RE: Aerobeez 26% Yak 55M Build Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Aerobeez 26% Yak 55M Build Thread
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Aerobeez 26% Yak 55M Build Thread - 1/28/2012 3:33 AM
overbored77
Score: 114
Last Login: 5/23/2013
Status: offline
zbo2, let me know how the quality is on the MSXR, i am considering the 88" 50cc MSXR
_____________________________
Chris Murphy
Hide Signatures
(in reply to zbo2)
       Post #: 51
RE: Aerobeez 26% Yak 55M Build Thread - 1/29/2012 1:23 AM
zbo2
Score: 100
Last Login: 2/23/2013
Status: offline
oke doke ..... your close enough to me you could stop over 1 day and check it out yourself...if you would like
< Message edited by zbo2 -- 1/30/2012 8:58 AM >
Joe
Hide Signatures
(in reply to overbored77)
       Post #: 52
RE: Aerobeez 26% Yak 55M Build Thread - 1/30/2012 10:44 PM
zbo2
Score: 100
Status: offline
Joe
Hide Signatures
(in reply to zbo2)
       Post #: 53
RE: Aerobeez 26% Yak 55M Build Thread - 2/2/2012 3:49 AM
lenough
Score: 100
Last Login: 5/28/2013
Status: offline
Troy-I am just starting to put mine together. Where is the CG on yours and were you able to balance by just shifting the batteries around?
Lee
Hide Signatures
(in reply to zbo2)
       Post #: 54
RE: Aerobeez 26% Yak 55M Build Thread - 2/2/2012 3:50 AM
lenough
Score: 100
Status: offline
Lee
Hide Signatures
(in reply to zbo2)
       Post #: 55
RE: Aerobeez 26% Yak 55M Build Thread - 2/2/2012 3:58 AM
lenough
Score: 100
Status: offline
Lee
Hide Signatures
(in reply to zbo2)
       Post #: 56
RE: Aerobeez 26% Yak 55M Build Thread - 2/6/2012 4:56 PM
funflyr
Score: 100
Last Login: 6/7/2013
Status: offline
Yes, mine had some nice decals included. I think I am going to have some vinyl graphics made for it. Lee, I will get the CG figures for you. I have been on a cruise and away from the computer for 8 wonderful days.
Troy
Hide Signatures
(in reply to zbo2)
       Post #: 57
RE: Aerobeez 26% Yak 55M Build Thread - 2/6/2012 10:50 PM
funflyr
Score: 100
Status: offline
Today was a perfect weather day. 50 degrees and 10 mph winds. I was able to put 5 flights on the Yak. I leaned the low side slightly on the SE-32 and it's running great. In knife edge flight it pulled toward the gear slightly, so I mixed in 4% of up elevator for both right and left knife edge. I flew the IMAC Sportsman sequence with it and it handled it just fine. I then tried every 3D maneuver that I could think of and it handled everything that I tried. I did 1/2 throttle blenders, full throttle pop tops, upright and inverted walls at 1/2-3/4 throttle. I flew it super hard and it held up fine, I don't think it can be broken in the air. It has tons of rudder authority and does fantastic upright and inverted flat spins, and knife edge spins. It was able to do some really fun knife edge walls with it. It locks into inverted harriers with no wing rock. In upright harriers it has a small amount of wing rock, but if you use a slightly higher throttle setting it goes away. I think a bigger prop will eliminate the wing rock. My only complaint is that I can't seem to get it to fly very tight waterfalls. I have the CG at 5 1/2 inch from the leading edge at the fuse and it's a little nose heavy. On high rates, I have as much throw as the elevators will allow. I am going to take the spinner off which will move the CG back a little and see if it helps with the waterfalls. I think a 19X6 prop will also help, I don't think the 18X6 is enough prop on the SE-32. I am happy with the Yak, it is easy to transport and will fly every maneuver that I have tried with it. If the weather stays this nice, I plan on putting a lot more flights on it.
Troy
Hide Signatures
(in reply to funflyr)
       Post #: 58
RE: Aerobeez 26% Yak 55M Build Thread - 2/7/2012 3:26 AM
lenough
Score: 100
Status: offline
Excellent info. Thanks.
Lee
Hide Signatures
       Post #: 59
RE: Aerobeez 26% Yak 55M Build Thread - 2/7/2012 6:52 PM
funflyr
Score: 100
Status: offline
Today, I took the Yak into the workshop to give it a good once over. Everything is holding up great. The pull-pull cables had streached a little, so I tightened them up and now it's ready to fly again. I was able to add some more down elevator, so this may help tighten up the waterfalls. I also took the spinner off which weighed 3.4 oz. this will move the CG back. This dropped they weight below 12 lbs.
Hide Signatures
(in reply to lenough)
       Post #: 60
RE: Aerobeez 26% Yak 55M Build Thread - 2/8/2012 7:15 PM
lenough
Score: 100
Status: offline
I'm finding that the ball links are extremely tight. Tight to the point that I'm getting some servo binding. Aside from replacing them, is there a way to loosen them up? Did you have this problem?
Hide Signatures
       Post #: 61
RE: Aerobeez 26% Yak 55M Build Thread - 2/8/2012 10:02 PM
speedracerntrixie
Score: 194
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: lenough
With them still im place, give them a little squeeze with a pair of pliers. This seats the ball in the plastic and will free them up without slop.
Hide Signatures
       Post #: 62
RE: Aerobeez 26% Yak 55M Build Thread - 2/9/2012 12:00 AM
funflyr
Score: 100
Status: offline
quote:
ORIGINAL: lenough
No, the ball links in my kit were very smooth.
Troy
Hide Signatures
       Post #: 63
RE: Aerobeez 26% Yak 55M Build Thread - 2/23/2012 1:24 AM
funflyr
Score: 100
Status: offline
Today was a great weather day. 58 degrees and only 15-20 mph winds. I put 4 more flights on the Yak today. I am really enjoying flying it. I am having trouble with my camera, and this video isn't much better quality than the last one. I think it's time to start shopping for a new camera. Thanks to my flying buddy Brian for taking this footage.
Troy
http://www.youtube.com/watch?v=lRP2C5CsTkw&list=UUuRsNKbiD4Kc1VYo7qecbZg&index=1&feature=plcp
Hide Signatures
       Post #: 64
RE: Aerobeez 26% Yak 55M Build Thread - 2/23/2012 6:34 PM
funflyr
Score: 100
Status: offline
Here's another vid that Brian took with his phone.
http://youtu.be/ty5TTlA1N5M
Hide Signatures
       Post #: 65
RE: Aerobeez 26% Yak 55M Build Thread - 3/31/2012 9:00 PM
funflyr
Score: 100
Status: offline
I have 30 flights on the Yak now and I am really enjoying it. I switched to some lighter batteries and the weight is now 11 lbs 10 oz. RTF (without fuel). I have the CG at 6" back from the leading edge of the wing (measured at the fuselage.) With this CG, the plane requires just a slight amount of forward pressure on the elevator for inverted flight. The guys at the field yesterday said it was the fastest rolling plane that they had ever seen. I'm having a lot of fun with it.
Troy
Hide Signatures
       Post #: 66
RE: Aerobeez 26% Yak 55M Build Thread - 4/1/2012 6:50 PM
funflyr
Score: 100
Status: offline
Lee asked where I cut holes in the bottom of the cowl. Here's the best picture that I have handy. I will take some more pics and post them asap.
Troy
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 67
RE: Aerobeez 26% Yak 55M Build Thread - 4/2/2012 12:40 AM
lenough
Score: 100
Status: offline
Troy - thanks for the responses. The problem I was having with the muffler was that the type I had was standing too far off the motor where it mounts to the motor as the mounting flange on the muffler was thick. This would have caused me to cut the side of the cowl which I didn't want to do. I switched to a J'Tec muffler which doesn't have a mounting flange. All is well now. Hoping to maiden next weekend.
Lee
Hide Signatures
       Post #: 68
RE: Aerobeez 26% Yak 55M Build Thread - 4/13/2012 2:12 AM
funflyr
Score: 100
Status: offline
Lee your going to love the Yak, I have 40 flights on it now and I'm really enjoying flying it. I bought a new video camera and had a friend take this video yesterday.
Troy
http://www.youtube.com/watch?feature=player_detailpage&v=yKDi99Or1w4
Hide Signatures
       Post #: 69
RE: Aerobeez 26% Yak 55M Build Thread - 4/15/2012 2:57 AM
lenough
Score: 100
Status: offline
Troy- Had my first flights today. Great flying plane. You're right about the roll rate. One of the quickest I've seen. Balanced at 6" like you did and seems to be good at that for the moment. It's a very responsive plane.
Hide Signatures
       Post #: 70
RE: Aerobeez 26% Yak 55M Build Thread - 4/15/2012 7:25 PM
funflyr
Score: 100
Status: offline
quote:
ORIGINAL: lenough
Troy- Had my first flights today. Great flying plane. You're right about the roll rate. One of the quickest I've seen. Balanced at 6'' like you did and seems to be good at that for the moment. It's a very responsive plane.
Lee, I'm glad your flights went well. I am having a ball with this plane. I take it with me everytime I go to the field. The weather has been great the last couple of weeks, I flew it on three different days last week.
Troy
Hide Signatures
       Post #: 71
RE: Aerobeez 26% Yak 55M Build Thread - 4/27/2012 2:16 AM
funflyr
Score: 100
Status: offline
I just ordered the new red and white 50cc Slick to go with the Yak.
Troy
Hide Signatures
       Post #: 72
RE: Aerobeez 26% Yak 55M Build Thread - 4/28/2012 7:04 AM
Bass1
Score: 125
Status: online
Hey funflyr, Please do a thread on the 50cc Slick as well when you get it. I enjoyed the read/info on your 55!
Hide Signatures
       Post #: 73
RE: Aerobeez 26% Yak 55M Build Thread - 4/29/2012 4:03 PM
funflyr
Score: 100
Status: offline
quote:
ORIGINAL: Bass1
Will do, I'm looking forward to assembling it. As good as the Yak flies, I'm guessing that the Slick being larger will fly even better.
Troy
Hide Signatures
(in reply to Bass1)
       Post #: 74
RE: Aerobeez 26% Yak 55M Build Thread - 5/11/2012 3:13 AM
funflyr
Score: 100
Status: offline
I received the Slick today. It seems really light and looks great.
Troy
Click for fullsize
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
