Question about running brushless w/ 72mhz    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Question about running brushless w/ 72mhz
Page: [1]
Login
Question about running brushless w/ 72mhz - 1/15/2012 5:06 PM
RBTHNTR64
Last Login: 7/26/2012
Status: offline
Guys,
Back in the day when I was flying brushed motors we added noise suppression to the leads. I have been out of the hobby for several years and getting back in.
I know all about the 2.4ghz stuff, but I am not ready to stop using my 72 gear. Is there any advise as to what precautions should be taken when using the brushless systems with the 72mhz radios? BTW, I do have two Spektrum radios in addition to my old stuff. Any help is greatly appreciated!
Dave
Hide Signatures
       Post #: 1
RE: Question about running brushless w/ 72mhz - 1/15/2012 7:43 PM
blvdbuzzard
Last Login: 5/11/2013
Status: offline
I run brushless with my 72 gear without an issue. In one install, I had the Rx on top of the ESC and never had a glitch.
Buzz.
Hide Signatures
(in reply to RBTHNTR64)
       Post #: 2
RE: Question about running brushless w/ 72mhz - 1/15/2012 8:34 PM
exeter_acres
Last Login: 9/24/2012
Status: offline
Assuming you do a good clean install.. perform a range check and you should be fine...
some folks run Ferrite Rings on the wire from the ESC to the throttle channel to help isolate it, but it isn't required.
_____________________________
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 3
RE: Question about running brushless w/ 72mhz - 1/16/2012 6:53 AM
HANGTIME II
Last Login: 6/19/2012
Status: offline
Im running the same older radio equipment (old school lol) with a new plane and no issues. Its like recycling, keeping the old stuff out of the junkyard . Cheers
Hide Signatures
(in reply to exeter_acres)
       Post #: 4
RE: Question about running brushless w/ 72mhz - 1/22/2012 7:26 AM
DustBen
Last Login: 2/18/2013
Status: offline
YOU CAN'T do it!
You'll have to sell me all your old 72mhz stuff... real cheap!
Nah, just kidding. I run my old Airtronics stuff on 72mhz flying electrics and just love that 2.4 ghz came along and thinned out the herds on 72 mhz!
Hide Signatures
(in reply to HANGTIME II)
       Post #: 5
RE: Question about running brushless w/ 72mhz - 2/12/2012 3:38 AM
HANGTIME II
Status: offline
Im running the old school stuff as well (given the rediculouse cost of it back then) and I have found no issues with the new batteries, brushless motors or speed controllers. Just nice to see its more cash friendly for people to get into the sport. Cheers!
Hide Signatures
       Post #: 6
RE: Question about running brushless w/ 72mhz - 2/13/2012 10:27 PM
Jsbrittain
Last Login: 9/11/2012
Status: offline
I also have old school radio systems(72mhz) I used to fly and getting back into it myself my question is ... Does one battery power the whole system or is there a seperate battery for the servos so if there is a failure in the motor battery I still have power to fly plane ??
Hide Signatures
       Post #: 7
RE: Question about running brushless w/ 72mhz - 2/14/2012 3:48 AM
HANGTIME II
Status: offline
Hide Signatures
(in reply to Jsbrittain)
       Post #: 8
RE: Question about running brushless w/ 72mhz - 2/14/2012 3:49 AM
HANGTIME II
Status: offline
The main battery runs the whole system. The speed controller handles the low battery cut off. You will maintain the radio as long as you watch for motor pulsing warning and land asap. I havent experienced that yet as I set a stopwatch at 7 min for my 2200 mh and its in the safe zone. Hope this helps.
Hide Signatures
       Post #: 9
RE: Question about running brushless w/ 72mhz - 2/14/2012 4:08 AM
Jsbrittain
Status: offline
Thanx Hangtime
Hide Signatures
       Post #: 10
RE: Question about running brushless w/ 72mhz - 2/15/2012 5:57 PM
flytreetimes
Status: offline
 i always use the ferrite ring supplied with most Esc when running 72 mhz. I even leave them on with 2.4. can't hurt to help kill any noise issues, right.
Smaller Esc systems, 2,3,4S typically use the built in Bec to run the Rx with 3-4 small servos. I use a separate Bec (higher Amp rating) with its own 2S battery to Rx for larger systems on both 72 and 2.4 systems. Look for ESC with switching Bec in smaller sizes, typically 2-3 A will handle 2-4 micros without issue. If you use digital servos, you may want  to consider a separate Bec or a small Rx pack, use 6 volts, not 4.8, especially on 2.4 setups.  Fwiw  flytreetimes
Hide Signatures
       Post #: 11
RE: Question about running brushless w/ 72mhz - 2/16/2012 3:35 AM
HANGTIME II
Status: offline
Thx Flytreetimes, good info will jot that down.
Hide Signatures
(in reply to flytreetimes)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.309RCU1
