote:
ORIGINAL: abozzie
The Hammer is shown on a set of ''snow floats'' in Jan 2000. Not much trouble picking this one out in the sky.
Nice - another design I happen to have spent some time working up (see pics). I like the idea of a pipe down the top deck on this one. Sarpolus was quite forward thinking at the time when he designed this one. Was yours the Hammer 40 or the original 25? Looks like a 40. I enlarged the original 25 ever so slightly below for a piped 25 or even 28 RE (I have one of these on its way... ). A 40 size with an OS 40 VF would be just the companion to the SP. I think both planes have similar moments and aspect ratios.
Thanks for posting the pictures!
David
Mmm... no uploads at the moment... first time this ever happens... not!
Click for fullsize
Click for fullsize
< Message edited by doxilia -- 3/4/2012 5:36 PM >
Hide Signatures
(in reply to Free Bird)
       Post #: 55
RE: Side Pocket Article - 3/4/2012 9:49 PM
abozzie
Score: 100
Status: offline
quote:
ORIGINAL: doxilia
The innards were also from Wing Mfg. A rather simple polystyrene cockpit and a heavy paper instrument panel if I recall.
quote:
ORIGINAL: doxilia
I looked again and the plans came in 20 & 40 size. This was a Hammer 20 from Flying Models (Plan CF637 published 7/83). Myself and a fellow flyer built two at the time and flew some tight formations with them...when I think back, other flyers tended to land when we started beating up the field in close formation. I went from an Enya .25 to a Enya .29V at some point, but don't recall what happened to the plane. My friend put a .35 in his to keep up and that resulted in a high speed elevator flutter, loss of elevator and a lawn dart into the ground. The balsa used along the hinge line was just too soft as well for the extra speed.
AB
Hide Signatures
       Post #: 56
RE: Side Pocket Article - 11/16/2012 1:53 AM
mercura
Score: 100
Status: offline
Just come across this in a copy of MA. Only photo I have seen of this design.
Click for fullsize
Hide Signatures
       Post #: 57
RE: Side Pocket Article - 11/16/2012 2:43 AM
doxilia
Score: 136
Status: online
That is cool! Thanks for posting. Finally we can confirm that the Hip Pocket was a reality. Even mentions John's excellent plans,... If we could only source those plans...
David
Hide Signatures
(in reply to mercura)
       Post #: 58
RE: Side Pocket Article - 11/16/2012 4:44 AM
pitstop000
Score: 105
Last Login: 5/17/2013
Status: offline
Hey mercura, like David said "thanks for posting!"
It looks like it was setup for an RE Engine like I thought.
It’s time for its own thread! We now have more contact info on this plane.
Thanks Bud!
By the way do you have the whole article? or atleast just the author of the piece?
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
       Post #: 59
RE: Side Pocket Article - 11/16/2012 5:30 AM
doxilia
Score: 136
Status: online
The wing and stab look to have the same planform as the Side Pocket. Even the aspect ratio of the model looks similar - large span, shorter fuse. RE setup indeed.
We'll have to carry this over to your new thread Paul.
David
Hide Signatures
(in reply to pitstop000)
       Post #: 60
RE: Side Pocket Article - 11/16/2012 1:38 PM
mercura
Score: 100
Status: offline
The article was by Ron Van Putte, he was reporting on the 1985 Nats for MA (Dec 1985)
Dave
Hide Signatures
       Post #: 61
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
