Antenna question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> Antenna question Page: [1]
Login
Antenna question - 1/17/2012 12:36 PM
James c harrell
Score: 105
Last Login: 5/18/2013
Status: offline
Would it hurt my reception if I put my antenna inside my boat? I don't really want to put a mast on it and have enough length to the boat to run it straight down the inside on the upper side. Any thoughts?
Hide Signatures
       Post #: 1
RE: Antenna question - 1/17/2012 12:46 PM
blizard05
Score: 100
Last Login: 5/17/2013
Status: offline
IT has ben done,may cut down on the range. Have done it with AM,FM radio
_____________________________
America home of the free,thanks to the brave
Hide Signatures
(in reply to James c harrell)
       Post #: 2
RE: Antenna question - 1/17/2012 3:22 PM
James c harrell
Score: 105
Status: offline
I am useing a FM radio. I have another question for you. Why do some of my radios say "Aircraft use only"? Most of my transmitters are 72 and for aircraft but why couldn't I use them for my boats?
Hide Signatures
(in reply to blizard05)
       Post #: 3
RE: Antenna question - 1/17/2012 4:30 PM
Dan S
Score: 115
Last Login: 5/7/2013
Status: offline
James,
72Mhz is for RC aircraft use only, 75Mhz is for surface.
Reason you can't use your 72Mhz radio on your boat, it is illegal (against FCC rules), it would also be irresponsible to do so.
although you may think that there is no one flying in the area you are operating your boat, you only need that one time that someone is and by pure luck both of you are on the same channel (unlucky).
You may lose control of your boat due to his command inputs and he may lose control of his aircraft due to your command inputs, this can cause not only serious damage to either equipment but also serious injury.
if one of your reason for using your 72Mhz is because you prefer dual stick instead of pistol grip, they do make surface dual stick on 75Mhz.
Another direction you could go is get a new 2.4Ghz radio, that way you can have the best of both worlds since 2.4 is for both.
Dan.
F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
Futaba FASST
Hide Signatures
       Post #: 4
RE: Antenna question - 1/17/2012 4:47 PM
James c harrell
Score: 105
Status: offline
I have many 2.4 radios. I was just wondering. Where I live I am just as liable to have someone flying that I don't know about as someone running a boat. I fly mainly on 2.4 for that reason. If I fly 72 it would be where I knew there was a pin board. And if I was to run my boat with one it would be where I knew there was no one in range. The only reason I asked was that I have alot of older 72 set-ups that wouldn't bother me if they got wet and ruined. If I lose one of my 2.4 recievers I am out 70-80 bucks. I do see your point with interference. I just need to pick up some 75 stuff. To bad though, after 20 odd years of flying, I have plenty of old 72 recievers. I am new to boats and somewhat un-prepared it seems. As to the interference thing. What would the difference be if someone turned on a boat up-river from me on the same 75 freq. I mean there are no pin bords any-where around here for boats or airplanes. Except for the one at my little airstrip.
Hide Signatures
(in reply to Dan S)
       Post #: 5
RE: Antenna question - 1/17/2012 4:57 PM
Dan S
Score: 115
Status: offline
totally agree with you james regarding someone else using the same channel on 75Mhz, it could and did happen for one of my friends here.
I agree, the Rx are not cheap, I also use 2.4 on my planes and boats.
Just make sure you have a water tight radio box.
Dan.
Futaba FASST
Hide Signatures
       Post #: 6
RE: Antenna question - 1/17/2012 5:10 PM
James c harrell
Score: 105
Status: offline
I am getting there. I just got into boats when a friend gave me his collection. He is 80 and said he just couldn't keep up with them any-more. I ran one of them the other day and at around 60 MPH I can see why. I did get some 75 rec. from him but am trans. poor on 75. Also, The antenna on all these boats I got are the little short fiberglass type that bolt thru the hull. Do they need to be tuned if I change freq. They plug in to the rec. and if I get new stuff I was wondering if they will still work.
Hide Signatures
(in reply to Dan S)
       Post #: 7
RE: Antenna question - 1/17/2012 11:20 PM
County-Flyer
Score: 100
Last Login: 2/17/2013
Status: offline
I agree with james I was running my dads boat one day and I happened to nose dive into a wave with a 2.4 radio. My rx got wet so we took it home and put it in a bole of rice to dry it out. Needless to say my $80 2.4rx is destroyed.I have lots of 72 receivers that I dont mind putting in a boat.
Hide Signatures
       Post #: 8
RE: Antenna question - 1/18/2012 12:22 AM
Dan S
Score: 115
Status: offline
I understand,
I run $90 receivers in my boats also, that is why it is important to have a water tight radio box.
you can also use corrosion-x in all servos and receivers.
Dan.
Futaba FASST
Hide Signatures
(in reply to County-Flyer)
       Post #: 9
RE: Antenna question - 1/18/2012 12:58 AM
County-Flyer
Score: 100
Status: offline
Thats very true I learned a valuable leson, which would be what you r saying water proof box(and not to sink my boat anymore. Hahahaha . Meand my dad found that rtv works pretty good for a water tight seal.
Hide Signatures
(in reply to Dan S)
       Post #: 10
RE: Antenna question - 2/23/2012 6:59 AM
madmorgan
Score: 100
Last Login: 12/27/2012
Status: offline
not to start a fight with the guys running 100 dollar rx boxes in their tubs but you should check out the flysky 2.4 ghz systems they r selling like wildfire and the rx are only 6-8 bucks ea. i will use these as i have done my own tests having my gf drive off with a servo and rx by the time she was 2 blocks down i could still see the car but if my boat was that far i would lose orientation any ways. but she turned and told me where it started glitching and she was very far away and who knows how many houses and trees between us. so take it for what its worth . btw anything man made that has electric passing through it is bound to die sooner or later and may be junk from the manufacturer so before any 1 chimes in about their 100 rx's being way better then i will direct you to other forums that will show you yes even the expensive rx's fail .one of these days im going to test traxxas 2.4  and tactics 2.4 futaba 2.4 and spectrum 2.4 just to get results. im by no means a expert but test results tell all .
if you dont know you better ask somebody ! usarmy active 1989-1997, 1990 desert sheild /desert storm, 1993 somolia .
Hide Signatures
       Post #: 11
RE: Antenna question - 2/23/2012 4:21 PM
Dan S
Score: 115
Status: offline
Mad,
I agree with you, I have read many reviews regarding the flysky (including yours) also seen a couple in action, very impressed.
Price..........Dirt cheap.
One thing I did not do in any of my previous post is that I did not mention any specific brands.
Yes I have a Futaba 3 PM 2.4, reason is back then there was only a couple of choices, the flysky did not exist.
but now, thats a different story.
Dan.
Futaba FASST
Hide Signatures
(in reply to madmorgan)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
