RE: Traxxas Summit    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> RE: Traxxas Summit
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Traxxas Summit - 2/6/2012 9:27 PM
Summit is Beast!!!
Score: 436
Last Login: 6/17/2013
Status: offline
Checked the reciever box...there was a half of a drop of water in the corner around a screw. I spray mine down with a water hose then with wd40 then blow that off with an air hose after every run.
_____________________________
Summit-$564, Tires and wheels-$150, lipos,servos and all my hopups-About $700, being the owner of the best rc ever-priceless
Hide Signatures
(in reply to LaTuFu)
       Post #: 101
RE: Traxxas Summit - 2/6/2012 11:26 PM
Summit is Beast!!!
Score: 436
Status: offline
O and also today I noticed my rear diff didnt lock so i took the body off and turned it on and off and the servo moves but it twitches back and forth til I cut it off. Is my servo bad already?
Hide Signatures
(in reply to Summit is Beast!!!)
       Post #: 102
RE: Traxxas Summit - 2/6/2012 11:28 PM
pyromatic177
Score: 255
Last Login: 4/18/2013
Status: offline
sounds like the switch may just be locked up
!!!Bash Like There''s No Repair Bills!!!
Hide Signatures
       Post #: 103
RE: Traxxas Summit - 2/6/2012 11:51 PM
Summit is Beast!!!
Score: 436
Status: offline
Just called traxxas and the guy said sometimes when the antenna gets fully submerged it looses contact with the radio. That makes sense but doesnt explain why peeps on youtube can do it on their stock summits. I think when i took the motor off and put it back on it might be binding the linkage somewhere bc it started the first run after I took off and cleaned the motor.
Hide Signatures
(in reply to pyromatic177)
       Post #: 104
RE: Traxxas Summit - 2/7/2012 12:00 AM
pyromatic177
Score: 255
Status: offline
Maybe
Hide Signatures
       Post #: 105
RE: Traxxas Summit - 2/7/2012 12:20 AM  1 votes
TheKennyKiller
Score: 462
Last Login: 1/23/2013
Status: offline
quote:
ORIGINAL: Summit is Beast!!!
By "binding the linkage" I guess you are talking about the pinion gear and spur gear? If the motor is revving but your truck is not moving then it is most likely a problem with the mesh of those gears or a stripped spur gear. Check out page 25 of your manual, the paper method is pretty good way of testing your mesh until you get a feel for it. If you are pulling on the trigger and the motor is doing nothing then the problem is somewhere else, did you take the receiver cover off and check for water inside? It's a good idea to remove that cover after running in the water to let it dry and avoid moisture build up. The problem with the servo might be linked to the problem with the receiver (if that is the problem) but it would not surprise me if the servo died.
Edit
Another thought, has the black cap on the antenna fallen off? Water could find its way in that way I guess.
Do you even RC?
Hide Signatures
       Post #: 106
RE: Traxxas Summit - 2/7/2012 12:38 AM
Summit is Beast!!!
Score: 436
Status: offline
No it runs fine forward and reverse my back diff wont lock in. It started after i pulled the motor off and cleaned it then reinstalled it. So im thinking a wire or something is on the way of the rear diff linkage. Im going to take the motor off again and check to see if anything is in the way of it.
Hide Signatures
(in reply to TheKennyKiller)
       Post #: 107
RE: Traxxas Summit - 2/7/2012 12:45 AM  1 votes
TheKennyKiller
Score: 462
Status: offline
Oh I see what you mean, the linkage between the servo and the diff. It's worth checking out. maybe try taking off the servo horn and see if the servo still works.
So your summit cut out while it was in the water but it is working fine now? Aside from the servo of course. Kinda makes me re-think trying this for a second time.
Do you even RC?
Hide Signatures
       Post #: 108
RE: Traxxas Summit - 2/7/2012 1:08 AM
Summit is Beast!!!
Score: 436
Status: offline
Ok i fixed it. Yeah it cut off in the middle of the creek. Like i said traxxas support said sometimes it looses connection with the handheld when the antenna is completly under water. O well ill never sink it to the roof again...i didnt really mean to today but the current in the creek caught it and took it out to the middle and it was deeper than i thought. Lol
Hide Signatures
       Post #: 109
RE: Traxxas Summit - 2/7/2012 1:13 AM
Summit is Beast!!!
Score: 436
Status: offline
Just watched ure vid kenny. He said it was fine as long as the antenna was above the water.
Hide Signatures
       Post #: 110
RE: Traxxas Summit - 2/7/2012 1:35 AM
Summit is Beast!!!
Score: 436
Status: offline
Ok this is the reason i thought i could sink my summit to the roof.
http://www.youtube.com/watch?v=jQkh7wkV-Ho&feature=youtube_gdata_player
But after watching it a second time I realized he has an antenna alittle over a foot long. My antenna is like 2 inches. Lol
Hide Signatures
       Post #: 111
RE: Traxxas Summit - 2/7/2012 3:05 AM
LaTuFu
Score: 275
Last Login: 8/31/2012
Status: offline
He has the original Summit version with the AM Tx.  Yours has the newer 2.4 GHz Tx, doesn't need the long antenna.  (And has longer range than the AM, too.)
You dodged a bullet.  They will take a lot of water, but they don't like full submersion very much.  Try not to do it too often, lol.
The micro servos for the diffs and tranny are notorious for going bad easily.  Make sure when you put it back on that you power it on before putting the horn back on, so it will center itself.  They are cheap on ebay if you ever need to replace.
Like the Thunder Tiger MT4 G3? Check it out on wondertiger.com
Hide Signatures
       Post #: 112
RE: Traxxas Summit - 2/7/2012 10:49 AM
aknitroguy
Score: 100
Last Login: 6/11/2013
Status: offline
Hi, I have a summit and I'm going to keep the stock brushed set up for what I need. Lipo's are all it's getting for a while. I am working on a plow system for it. With the stock locking diffs and low gearing I figured it would make a great candidate for a plow truck. I will post pictures of my progress. Who knows maybe I will make a couple of extra units. It is a very scale design and the blade lift servo is hidden under the winch in the body (the servo mount replaces the plastic hoop bumper stand off).
Anyway I subscirbed to this thread and I'm looking forward to talking about summits with you folks.
Take care, Jay
Hide Signatures
       Post #: 113
RE: Traxxas Summit - 2/7/2012 1:42 PM
pyromatic177
Score: 255
Status: offline
That would be a cool thing to see
Hide Signatures
(in reply to aknitroguy)
       Post #: 114
RE: Traxxas Summit - 2/7/2012 2:03 PM  1 votes
TheKennyKiller
Score: 462
Status: offline
I must have watched that video 100 times while waiting for my Summit to arrive.
Do you even RC?
Hide Signatures
       Post #: 115
RE: Traxxas Summit - 2/7/2012 3:11 PM
JUCD VPR
Score: 130
Last Login: 3/26/2013
Status: offline
Awesome thread guys. I've had my Summit for about 2 years now and I absolutely LOVE IT! I beat the tar out of it, it's seen 30+ feet jumps etc and always comes back begging for more!!
Currently doing a BL E- Revo Rebuild/Refresh as i've been beating it up for about 2 yrs also and it's time to do some upgrades.
When I'm finished my sights are set are on upgrading the Summit. I currently run 2S Lipo's and a LVC. Truck just isn;t fast enough for me considering everything else I own is brushless. SO i'll be adding a Brushless Sensored System to make it faster and keep it crawling in the near future, some new wheel/tires, and upgraded Arms and shafts.
You guys do know you can waterproof a brushless system right? All my trucks are waterproofed using CORROSIONX, best thing i've ever found in regards to keeping water away. I retreat once a year.
http://www.youtube.com/watch?v=6jpSW50cobs
Savage Flux HP XL, BL E-Revo , BL Cen GST, BL Losi LST E-XXL, Traxxas Summit, Savage X SS (Nitro)!
Hide Signatures
       Post #: 116
RE: Traxxas Summit - 2/7/2012 6:08 PM  3 votes
Summit is Beast!!!
Score: 436
Status: offline
It got soooo dirty today...
Now im going to spend the next hour cleaning it!!!
Hide Signatures
(in reply to JUCD VPR)
       Post #: 117
RE: Traxxas Summit - 2/7/2012 6:31 PM  2 votes
Summit is Beast!!!
Score: 436
Status: offline
Shhhh..... Dont tell the wife. Lmao
Hide Signatures
       Post #: 118
RE: Traxxas Summit - 2/7/2012 7:00 PM
aknitroguy
Score: 100
Status: offline
It definately is a must to water protect your equipment. I am sticking with the brushed set up because it is smooth as slow speeds/rpm and for my application the stock set up will lose traction before losing power. I have other brushless models for speed.
I originally wanted to just buy a plow and all I found was one for the T-maxx that looks like a thin gauge sheet metal blade crimped at the top so it don't fold the first time you hit a chunk of ice (in theory) and has little airplane landing looking wheels for skids. The other one is $180.00 and has buggy shocks for trip springs and no lateral support (side force).
Up until lately I have been designing/producing helicopter parts, now my kids are getting old enough for rc I am pretty much switching over to surface equipment and spending less time at the airfield.
Don't let the MRS catch you washing truck parts in the sink, they don't like that. Ask me how I know lol. Your summit body is sweet with the trx graphics, did you buy it that way?
Have a good one, Jay
Hide Signatures
       Post #: 119
RE: Traxxas Summit - 2/7/2012 7:09 PM  1 votes
Summit is Beast!!!
Score: 436
Status: offline
Yes it comes stock on the new 1s. How do u know that? I just converted it to a low rider. What do yall think?
Hide Signatures
       Post #: 120
RE: Traxxas Summit - 2/7/2012 7:19 PM
Dale Gribble
Score: 288
Last Login: 6/13/2012
Status: offline
Lol! I am pretty sure you might have some rubbing issues there.
*** Support your local tracks ***
Hide Signatures
       Post #: 121
RE: Traxxas Summit - 2/7/2012 8:43 PM
JUCD VPR
Score: 130
Status: offline
Nice pics! I like the new body colors
Hide Signatures
(in reply to Dale Gribble)
       Post #: 122
RE: Traxxas Summit - 2/7/2012 9:04 PM
pyromatic177
Score: 255
Status: offline
quote:
ORIGINAL: Dale Gribble
LOL i think so too. IMO it looks wierd like that
Hide Signatures
       Post #: 123
RE: Traxxas Summit - 2/8/2012 12:21 AM
JahVega
Score: 100
Last Login: 3/21/2013
Status: offline
 for all of us summit users. get the kershaw designs upgrade. its still brushed waterproof and faster about 10 miles and still extremely capable at low speeds.
Hide Signatures
       Post #: 124
RE: Traxxas Summit - 2/8/2012 1:04 AM
Summit is Beast!!!
Score: 436
Status: offline
So when i was cleaning my summit today i took the motor out and looked at the linkage to the rear diff. When i put the motor back on last time i had wires put back in the wrong spot and it was holding up the linkage from locking the rear diff...my servo is fine thank god!!! Everything is back to working order
Hide Signatures
(in reply to JahVega)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
