RE: Hangar 9 30cc P-47 Build Thread    Gallery
Logged in as Guest
Users viewing this topic: FlymoreRC, affas
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Hangar 9 30cc P-47 Build Thread
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Hangar 9 30cc P-47 Build Thread - 6/13/2012 9:56 AM
njmheli
Score: 100
Last Login: 5/18/2013
Status: offline
Hi guys.
This is what I have done for the mains and tail wheel for my P-47...........
I managed to get hold of what I would count as a first production run of the pnuematic mains from Robart a few months back ( NOTE : no holes drilled in them for the gear door attachment ).I bought a pnuematic tail wheel set up from TH in the States.
Both mains and tail units use LADO digital actuators.............so it is a "plug and play" set-up,power can be supplied by a normal 6v pack or a 2S Lipo ( which is what I will be using ) and the UC will have it's own power supply.Conversion is pretty easy to do both...........my tail wheel mod,just needing a "little" metal work doing for an extended actuator mounting bracket.
www.e-retract.com ( see for info,I think that LADO are also doing their own complete Electric TW set up for Warbirds etc,looks almost the same as the Robart TW unit.
These digital units can also be programmed to have delays,so you can easily get the "staggered UC look "on up and down !!!
Hope I can up-load my photos below !!!
Nick..................(UK).
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Ron101)
       Post #: 276
RE: Hangar 9 30cc P-47 Build Thread - 6/13/2012 2:11 PM
lablover
Score: 103
Last Login: 5/8/2013
Status: offline
John, Ron, thanks for the answers.
Cool idea on the retracts too NJM !  you just bought the Robart pnumatics and converted with the LAdo elec actuators?
John, what do you think could be the largest gas motor you could fit in this without any mods to the firewall or cutting on the cowl.  Do you think a DLE 55 would bolt up to the firewall and not have to much hanging out of the cowl?
Thanks again guys.  Think my local place is gonna trade me the P-47 they just got in for one of my heli's    I'll look it over real good again to make sure no bobo's
Joe
Hide Signatures
(in reply to njmheli)
       Post #: 277
RE: Hangar 9 30cc P-47 Build Thread - 6/14/2012 4:01 AM
Ron101
Score: 116
Last Login: 5/19/2013
Status: offline
Real Happy to report my replacement showed up and is in very good condition... no oil mess and everything looks great!
Can't wait to dig into this one and get going
Thanks John and Horizon for taking care of me on this
_____________________________
"It''''s not personal, Sonny. It''''s strictly business."
Hide Signatures
(in reply to lablover)
       Post #: 278
RE: Hangar 9 30cc P-47 Build Thread - 6/14/2012 5:24 AM
Peter_OZ
Score: 108
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: John Redman
So with the mini bulkheads opened up to accept the wires we installed teh retract units. These drop right in as the model is designed to fit these retracts. Simple step. 4 bolts with some threadlock and a 7/64 ball driver for the 6-32 bolts and the unit was installed.
pic #1 shows the unit bolted into the wing.
Pic #2 shows the wire harness being routed through the mini bulkheads keeping it out of the way.
Pic #3 shows the harness being directed out of the wing. A 3 inch extension was used to extend the harness out side of the wing panel. You will note the heat shrink tubing over the harness to ensure it won't come apart at any time during operation.
Be nice if the retracts were in scale location. Understand far easier to mass produce with simple spar system. Just my scale prejudices showing
< Message edited by Peter_OZ -- 6/14/2012 6:33 AM >
fun police have struck again
Hide Signatures
(in reply to John Redman)
       Post #: 279
RE: Hangar 9 30cc P-47 Build Thread - 6/14/2012 3:52 PM
Duplicator41
Score: 100
Status: offline
I'm with you on this. EMS seems to be able to do it at a much lesser cost. (and with a fibreglass fuselage)
Cheers,
So many planes, so little time
Hide Signatures
(in reply to Peter_OZ)
       Post #: 280
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 12:34 PM
John Redman
Score: 117
Status: offline
A few notes here.
@ Ron101, glad all is good. I am sorry it took as long as it did.
@ njmheli, In speaking with Robart, no units have been deliverd with no holes in the lower strut. I am guessing you have a set of the one that were designed around the original 150 P-47 (green one). Those are slightly different than the new ones. The ones designed for the original did not have holes in the lower strut.
@ lablover, I am pretty sure a 50cc gaser would fit in the cowl all day long. Depending on carb location it may stick out (side mounted carb) and possibly muffler.
@ Peter Oz, yes the gear have been adjusted as we were not interested in $600+ retracts. The real P-47 had the main gear strut decompressurize and collapse during retraction. If we put the main units in the scale location then we would need to duplicate the collapsable strut. Great program for a Top Gun model, but not really for a mass produced ARF. So although not fully scale, they are done very similar to other P-47's on the market.
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
(in reply to Duplicator41)
       Post #: 281
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 2:48 PM
Doug Andre
Score: 100
Last Login: 5/6/2013
Status: offline
John,
Any update on the delivery of our electric retracts, scale cockpit and EP motor box and tray?  Still hoping that October date was an error.
Hide Signatures
       Post #: 282
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 3:59 PM
lablover
Score: 103
Status: offline
Those of you going electric on this baby....How would you think the eflite 160 would compare to a gas setup...I mean, what CC gas would equal the eflite 160?
I want to try electric but would hate to get all the goods and go...YUK, it's too slow.  John, you mentioned the Evo 40 did a fair job at pulling her around.  If you had to do it over, what would you go with.  I'm in Michigan so sea level is not an issue.  I'd like to have some spare speed.  I also don't want to have to try to modify the daylights out of the firewall etc to get a motor to fit.  Any other evo as a drop in choice?
Hide Signatures
(in reply to Doug Andre)
       Post #: 283
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 4:09 PM
glazier808
Score: 291
Status: offline
I'm using the 160 in three 80+inch planes, all under 20lbs...
they all are very fast, one almost too fast.
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
       Post #: 284
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 4:21 PM
lablover
Score: 103
Status: offline
thats good
Now, waiting on the electric box and tray....hmmmmmmmm
Hide Signatures
(in reply to glazier808)
       Post #: 285
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 8:07 PM
vik
Score: 100
Status: offline
quote:
ORIGINAL: lablover
Axi5330 is almost identical
So 35-45cc http://modelmotors.cz/index.php?page=61&product=5330&serie=24&line=GOLD
Hide Signatures
       Post #: 286
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 8:11 PM
glazier808
Score: 291
Status: offline
I love the AXI motors(I have two 2820/10 and 5345-14), but for us here in the USA, that motor is almost twice the cost of the eflight.
Casey
Hide Signatures
(in reply to vik)
       Post #: 287
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 8:15 PM
glazier808
Score: 291
Status: offline
here ya go...
http://www.horizonhobby.com/products/power-160-brushless-outrunner-motor-245kv-EFLM4160A
http://www.hobby-lobby.com/brushless_axi5330.htm
Casey
Hide Signatures
       Post #: 288
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 8:36 PM
nioa
Score: 100
Last Login: 3/19/2013
Status: offline
quote:
ORIGINAL: glazier808
Casey
I have four Tacon 1.60 motors, and ESC's that are looking for a home. Casey, which three planes do you have?
Nick
Hide Signatures
       Post #: 289
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 8:45 PM
AZThud
Score: 100
Status: offline
I have 2 20 pound planes flying on e-Flite 160 motors, and ESM-LA-7 that I run on 12S and the older Hanger 9 Razorback that I run off on 10S    Both perform well over scale in climb and speed.  Here are links to some Video of them.    The P-47 has a Bendini Sound System under the cowl.
P-47 Eflite 160 80 Amp Castle HV2 10S Xoar 18X12 prop
http://www.movingmoment.net/Rick2.wmv
ESM LA-7
Eflite 160 120 Amp Castle HV2 10S Xoar 16X10 prop  (16X12) simply too fast :-)
http://www.movingmoment.net/La7.wmv
Hide Signatures
       Post #: 290
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 10:22 PM
glazier808
Score: 291
Status: offline
quote:
ORIGINAL: nioa
Casey
Nick
I have,
ESM 109E
ESM 80" P-39
Fliteskin 109F (unfinished)
basically the 160 is a great motor for planes up to 20 lbs(flying scale) and about 16.5-17lbs for 3d.
Most all of the ESM's smaller line can be flown with a Power 110 or 160(for you speed freaks) alot of their larger 80" planes fly quite well on the 160 as well. I'm currently doing a Lien/Holman 190A8, that if I can keep under 19lbs, I'll put the 160 in as well. If not, I have the AXI 5345-14 for it.
I would imagine the 160 would make this a rocket...what is the AUW? If its under 17, get ready to hover lol
Casey
in my opinion the power series motors from Eflite are priced quite well, run like wild beasts, and last.... now thats hard to beat.
Hide Signatures
(in reply to nioa)
       Post #: 291
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 10:29 PM
glazier808
Score: 291
Status: offline
quote:
ORIGINAL: AZThud
ESM LA-7
very nice!
Hide Signatures
(in reply to AZThud)
       Post #: 292
RE: Hangar 9 30cc P-47 Build Thread - 6/15/2012 10:36 PM
AZThud
Score: 100
Status: offline
Thanks, much appreciated.
I just picked up an ESM P-39 and am wondering if yours is also electric?
I have Ty's cockpit and am looking for idea's regarding battery placement and am open to any idea's
Cheers
Hide Signatures
       Post #: 293
RE: Hangar 9 30cc P-47 Build Thread - 6/16/2012 3:16 AM
hairy46
Score: 183
Status: offline
Just found this thread, I'm all ears!
Hide Signatures
(in reply to P47Pilot)
       Post #: 294
RE: Hangar 9 30cc P-47 Build Thread - 6/16/2012 4:14 AM
Ron101
Score: 116
Status: offline
I'm going electric on mine and talked with the guys from aeromodel (hacker dealer) down at the AMA show. They have the older razor back version setup as a demo plane.
I was told if you want a rocket ship go with the HAcker A60-16L with a 20X15 prop... 12s 65c 5000 mah thunder power packs and a Castle ICE 160 HV 2
So that is the setup I bought for mine.... they said it's in the 130 mph range
I have ran hacker motors in many of my planes and just love them! I have the A60-18L on 12s with a 24x 12 prop in a 30% extra, The power is unreal and makes a DA 50 look silly
I also have the AXI 5345/14 in my 26.5 pound GS P-51 on 12s and it's just a beast!! it would be way to much motor for this plane
I'll be sure to get video so you guys can what the set up can do .... but I think it's going to be really fast with all that pitch
Hide Signatures
(in reply to hairy46)
       Post #: 295
RE: Hangar 9 30cc P-47 Build Thread - 6/16/2012 7:20 AM
bbrundle
Score: 100
Status: offline
An update on the retracts and the optional parts i.e. cockpit tub and EP power.
The retracts were delivered personally by the owner of Robart Friday so these should be processed and ready for shipping next week.
The cockpit tub was missing the correct paper instrument panel, but these were received earlier this past week so these should be in stock and also ready for shipping next week.
The EP battery trays are enroute to us and we should have these in stock within a couple of weeks. Sorry for the delay on this, but the item failed QA and we are rushing new parts to correct the issue.
Bill Brundle
Hangar 9 Senior Product Developer,
Hide Signatures
       Post #: 296
RE: Hangar 9 30cc P-47 Build Thread - 6/16/2012 10:35 AM
lablover
Score: 103
Status: offline
AWESOME NEWS
Picking mine up today after the pmac warbird event here in Michigan.  Looks like a E set up for me.
Hide Signatures
(in reply to bbrundle)
       Post #: 297
RE: Hangar 9 30cc P-47 Build Thread - 6/16/2012 11:35 AM
Doug Andre
Score: 100
Status: offline
Bill,
Thanks for the update on parts delivery.   Looking forward to those retracts!
Hide Signatures
       Post #: 298
RE: Hangar 9 30cc P-47 Build Thread - 6/17/2012 3:12 PM
John Redman
Score: 117
Status: offline
@ lablover, as for different engines out there not sure yet. I am confident you could throw the Evo 50 up front and it would haul the mail. Was talking and flying this past week and found a new prop for the 40. Seems an APC 18.5 x 10.25 pattern prop brought it to life! This was used by the engine guy (Pete Bergstrom) here and we were quite impressed with its performance. I will order one up and fly it to see how the difference feels. Looks are very promising.
I would still do the model in gas for me personally. I love electric but prefer to have my larger models in gas. My 15 year old son flies and there is no way I could afford batteries to feed him. When he goes to the field our models are constantly up flying cover. He burns through a gallon of gas in an afternoon easily, if not 2 gallons. By the way he fell in love with the P-47 the other day when I gave him the keys!
< Message edited by John Redman -- 6/17/2012 10:47 PM >
John Redman
Hide Signatures
       Post #: 299
RE: Hangar 9 30cc P-47 Build Thread - 6/17/2012 3:17 PM
glazier808
Score: 291
Status: offline
lucky boy!!! happy fathers day John!
Casey
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.676RCU1
