"Stihl" fuel line - seems flexible - does anyone know anything about it? Pix included    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> "Stihl" fuel line - seems flexible - does anyone know anything about it? Pix included
Page: [1]
Login
"Stihl" fuel line - seems flexible - does anyone know a... - 1/16/2012 10:33 PM
SkidMan
Score: 105
Last Login: 4/24/2013
Status: offline
I went to the premium/professional mower shop in my town today searching for Oregon 07-266 tubing and felt clunks. While they didn't have the tubing I was looking for, knowing what I wanted to use it for, the counter guy showed me some black tubing that he described as what Stihl was using in their equipment now. I had never seen it before but the guy at the shop said that it seems to stay pretty flexible. I bough a couple feet to give it a try.
Does anyone have any experience or knowledge of it?
Here is a picture of it:
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: - 1/17/2012 12:00 AM
av8tor1977
Score: 665
Last Login: 5/18/2013
Status: offline
I buy big lots of used yard equipment. Some I repair and sell, some I pirate the engines for airplanes. The Stihl fuel lines are the best out of all the brands I have serviced; even better than Echo. If this new line you got is anything like the old stuff; it's golden.
Let us know how it works,
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to SkidMan)
       Post #: 2
RE: RE: - 1/17/2012 1:46 AM
SkidMan
Score: 105
Status: offline
quote:
ORIGINAL: av8tor1977
AV8TOR
Sweet. Thanks for letting me know.
I've just plumbed a new Fiji Water gas tank with it. I'll probably use tygon to run from the tank to the engine so I can see if I'm sucking air.
I hope to have some gas in it tomorrow.
Paul
Hide Signatures
(in reply to av8tor1977)
       Post #: 3
RE: - 1/17/2012 2:52 AM
MercerAUST
Score: 120
Last Login: 2/14/2013
Status: offline
I use that style and it is good and flexible. However, it does stretch after time and its best to use cable ties (smallest size) inside the fuel bottle to stop anything falling off. It can also get brittle after several years of use and split. Not being transparent, it is tempting to use Tygon on the final tube to the carby so you can eyeball any air in the line.
Hide Signatures
       Post #: 4
RE: - 1/17/2012 1:05 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
Possibly that's re-badged 'Viton' tubing.
If so, it's top notch stuff!
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 5
RE: RE: - 1/17/2012 1:56 PM
captinjohn
Score: 247
Status: offline
Most rubber products made now do not last like they did years ago.  My opinion is that the makers like it that way.  That way they can keep selling you more rubber made products. Price some of the small rubber parts  found on many products. The prce is a all out ripp-off.  Like the cable covers on a motorcycle.  Most anything rubber is way over priced.
Its kinda like selling a car and the dealers make more $$$ on service and replacing whatever goes bad. If they plan for more parts to go bad....the more they make.    I put this under the heading of.... The "fleecing of America"   Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to a1pcfixer)
       Post #: 6
RE: RE: - 1/17/2012 4:10 PM
a1pcfixer
Score: 168
Status: offline
Very true!
Simplest easiest item to note such change is the rubber bands we use to hold down wings on some models.
Used to be true rubber, now it's a synthetic mix of crap.
Jim L.
Hide Signatures
(in reply to captinjohn)
       Post #: 7
RE: RE: - 1/17/2012 4:17 PM
goirish
Score: 305
Status: offline
quote:
ORIGINAL: captinjohn
Its kinda like selling a car and the dealers make more $$$ on service and replacing whatever goes bad. If they plan for more parts to go bad....the more they make.    I put this under the heading of.... The ''fleecing of America''   Capt,n
what do you mean "In Florida Now" You didn't leave warm Michigan did you?
DX-7,RDS8000. big Bingo,1/4 Scale Cub, SeaMaster 120, Forget the health food, I need all the preservatives I can get
Hide Signatures
       Post #: 8
RE: - 1/17/2012 4:43 PM
a1pcfixer
Score: 168
Status: offline
Capnjohn is now a 'snow bird'.
Jim L.
Hide Signatures
(in reply to goirish)
       Post #: 9
RE: - 1/17/2012 5:52 PM
av8tor1977
Score: 665
Status: offline
The other factor is that the EPA keeps outlawing all the good chemicals. That makes the manufacturers have to use other methods that usually end up with two results; an inferior product that costs more.
You can't even buy good paint anymore. Ever wonder why you see so many cars now with faded and peeling paint? Thank the EPA.
Mineral spirits used to be dirt cheap and great for cleaning parts. Now, IF you can even find it, it is heading for 20 bucks a gallon!
AV8TOR
Hide Signatures
       Post #: 10
RE: RE: - 1/17/2012 7:21 PM
MTK
Score: 203
Status: offline
Aviator hit it.... I worked for Gates Rubber Company almost 20 years ago in high pressure, high performance hose manufacture. I designed some of the hydraulic products and compounded some of the rubber stocks. EPA had quite a bit to do with raw material changes which caused us chemies headaches galore in figuring out new solutions. In many cases we developed new chemicals that were safer and worked just as well, but I don't recall one instance where the new stuff worked better than the old.
BTW- there is only one rubber raw material that is non-synthetic. It isn't the best and it isn't the worst. They all have their strengths and weaknesses including Fluorosilicones and Vitons which are at the top of the synthetic heap
Regards,
MattK
Hide Signatures
       Post #: 11
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> "Stihl" fuel line - seems flexible - does anyone know anything about it? Pix included
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
