MIGHTY BARNSTOMER    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> MIGHTY BARNSTOMER
Page: [1]
Login
MIGHTY BARNSTOMER - 1/25/2012 5:33 PM
atron
Score: 100
Last Login: 5/20/2013
Status: offline
Hi everybody:
I am from Mexico City, please excuse my English.
Friend of mine still has a Mighty Barnstormer, intact and flying for more than 30 years!!! See photos, has an Webra speed .61 on the nose and is covered on silk & dope.
I always liked that plane, the idea is to make it around an OS 91 Surpass, so it got to be light.
I am starting to build (copy) the "large" version (72" wingspan) of the famous Dave Boddingtons Barnstormer.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by atron -- 1/25/2012 8:01 PM >
_____________________________
I´ll rather be flying.
Hide Signatures
       Post #: 1
RE: MIGHTY BARNSTOMER - 1/25/2012 5:42 PM
atron
Score: 100
Status: offline
By the way, the guy in the photo is Max Betancourt, owner of the plane.
Now some progress on the building....
Build will be OLD SCHOOL, so there will be no laser cutting.
Wing pattern is made in alumminum, its original one used by y friend.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by atron -- 1/25/2012 8:03 PM >
Hide Signatures
(in reply to atron)
       Post #: 2
RE: MIGHTY BARNSTOMER - 1/25/2012 5:46 PM
bogbeagle
Score: 148
Last Login: 5/25/2013
Status: online
I have the Bi-Stormer 72 inch... pretty much the same as the BarnStormer, except with 2 wings!
Anyway, mine has an OS .91 four-stroke and this provides plenty of power for the model. My model is covered with nylon and dope, then painted; so, it's not particularly light in weight. I think that your Barnstormer will be just fine with the OS engine.
They do fly very well; very predictable. I've logged 9.3 hours on it, since last January and I love it to bits.
I bought mine, secondhand, from a swapmeet. It had a fixed tailwheel. Now, it has a steerable tailwheel, which is a great improvement. Still, the model and all the servos for £20 was a good deal.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 3
RE: MIGHTY BARNSTOMER - 1/25/2012 7:43 PM
kenh3497
Score: 115
Status: offline
quote:
ORIGINAL: atron
Hi everybody from Mexico City, please excuse my English.
Don't fret (worry) about your English. From what I can read, your English is better than some whose first language is English
Sent from my Dry-Erase-Board
Hide Signatures
(in reply to atron)
       Post #: 4
RE: MIGHTY BARNSTOMER - 1/25/2012 8:31 PM
atron
Score: 100
Status: offline
BOGBEAGLE:
Your Bi-stormer looks fantastic.
I plan to have an steerable tailwheel and cover on SIG Koverall.
Thanks.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to kenh3497)
       Post #: 5
RE: MIGHTY BARNSTOMER - 1/25/2012 9:49 PM
FlyerInOKC
Score: 116
Last Login: 5/24/2013
Status: offline
I agree with kenh3497 your English is just fine. I enjoy building the "Old School" way myself I believe it is a sign of craftsmanship. Not too long ago I cut out two sets of wingribs for a 1/5 scale Ryan SC-W if you look at the pictures you can see the tapper on the wing. At the root the rib is 17.75 inches long and at the wingtip 4.75 inches long and ther are 12 or 13 ribs per wing. I used paper wingrib templetes and rough cut them out in pairs with a rasor saw and a Xacto Knife with a # 11 blade and then sanded them to the lines of the template. I used rubber cement to hold the templates to the top layer of wood so they peeled right off and a little rubbing removed any remaining glue. The design calls for the ribs to interlock into a plywood main spar with a liteply rear spar extending 2/3 of the way into the wing. The wing has alerons but it has an airbrake mounted between the main gear instead of flaps. On the full scale airplane the fuselage was constructed of a metal skin over formers and the wing has a metal skin from the leading edge to the mainspar and the the remaining part is fabric covered as are all control surfaces.
Click for fullsize
Click for fullsize
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
(in reply to atron)
       Post #: 6
RE: MIGHTY BARNSTOMER - 1/26/2012 12:27 PM
nevster
Score: 100
Status: offline
Hello Atron,
I have had barnstormers for the last 26 years (all 72" wingspan versions). They are a fantastic flying model. My last one was powered by a saito 65
fourstroke which was more than enough power - this model was covered in solartex and painted so it was no liteweight. I used to also carry around
quite a heavy digital camera on top of the wings - it flew fine !
If you look under my models on my profile page you will see a photo of my latest barnstormer. Unfortunately I have had to strip off the covering
and rebuid the front of the fuselage as it's so old and fuel soaked from a lot of flying. The only thing I would recommend is to enlarge the ailerons by
one rib bay - this helps with the roll rate and makes it feel more solid on windy days
Good luck with the build
Regards
Nev
Hide Signatures
(in reply to FlyerInOKC)
       Post #: 7
RE: MIGHTY BARNSTOMER - 1/30/2012 6:17 PM
kdc
Score: 115
Last Login: 5/23/2013
Status: offline
There is a Barnstormer 63 build blog on this site http://www.modelflying.co.uk/forums/postings.asp?th=63537
The plans for the Barnstormer 63 & 72 and Mighty Barnstormer are available from DB Sport & Scale in England. They also sell the wing rib sets at good prices also u/c parts. This was the late David Boddington's company which is still going but has been run by someone else for many years..
see
http://www.dbsportandscale.com/Plans-List.htm
http://www.dbsportandscale.com/Mighty-Barnstormer.htm
The Mighty Barnstormer plan is also avail in USA from RCM Plans
see
http://www.rcmplans.com/index.php?main_page=product_info&cPath=3&products_id=1315
Hide Signatures
(in reply to nevster)
       Post #: 8
RE: MIGHTY BARNSTOMER - 1/30/2012 10:38 PM
atron
Score: 100
Status: offline
Folks:
Guess what, i just find that i am builing the 89" wingspan and not the 72"!!!!
Please excuse my mistake.
So the question still exsist...... Is the OS 91 four stroke (older Surpass version) somehow equivalent to a two stroke 60 enough for this plane?
AT
Please take in consideration that Mexico City is a very high altitude, flying field is at 2500 meters or 7,500feet.
RCM PLAN # 490
MIGHTY BARNSTORMER
89" span, 1200 sq. in., .60-.80, 4 ch., built-up balsa and plywood, one sheet 41-1/2" x 76" $15.00
Click for fullsize
Hide Signatures
(in reply to kdc)
       Post #: 9
RE: MIGHTY BARNSTOMER - 1/30/2012 11:48 PM
bogbeagle
Score: 148
Status: online
Well, their website says .50 to .70 sized engines ... http://www.dbsportandscale.com/Mighty-Barnstormer.htm
BUT, given the altitude at which you intend to fly, I'm thinking that you'll need a lot bigger engine. Experience will be your best guide. That is, how do comparable models perform at that altitude?
I'm confident that the model will perform poorly on a .90 four-stroke.
I could predict, using rule-of-thumb, that your model will climb at a little less than one half of its sea-level rate. I'd guess that a 1.20 four-stroke would be the minimum acceptable power, unless you want to fly very sedately.
Hide Signatures
(in reply to atron)
       Post #: 10
RE: MIGHTY BARNSTOMER - 2/4/2012 4:52 PM
CanDo
Score: 100
Status: offline
How about the DLE 20 (20cc) gas engine? It swings a 17x6 prop and is much cheaper to operate than a 120 glow engine. I believe Tower Hobbies' price is less than a OS .91 4-stroke engine. I agree, at 7500 ft, you may need more power than a .91 4-stroke. What is the ready to fly weight?
Wanted: Smarter thumbs...
Hide Signatures
(in reply to atron)
       Post #: 11
RE: MIGHTY BARNSTOMER - 2/4/2012 7:40 PM
atron
Score: 100
Status: offline
If you go back to post #1 you¨ll see the model i am after. It has a Webra 61 speed from the 80´s and it fly VERY well at Mexico City altitude. No is not a 3D, nor i dont want such a plane!!
The plane is similar to a Telemaster or a Kadet Senior, but somehow different.... has an semisimetric airfoil an is little hevier.
The DLE 20 seems too big for this.
Click for fullsize
Hide Signatures
(in reply to CanDo)
       Post #: 12
RE: MIGHTY BARNSTOMER - 2/4/2012 7:58 PM
bogbeagle
Score: 148
Status: online
In that case, atron, just build it as you first intended ... that is, with the OS .91. It will certainly fly and you can assess the power for yourself. It won't be too difficult to slip a larger engine between the bearers, if you should need to.
I must confess that I wouldn't want a modern petrol engine on the front, either. I'm a bit stuck in my ways, I suppose.
Hide Signatures
(in reply to atron)
       Post #: 13
RE: MIGHTY BARNSTOMER - 2/6/2012 8:47 PM
CanDo
Score: 100
Status: offline
If you think a .91 4 stroke can fly your 89" span plane at 7500 ft easily, then that is the way to go. As Bogbeagle said, it wouldn't be difficult to upgrade if you need to. 4 stroke engines do sound great, it's the price of glow fuel that has changed my mind about them.
Hide Signatures
(in reply to atron)
       Post #: 14
RE: MIGHTY BARNSTOMER - 2/7/2012 12:05 AM
green river rc
Score: 100
Last Login: 3/5/2013
Status: offline
Cool airplane, love the parasol wing!
With the parts left over, Im going to build a motorcycle.
Hide Signatures
(in reply to CanDo)
       Post #: 15
RE: MIGHTY BARNSTOMER - 2/7/2012 12:26 AM
atron
Score: 100
Status: offline
I did order the much needed balsa wood to "The Balsa Store" but shipment is on hold because of some Paypal problem with the founds.
Meanwhile, i began working on the cowling. My friend found the original plug made in hard wood that was used to make the fiberglass mold. Just imagine, all that work to make one pice.
I will be extending it to fit any 120 four cycle engine.
Hide Signatures
(in reply to green river rc)
       Post #: 16
RE: MIGHTY BARNSTOMER - 4/7/2012 3:35 AM
atron
Score: 100
Status: offline
Hi everybody:
I have not posted in a loooong time, but i been working on the plane.
Here are some photos of the fiberglass cowling, i needed to add an inch to the base, took 3 moulds to have a good one.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 17
RE: MIGHTY BARNSTOMER - 4/7/2012 3:42 AM
atron
Score: 100
Status: offline
Now the woodwork.
Its very straightforward.
Only very few deviations from plan, the radio access will be from the bottom.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 18
RE: MIGHTY BARNSTOMER - 4/7/2012 3:49 AM
atron
Score: 100
Status: offline
More photos.....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 19
RE: MIGHTY BARNSTOMER - 4/7/2012 3:52 AM
atron
Score: 100
Status: offline
and some more on he planking and rudder/stab.
Cabanes are removables.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 20
RE: MIGHTY BARNSTOMER - 4/7/2012 3:56 AM
atron
Score: 100
Status: offline
some on the stab hinging....
Click for fullsize
Hide Signatures
(in reply to atron)
       Post #: 21
RE: MIGHTY BARNSTOMER - 4/10/2012 1:22 AM
kenh3497
Score: 115
Status: offline
Looking mighty fine.
Ken
Hide Signatures
(in reply to atron)
       Post #: 22
RE: MIGHTY BARNSTOMER - 4/12/2012 7:38 PM
soarrich
Score: 136
Status: offline
Great looking plane!
The ARFers don't know what they are missing.
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
       Post #: 23
RE: MIGHTY BARNSTOMER - 4/12/2012 7:52 PM
atron
Score: 100
Status: offline
Soarrich:
Yeap, i really enjoy building.
I am taking my time to do it right (means my way).
Hide Signatures
(in reply to soarrich)
       Post #: 24
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
