How to keep castor from seperating in cold?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> How to keep castor from seperating in cold? Page: [1]
Login
How to keep castor from seperating in cold? - 1/16/2012 3:21 PM
Max_Power
Score: 127
Last Login: 5/9/2013
Status: offline
Ok, I have some high nitro fuel I mixed for my small 1/2a engines for when I want them REALLY HOT . I had a jug of powermaster 50/50 methanol/nitromethane like they used to sell. I combined 8/10 of a gallon of this to 2/10 of a gallon of sig castor. I figure I should be pretty close to 40% nitro and 20% castor fuel mix.
Here in Minnesota when it is cold the oil seperates and rises to the top. I have read that with high nitro percentages the oil will seperate like this and unless you want to be constantly mixing it needs a "co-solvent" How normal is my situation and what can be done about it? What is a good co-solvent? I'd like to make this work as it will be all the high% fuel I will need for life running small engines! Thanks in advance.
_____________________________
"A guy told me the other day I must be very smart,......I told him "No!, I''m REALLY dumb, But learning from my mistakes!!""
Hide Signatures
       Post #: 1
RE: How to keep castor from seperating in cold? - 1/16/2012 5:08 PM
gkamysz
Score: 120
Last Login: 2/6/2012
Status: offline
Typically the answer is synthetic oil.
How long has your castor been sitting around? I've had problems with old castor.
Greg
Hide Signatures
(in reply to Max_Power)
       Post #: 2
RE: How to keep castor from seperating in cold? - 1/16/2012 7:00 PM
pe reivers
Score: 646
Last Login: 6/18/2013
Status: offline
Add some acetone. This helps as solving agent. Keeping the fuel above freezing when not in use also helps.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to gkamysz)
       Post #: 3
RE: How to keep castor from seperating in cold? - 1/17/2012 1:13 AM
downunder
Score: 123
Last Login: 6/19/2013
Status: offline
I suspect your fuel is hovering right on the edge where castor is no longer soluble in nitro and I'm guessing this "edge" may be temperature dependent in that with warmer fuel the oil may not seperate out. Try what pe said or you could try ether which is a very good solvent but tends to evaporate out rather quickly. Or just fly on warmer days .
Hide Signatures
(in reply to pe reivers)
       Post #: 4
RE: How to keep castor from seperating in cold? - 1/17/2012 4:19 AM
Max_Power
Score: 127
Status: offline
How much acetone are we talking PE? 1 or 2%?....I did move it into the house out of the cold garage and it seems to be better. I don't use it very often but like to keep it as a "stash" of the stout stuff. The castor is about 2 years old, as is the nitro/methanol. Thanks for the replies...I think I may try some acetone.
Hide Signatures
(in reply to downunder)
       Post #: 5
RE: How to keep castor from seperating in cold? - 1/17/2012 11:47 AM
pe reivers
Score: 646
Status: offline
The norm is about 3%. More will harden your silicone fuel lines too much.
Because Acetone evaporates better than methanol at low temperatures, it also improves winter wonderland engine handling, especially the cold starts.
PS
Ether in glow fuel causes knock, unless your compression ratio is very low. Not good either way.
Hide Signatures
       Post #: 6
RE: How to keep castor from seperating in cold? - 2/11/2012 4:01 PM
aspeed
Score: 105
Status: offline
I heard a detergent mixes oil and water in high school chemistry.  I am not sure I would put it in glow fuel with a motor I care about though.  Most of them are water based.  Might be an experiment if you have nothing to do.  It may foam up too much or take too much to have an effect. ( I failed grade 12 chemistry too if you really want to know.)
Hide Signatures
       Post #: 7
RE: How to keep castor from seperating in cold? - 2/11/2012 4:09 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: aspeed
Our oil and fuel is soluble in water so detergent really in't required.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
(in reply to aspeed)
       Post #: 8
RE: How to keep castor from seperating in cold? - 2/11/2012 10:21 PM
aspeed
Score: 105
Status: offline
Unless the detergent makes it more soluble so it doesn't separate.  I was worried about the water in the detergent ruining the motor.
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 9
RE: How to keep castor from seperating in cold? - 2/11/2012 11:03 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: aspeed
No the detergent would not be any help.  Acetone might.
Hide Signatures
       Post #: 10
RE: How to keep castor from seperating in cold? - 2/12/2012 12:58 AM
Max_Power
Score: 127
Status: offline
The Acetone worked well...as did a slightly warmer storage area, Honestly I'd just shake it up right before I use it before I started adding anything too weird or water to the stuff. I think if it were any weaker than 40% It would'nt have done it? Todd
Hide Signatures
       Post #: 11
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> How to keep castor from seperating in cold?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
