Help with webra TN carb    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Help with webra TN carb
Page: [1]
Login
Help with webra TN carb - 1/16/2012 12:49 AM
cremation101
Score: 100
Last Login: 5/21/2013
Status: offline
I got this webra speed 50 and it runs great. I just cant figure out how the carb barrel is supposed to close so the engine will stop . Instead of having to pinch or pull the fuel line. It will run about 4k for a moment then load up a bit down to just over 3k.
What is the third screw with a spring under it for?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
coño carajo
Hide Signatures
       Post #: 1
RE: Help with webra TN carb - 1/16/2012 12:51 AM
cremation101
Score: 100
Status: offline
Oops, I dindnt mean to put the same pic three times.
Any one have an idea?
coño carajo
Hide Signatures
(in reply to cremation101)
       Post #: 2
RE: Help with webra TN carb - 1/16/2012 1:29 AM
Hobbsy
Score: 650
Last Login: 5/22/2013
Status: offline
That is the speed adjustment screw and appears to be screwed in too far. Back it out whiel putting a little pressure on the throttle and watch the barrel close. It should be less than 1/32nd" open at idle.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 3
RE: Help with webra TN carb - 1/16/2012 4:09 PM
jaka
Score: 158
Status: offline
Hi!
It's not the speed adjustment screw!
You have the older typ of TN carb and the small screw adjusts the throttle drum position. You must turn it out so you can close the throttle drum with the throttle servo. Simple as that!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 4
RE: Help with webra TN carb - 1/16/2012 4:37 PM
Mr Cox
Score: 102
Status: offline
I think you are both referring to the same thing, i.e. the "idle speed" or "throttle stop" screw...
The screw needs to come out a bit.
Hide Signatures
(in reply to jaka)
       Post #: 5
RE: Help with webra TN carb - 1/16/2012 7:21 PM
Hobbsy
Score: 650
Status: offline
Jan, you just did a repeat of what I said, when you change how far the barrel goes closed you change the idle speed. Simple as that.
Hide Signatures
(in reply to jaka)
       Post #: 6
RE: Help with webra TN carb - 1/16/2012 11:28 PM
cremation101
Score: 100
Status: offline
Thank you, gentlemen. I went and tried it after reading. It's working good now. Don't have time to go and run it but i got the barrel closed by turning the screw with a spring out a little.
coño carajo
Hide Signatures
(in reply to Hobbsy)
       Post #: 7
RE: Help with webra TN carb - 1/17/2012 10:52 AM
Dauntae
Score: 105
Status: offline
I've got that exact same engine and that same carb on it too, Also have that carb on a speed 60 and they run well. Neither of the Webra's like any nitro however (they tend to over heat with nitro) I run them on FIA fuel (0% nitro) and they run great on it and it's much cheaper than the other fuel too. Have fun with that Webra, I love these engines. Need to find a good airframe for the 50 though.
Dauntae
I laugh in the face of danger... Then I hide until it goes away
Hide Signatures
       Post #: 8
RE: Help with webra TN carb - 1/17/2012 4:47 PM
jaka
Score: 158
Status: offline
Hi!
Webra engines can of course be run on nitro fuel! 5% nitro is just perfect! But of course they run nearly as good on 80/20 fuel (FAI fuel).
Hide Signatures
(in reply to Dauntae)
       Post #: 9
RE: Help with webra TN carb - 1/17/2012 11:50 PM
NM2K
Score: 161
Status: offline
I have to pull my older Webra .50 GT out and look at it. It has a TN carb, but which model is a good question. No more Dynamess carbs for me. Once was too many.
A while back I said I wish I had a Webra .32 (right now). I did have two Webra .32, but both were NIB and both were sold to customers. So, I wasn't lying. I did "have" them, but they were just passing through.
Ed Cregger
"Practice makes prefect"
Hide Signatures
(in reply to jaka)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Help with webra TN carb
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
