RE: ESM Spitfire 72.5    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: ESM Spitfire 72.5
Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: ESM Spitfire 72.5 - 5/19/2012 11:14 PM
alanc
Score: 105
Last Login: 5/19/2013
Status: offline
i have one of the early ones of this spit,  i came by it with one side of the retract bay ripped out,      this week, i taped up the cowl holes,   removed the air scoops,    ballasted it,  and chucked it off a hill !!!!!!!  it makes a reat power scale soarer,      doesnt half get its speed up,  all aerobatics are as possible with this, as with an engine up front,   might never have it as a power model again
Hide Signatures
(in reply to Me410)
       Post #: 126
RE: ESM Spitfire 72.5 - 5/22/2012 7:28 PM
Me410
Score: 100
Last Login: 5/15/2013
Status: offline
I did alittle slope soaring years ago with some small light stuff. We don't really have a good spot around here for it.
I am suprised an ESM warbird could be converted to that,   thought they would be too heavy?
Hide Signatures
(in reply to alanc)
       Post #: 127
RE: ESM Spitfire 72.5 - 6/29/2012 3:54 AM
Me410
Score: 100
Status: offline
I should wrap up my 2cents on this bird.
I had to cut out the bottems of the wheel well inserts as they robbed me of needed wheel clearance.  At that point I just said to heck with it and made balsa liners. I panted them with  gray Tremclad  as thast what I had. I didn't have any fuel proof greenish zinc-chromate handy.
I have not made the wing canons yet,  and gear doors may never be made,  I want to fly!
I set the CG at 110 mm as others have done,  I did have to make a ply tray that attached to the motor mount and added a pound of lead.
 Flaps max at 65 degrees
All up weight is approx 15-16 LB.
And off to the field we go.
Take off was pretty easy, no tendency to noise over with the modified gear rake. One trick I used was the tailwheel is alittle cocked off to the left turn, so to slow roll straight forward you have to hold right rudder , as  speed picks up and the tail lifts, you are already holding right rudder and on top of the warbird LH torque pull.
The Saito 120 with a APC 15x8 prop pulled it well, not a speed demon, but very scale and fast enough. Big loop are no problem, so I am happy with the power. Also,  the sound of a glow fourstroke is hard to beat, I know,  a 4 stroke twin would be better .  But = $$$$$$$ .
The CG seems spot on. This plane feels very solid  and is a joy to fly.
Landing was alittle hairy as it was somewhat windy and  I elected to come in without flaps, I touched down alille hot and ran to the end of the runway into the weeds, got lucky, no damage.
Next landing was with full flaps and still did not slow down that much, but did not overrun the runway that time.
My engine is at a slow enough idle and flaps at approx 65 degrees, I seem to need alot of runway to land though.  I few more weekends flying and I should get shorter landings, maybe I can reduce my approch speed alittle more .
All in All I love to fly this plane and it looks great and only took me a couple of months to get from the workshop to the field.
Cheers
Tom
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Me410)
       Post #: 128
RE: ESM Spitfire 72.5 - 6/29/2012 4:57 AM
hombresinropa
Score: 100
Last Login: 5/18/2013
Status: offline
Tom,
Awesome news.  I'm glad you got your plane flying!!  I have about 6 flights on mine and have not put the gear doors or guns on either.  Actually, I haven't put any of the extra plastic or fiberglass parts on yet... I'm still tinkering with how it flies.  I meant to take it out today but was too windy.  I hope to get out early tomorrow.  It flies great for me in the wind, I've flown it in 15mph before.  I haven't flown it recently through, since the last 4 times I've taken it to the field, the engine won't stay running.  At home on the driveway, it's fine.  Field... not fine.  Go figure.  I put in new ESM aluminum wheels after I got a bind in my other aluminum wheels that came with my ESM retracts, and I wish I would have used your balsa lining technique.  I thought about it but went with the plastic inserts.  They are big enough for me, BARELY.  My brother is making me some replicated vaccu formed parts, hence why I haven't put them on yet, to include the radiators made out of much tougher plastic.
I love this plane, it looks so awesome in the air.  I have the 120 OS two stroke through, so sound isn't the same, but it still sounds oh so nice.  I still have my buzz bomb dream.  One day...
_____________________________
Fortune favors the bold.
Hide Signatures
(in reply to Me410)
       Post #: 129
RE: ESM Spitfire 72.5 - 6/29/2012 5:03 AM
tevans55
Score: 123
Status: offline
Me410-
If you have enough throw in your flaps...I have been flying mine this year with 75 degrees of flap and it slows very nicely and lands nicely in about 200 feet. I put my flaps on a slider rather than a 2 or 3 position switch so that I can apply the flaps as needed for wind conditions. Most landings however are with full flap. My first ESM Spit only had about 45 degrees of flap and used up about 300 feet of runway so I added more flap to this second plane and it handles it very well. The added flap has really made landings with this Spit alot more enjoyable. Good Luck.
Nothing difficult is ever easy.
Spitfire Brotherhood #44
Hide Signatures
(in reply to Me410)
       Post #: 130
RE: ESM Spitfire 72.5 - 8/19/2012 2:24 AM
Me410
Score: 100
Status: offline
Increased flaps to approx 75 degrees, all good,  better landings. Here's a link to a vid my buddy took of my sweet flying spit. http://www.youtube.com/watch?v=9Fffqa6Dupk
Tom
Hide Signatures
(in reply to tevans55)
       Post #: 131
RE: ESM Spitfire 72.5 - 8/19/2012 1:33 PM
tevans55
Score: 123
Status: offline
Wow Tom great video and landing! You have just shared the same experience with me. This plane loves a lot of flap and really slows down nicely without upsetting the balance in any way. Congratulations!
Hide Signatures
(in reply to Me410)
       Post #: 132
RE: ESM Spitfire 72.5 - 1/16/2013 9:51 AM
silvo2011
Score: 100
Last Login: 5/4/2013
Status: offline
I was looking for a cockpit for the ESM Spitfire 72.5,  do you know where i can buy it?   same as youre photo.
Hide Signatures
       Post #: 133
RE: ESM Spitfire 72.5 - 1/16/2013 4:45 PM
tevans55
Score: 123
Status: offline
Silvo2011-
Here is the link to company and the page for this cockpit.
http://www.dbalsa.com/cockpits/spitfire-kmp.htm
The company is Dynamic Balsa. The current price is $60 USD.
Good Luck, it is a nice product and works very well in this plane.
Also WELCOME to RC Universe!!
Hide Signatures
(in reply to silvo2011)
       Post #: 134
RE: ESM Spitfire 72.5 - 5/13/2013 10:44 AM
oldtimer4759
Score: 100
Status: offline
hello Spitfire lovers,
I just picked mine up today, looks good, a crack in the top of the cowl, been looking at another forum, so I have gone for the power option, a DLE 35 with the rear exhaust, it is a fighter, so it needs horse power, will let you know how it goes. this is my 3rd ESM model, the P-47, with a DLE 30, beautiful to fly, love it, also the P-51B with an RCGF 30 in it, magic, now that I have it sorted out.
Oldtimer.
Hide Signatures
       Post #: 135
RE: ESM Spitfire 72.5 - 5/15/2013 7:45 PM
Me410
Score: 100
Status: offline
Oldtimer4759
You will love your ESM Spitfire.  My cowl was cracked on top also.  I added lots of new fiberglass inside after the engine cut outs were done to make it stonger. You are going to need to add wieght  up front anyway.
I have a new DLE30 with wrap around muffer that I may replace my Saito 120 4s with. I love the Saito, good fit, good power, great sound....but.... I hate paying 40$ a jug for nitro from my LHS.  A jug does not go far with that motor.
It looked to me that  my DLE 30 will not fit unless I saw off the firewall and make a new one about 1/2 inch back?
Other option might be to cut a hole in the firewall to let the carb recess into and use shorter stand offs, but as you see the stock firewall area is pretty small.
let me know how you make out with the DLE35 RA install.
Tom
Hide Signatures
(in reply to oldtimer4759)
       Post #: 136
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
