thunderbolt2 beetle rollcage    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> thunderbolt2 beetle rollcage Page: [1]
Login
thunderbolt2 beetle rollcage - 1/27/2012 9:54 AM
DizzyRonson
Score: 100
Last Login: 5/12/2013
Status: offline
Hello rc people
I started a lil project with my tb2
It's a rollcage made from seamless high pressure hydraulic pipe..
Made to fit inside a fiberglass beetle body from nutechracing.nl
And on the zmc dual steering servo chassis.
It is not finished yet, there are no mounting points, no side bar/step thing,
No paint, no final fitting and there are some more bracing to to in the back
Here's a pic
Hide Signatures
       Post #: 1
RE: thunderbolt2 beetle rollcage - 1/27/2012 11:10 AM
Foxy
Score: 2012
Last Login: 5/18/2013
Status: online
Looks great! You might want to consider protecting the top of the front shock tower with something, it looks a little exposed, and is a weak point on the car as stock.
_____________________________
IT`S A FAAAAAAAAKKKKKKKEEEEEEEEE!
Hide Signatures
(in reply to DizzyRonson)
       Post #: 2
RE: thunderbolt2 beetle rollcage - 1/27/2012 11:32 AM
DizzyRonson
Score: 100
Status: offline
That shock tower is actually already broken, but there are a 7mm thick one almost done just sitting on my work bench
And if you look at the bar going down the middle there, you might notice its a little low..
the plan was to make it a little longer with more bend so it will sit a tad higer.
That should help some, and I will make a front and rear bumper, that would also help a little..
Hide Signatures
(in reply to Foxy)
       Post #: 3
RE: thunderbolt2 beetle rollcage - 1/27/2012 5:02 PM
mradlin
Score: 105
Last Login: 5/13/2013
Status: offline
It's looking really good Dizzy!!
I can't wait to see it all finished up and mounted.
Owner of 5thscaleracingforum and Hurraxforum
Hide Signatures
       Post #: 4
RE: thunderbolt2 beetle rollcage - 1/27/2012 8:22 PM
Foxy
Score: 2012
Status: online
quote:
ORIGINAL: DizzyRonson
This is what I was thinking, only it looks good low as it is now. I was thinking maybe you could just weld a small semi-circle like a hood bulge.
Hide Signatures
       Post #: 5
RE: thunderbolt2 beetle rollcage - 1/27/2012 11:26 PM
DizzyRonson
Score: 100
Status: offline
Actually thats not a bad idea. I was thinking, I have to cut holes in the hood of the beetle body for the tower to stick out,
so some sort of brace will look good
I did not get to drag myself over to the workshop today. So no new progress or pics today:/
Will try and get something done tomorrow.. need mounting points first, and I may have to rework some of the lower back to make it sit lower and give room for exhaust..
I was also thinking it would be Nice with functional doors, so I don't need to remove body from cage to re fuel.
Steel cage will make fiberglass body stiff enough anyway I think...
I also have on order some alu case for 5755 servo..
Does anyone know anything about that?
Quality, pros, cons and such.
I could not find much info on it..
Anyway I think they will look good
Hide Signatures
(in reply to Foxy)
       Post #: 6
RE: thunderbolt2 beetle rollcage - 1/28/2012 3:12 AM
tizdaz
Score: 100
Last Login: 5/14/2013
Status: offline
fair play fella, that looks propper sweet ^^
im after a sandrail for my FG, some guy off another forum is hopefully gunna sort one for me (im from UK).. but yours looks sweet mate, id keep it like that & just throw some panels on it instead of a lexan shell
North West Off Road RC Club: http://www.northwestoffroadrcclub.co.uk
How fast was that tree going when it hit you!?
Hide Signatures
       Post #: 7
RE: thunderbolt2 beetle rollcage - 1/28/2012 11:13 PM
DizzyRonson
Score: 100
Status: offline
I probably will put alu panels on it at some point.. I usually do that to my rc cars, I like alu panels.. as you can see here
But back on topic
The body I have for it is not lexan.. its fibreglass.
Here is pic of the cage in the body
And here is a pic of the cage through the front window. It will sit a tad higer tho.. The cage will be painted red to match red engine accessories
Hide Signatures
(in reply to tizdaz)
       Post #: 8
RE: thunderbolt2 beetle rollcage - 1/28/2012 11:57 PM
Lars from Norway
Score: 155
Last Login: 5/17/2013
Status: offline
This looks beautiful! Very nice work. I really had to have a look in your profile where you came from when i saw that bottle of Solo, i couldnt think of any other country than Norway
Find a job you love, then you won''t have to work for the rest of your life.
Hide Signatures
       Post #: 9
RE: thunderbolt2 beetle rollcage - 1/30/2012 1:52 AM
DizzyRonson
Score: 100
Status: offline
Hey Lars heia norge
And thank you all for positive comments
I was at the workshop today, and made brackets at the front and prototype brackets at the back..
Modified a little on the bottom rear end of the cage to make more room for exhaust,
Don't know if I like how it turned out.. will have another look at it tomorrow..
I did forget to take pictures today, but I may remember it tomorrow
Here is another pic of earlier cage to compensate
This is the same car with my first attempt at a cage. I welded it together with a stick welder thing.. I think there are maybe one half decent weld on it, but I can stand on it
BTW My brother did a "stand on it" test on the beetle cage today. He weighs in at 100kg and the cage didn't even flinch a little. He could probably jump on it
Hide Signatures
(in reply to Lars from Norway)
       Post #: 10
RE: thunderbolt2 beetle rollcage - 1/30/2012 5:34 PM
DizzyRonson
Score: 100
Status: offline
I got something Nice today
And I got 3 of them
Will look Nice with all the other alloys
Hide Signatures
       Post #: 11
RE: thunderbolt2 beetle rollcage - 1/30/2012 10:45 PM
mradlin
Score: 105
Status: offline
It's really looking great Dizzy!!
Keep it up.
Hide Signatures
       Post #: 12
RE: thunderbolt2 beetle rollcage - 1/30/2012 10:49 PM
Lars from Norway
Score: 155
Status: offline
Lucky you with all that chocolate
Hide Signatures
       Post #: 13
RE: thunderbolt2 beetle rollcage - 1/31/2012 1:50 PM
craigrobbo
Score: 100
Last Login: 4/24/2013
Status: offline
I am speachless that cage is amazing...I would buy one at the flicker of an eyelid!
This is my Signature
Hide Signatures
       Post #: 14
RE: thunderbolt2 beetle rollcage - 2/6/2012 12:34 AM
DizzyRonson
Score: 100
Status: offline
Tada!!
I did something today
now im tired so i dont have the energy to write more about it now..
Hide Signatures
(in reply to craigrobbo)
       Post #: 15
RE: thunderbolt2 beetle rollcage - 2/6/2012 12:39 AM
DizzyRonson
Score: 100
Status: offline
Hide Signatures
       Post #: 16
RE: thunderbolt2 beetle rollcage - 2/6/2012 1:00 AM
craigrobbo
Score: 100
Status: offline
That really is just amazing, that just needs a wing mount & wing on the back and it would in my eyes be perfection!
Please get back to me on making me one of these.
Craig
Hide Signatures
       Post #: 17
RE: thunderbolt2 beetle rollcage - 2/10/2012 9:28 PM
DizzyRonson
Score: 100
Status: offline
Hey people i'm sorry for the hold up.. but i have not been feeling to much like superman lately.. i'm dizzy and my head hurts :/
so progress is a little slow..
But got some prettying up done today tho
@craigrobbo
i'm sorry but i have not been home more than about 7 minutes this week. so i have not been able to get a estimate done..
Will try my best to get some info for you asap.
Hide Signatures
       Post #: 18
RE: thunderbolt2 beetle rollcage - 2/10/2012 10:04 PM
craigrobbo
Score: 100
Status: offline
NO worries mate.
Thanks for taking the time to let me know.
I cannot wait for mine!!
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
