RE: Any thoughts about these servos for Gas planes?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Any thoughts about these servos for Gas planes?
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 10:02 AM
3136
Score: 135
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: juanjulian
The hobbico line has work for me, and are made by hitec or futaba.
Can anyone confirm this?
_____________________________
regards Mark
Hide Signatures
(in reply to juanjulian)
       Post #: 51
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 10:39 AM
AJsToyz
Score: 304
Last Login: 5/22/2013
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXANT4&P=0
Check this servo out then check the replacement parts for it. Some of the stuff is now repacked with the Hobbico brand but not all.
Andy
www.Deathbychina.com
Hide Signatures
(in reply to 3136)
       Post #: 52
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 1:15 PM
w8ye
Score: 318
Status: offline
I have a couple dozen that are Futaba 3003's. You peel the sticker off and they say Futaba on them. look at the replacement parts?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUK84&P=ML
I also have two that are Hitec 425's
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to AJsToyz)
       Post #: 53
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 1:25 PM
suburban95
Score: 100
Status: offline
Stay away from the Tower Pro servos from Nitro Plane/Hobby Partz. My brother had them in a Sig Four Star 120, during the 2nd flight he couldn't keep the plane level upon landing (sure Luck that he got it back on the ground) he found that the right aileron servo would not center. He had same servos in a Pete N Poke and the elevator servo went full Up upon take off and stuck there sufface to say the Pete N Poke did a nice loop to close to the ground and he trashed the crankshaft on the Saito he had in it. Buy name brand servo's.
Hide Signatures
(in reply to w8ye)
       Post #: 54
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 1:29 PM
mike31
Score: 114
Status: offline
Hi Tech servos. Just plain the best overall.
Hide Signatures
(in reply to armody)
       Post #: 55
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 1:47 PM
Rocketman_
Score: 110
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: pdm52956
Everyone is going to have their own opinion, and there's mine. I will NEVER go cheap.........er, I mean inexpensive ........on servos again!
quote:
ORIGINAL: NM2K
As someone else states in this forum, servos are not the place to save money.
Don't people buy Hitec servos instead of Futaba and JR because Hitec's are cheap?
NORTHEAST R/C MODEL CLUB
http://www.nrcmc.org/
Hide Signatures
(in reply to mike31)
       Post #: 56
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 2:16 PM
pdm52956
Score: 140
Status: offline
quote:
ORIGINAL: Rocketman_
quote:
ORIGINAL: pdm52956
quote:
ORIGINAL: NM2K
Personally, the biggest reason I have always used Hitecs are because that's what I started with and have never had issues with. Well, that's not true. My first plane had JR ST-47 standards in it. Never had any issues there either.
Kind of like going to a restaurant to get dinner. If you find something there that you really like, next time there's a good chance you'll eat that same meal again.
Anyway, cheap is relative to that individual.
Hide Signatures
(in reply to Rocketman_)
       Post #: 57
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 2:58 PM
w8ye
Score: 318
Status: offline
The "Tower Pro" servo is not related to Tower Hobbies
The Hitec 300 servos had problematic reference pots in them and were trouble magnets.
The Hitec 325's were OK
I used a lot of 420 and 425's and never had a problem with one.
Original AMA #31261
Hide Signatures
(in reply to pdm52956)
       Post #: 58
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 3:07 PM
nute12
Score: 115
Last Login: 4/27/2013
Status: offline
for what it is worth... My nickle in the pot. Besides im snowed in and got nuthin better to do.
At least use a metal gear servos on the ele.... strip the ele servo and yer done. I would use mg on everything. its a 10 pound missile looking for a reason to rekit itself
Battery: the AA cells may not put out the amperage required. if you draw too hard on it voltage will drop and a "brownout" will ensue. If you have a capable charger look into the life or a123 batts of the same mAh rating. (A123 is just a quality brand of life technology) If you dont have the charger go for the larger Nimh cell 4/5 A? cant remember i went li- on everything but ignition a few years back. The larger cell has a lower internal resistance and will keep the voltage up under a heavier load.
biggest deal on the servos is to buy a decent one, metal gear for ele minimum and to meet or exceed the manuf. spec. for the plane. (red the online manual...didnt see specs.)
Throttle servo, dont run cheap there....they take alot of vibration. get a decent servo for it. I use metal gear on all mine. a 625mg works well, pretty fast and fairly strong. I would use 625's on it all. they are still strong enuff at 6v and quicker. same price tho, thats up to you and am sure i will git nailed for telling you to use to weak of a servo.
another servo to look at is the hd9150, digital around 200 oz.in. torque. and about 2 cents more than a 645. have over 100 flights on my 30 cc ulti with em and they have worked as advertised without a hitch. The 1501 is good servo also it has more torque, but is analog and does not center as well. Friend is running them on a 90" edge with a g-62. been solid for him all season. probably 75 flights they run about 23 bucks bought state side, 13 if ya order offshore.
Hide Signatures
(in reply to pmerritt)
       Post #: 59
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 3:37 PM
Texastbird
Score: 150
Status: offline
If you are trying to fly on a budget, you might try these servos. They are rebadged HD Power servos.
http://www.hobbyking.com/hobbyking/store/__18919__Turnigy_Metal_Gear_Servo_60g_15_5kg_16sec_USA_Warehouse_.html
Hide Signatures
(in reply to nute12)
       Post #: 60
pdm52956
Score: 140
Status: offline
quote:
ORIGINAL: nute12
Wasn't going to go there but that's the servo that just about brought down my 50cc edge~
Fried a motor on the third flight and one elevator half froze up. That was fun.
Like I said before, won't go inexpensive again and..........your mileage may vary.
Oh, I still have the other ones but haven't found anyone local that wants them! Not even for free!
Hide Signatures
       Post #: 61
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 3:57 PM
Texastbird
Score: 150
Status: offline
Yeah, that's the problem with Chinese electrical type stuff. Its a crap shoot as to initial quality. I have a set of the 9150s and all I have done with them so far is cycle them for a couple of hours to break them in and try to weed out any faulty ones. So far they are looking good. I might not have mentioned this brand but on another forum the HDs are picking up a pretty solid following from some experienced flyers.
And not to start a brand war, but I saw two of my friends brand new $95 Futaba servos malfunction right out of the box. So I think it can happen to any brand now days. How long a servo will last is a different story.
Hide Signatures
       Post #: 62
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 4:14 PM
pdm52956
Score: 140
Status: offline
That's the exact reason I wasn't going to mention what brand I had the issue with. They all fail.........sometime. No one manufacturer is beyond it. Law of averages plays a large roll too. I mean how many Hitecs are out there versus Power HD?
I think I may know which forum you're referring to because there is another thread there that I started based on the Power HD thread that was trying to get a generalized idea as to failure rates between brands. You know, Hitec failed the most when you compared what input was given. On the other hand, Hitec also was the most widely used.
I don't mean to knock Power HD as yes, there are a lot of people that report good experiences from them. I just had a bad one and prefer not to visit that place again.
Hide Signatures
(in reply to Texastbird)
       Post #: 63
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 5:01 PM
raptureboy
Score: 178
Status: offline
Go with the metal gear servos on the throttle and the crittical flight controls and for the best battery info and quality packs http://www.hangtimes.com/nobsbatteries.html There is more to selecting the correct battery than size, volts or chemistry. godo info even if you don't buy from them.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 64
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 5:16 PM
juanjulian
Score: 100
Status: offline
For me has worked trying to get the most bang for the money, but some times you get bitten.
First do a research in the forums, for sure someone has already tried and posted the good or bad. Don´t believe everything your read since we don´t know the experience of the person writing. (don´t believe me) There is a web site from a kiwi guy tha does research of  new products wis interesting information http://www.rcmodelreviews.com
Test the product before using it., put servo in a surface that is not as critacal as elevator,put  it on a trainer or plane you don´t care any more.
Buy from a trusted dealer so you can have guarranty.
Take a risk you can afort
Know were to buy what.
I bought the Power HD 15001 since had more good than bad reports, opened one to ispect the integrety and seemed fine, places  it irudder in  my Mojo 60 Saito 100, then put another in the elvator and worked, BUT it does not center properly so the plane does not fly level, needed constant inputs.  Will use them for air brake, flaps, wheel steering etc. Think rebranded servors are good option.(got bitten, each servo was 15)
Chargers why pay 100 or more for a brand charger when a 25 china charger does more for less.  The worst charger I have  had was te Triton 2 and the equinox balancer was terrible. Buy from a trusted provider since guaranty counts no matter the price. My Hobby King  Accucell 8 came defect from them and unlless you ship back you are covered. I  fixed it  my self and can say is a better charger than triton 2 for less.(Got bitten, and luckuy fix)
Stores have found with good products
TOWER HOBBIE ( building materials, rc equipment, and planes) to save you need to hold on on their offers.
Radical RC (wires, conectors,RX TX batteries,  electric rc kits)
Ep buddy ( A123 batteries, chargers with guaranty at good prices)
AT YOUR OWN RISK
Hobby King ( wires, conectors, accesories, LIPO bateries)
Will not buy a electronic unless I{m willing to take de risk.
Cheers
Juan
Hide Signatures
       Post #: 65
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 5:18 PM
armody
Score: 114
Status: offline
For the rudder I chose this servo http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ89&P=ML
For aileron, elevator May I go with these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNRK1&P=7
Or These http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXN586&P=ML
Everything fails and I'm not afraid of it cos nothing is perfect, people cuss out on Evolution engines, and some people love it, some people cuss out on JBA engines some love it, people have various experiences on various things. All I want to know that out of these servos from Hobbico and Hitec which are gonna work. I've never used Hobbico, and I'm using mostly Hitec's stuff and never let me down. I love Hitec's Aurora 9 2.4 GHz with Optima 7 receiver which I would use, so, may I go with this HB425 Hitec just like w8ye said?
I WANT COLLECTIVE OPINION
Mody
It''s great2 keep flying invariably. Hitec Aurora9 2.4 GHz, Yak 54-120 /XYZ20, Kadet II, U-Sport Kits, MXS-R RCG20 (AMA Mem)
Hide Signatures
(in reply to raptureboy)
       Post #: 66
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 5:36 PM
w8ye
Score: 318
Status: offline
Go with the CS-126 servo on the elevator and ailerons
Original AMA #31261
Hide Signatures
       Post #: 67
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 7:55 PM
armody
Score: 114
Status: offline
w8ye, Juan,
Thanks a lot for your advices.
I'm gonna go on and buy Hobbico's CS-126 Servos, still good priced and within my range, so I ain't gonna go cheap on servos here.
Thanks a lot guys
Mody
Hide Signatures
(in reply to w8ye)
       Post #: 68
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 8:18 PM
armody
Score: 114
Status: offline
Combination of digital servos of Hobbico's CS-126 and Hitec 645MG analog servo would make a difference or not?
Hide Signatures
       Post #: 69
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 8:37 PM
armody
Score: 114
Status: offline
One more question,
I hope you guys did not get bored of my questions lol
In order to use 2 servos on elevator, one of the servo has to be reversed servo or I have to do some P mixing or something else on my radio which is Hitec's Aurora 9 2.4 GHz.
Mody
Hide Signatures
       Post #: 70
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 8:48 PM
BarracudaHockey
Score: 280
Status: offline
I dont know the exact programming sequence but I know that radio does it internally.
If you use a pmix, make sure the trim works on both halves.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 71
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 9:36 PM
SpinnerRow
Score: 152
Status: offline
I use Power HD DS090M servers which compare VERY favorably to Hitech HS-5625s. I have some 5625s as well and are a great servo but the DS090Ms are about $20 cheaper, more powerful and center better. I've been flying the DS090Ms in a DLE 20 Profile and a DLE 20 powered Great Planes PT-17.
http://youtu.be/WH5daGpNow0
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
(in reply to 3136)
       Post #: 72
RE: Any thoughts about these servos for Gas planes? - 1/18/2012 10:39 PM
Tim Holley
Score: 100
Last Login: 3/21/2013
Status: offline
Check out the Power HD servo
Hide Signatures
       Post #: 73
RE: Any thoughts about these servos for Gas planes? - 1/19/2012 12:08 AM
aerialsports
Score: 100
Status: offline
If going on a budget I would recommend finding some name brand metal gear servos here on RCU. If you look on Hitecs web site they even advice you against using karbonite geared servos in a gasser do to vibration wear on the gears.. There is another servo by the name of SAVOX in which we have been using in a gassers lately with great success, they are digital and priced low. they are the ones that make the align brand servos for the helis.
Hide Signatures
(in reply to 3136)
       Post #: 74
RE: Any thoughts about these servos for Gas planes? - 1/19/2012 12:13 AM
aerialsports
Score: 100
Status: offline
If you are using the new hitec aurora 9 it has dual servo mix built into the programing and will actually ask if your using dual servos when you go through the setup. There for you will not need a servo reverser or anything..
Hide Signatures
(in reply to aerialsports)
       Post #: 75
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Any thoughts about these servos for Gas planes?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
