Programming Aurora 9 - Elevon mode    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Programming Aurora 9 - Elevon mode
Page: [1]
Login
Programming Aurora 9 - Elevon mode - 1/30/2012 5:45 PM
JVB
Score: 100
Last Login: 5/19/2013
Status: offline
I've got a plane set up in elevon mode. I would like to program a switch to give me a bit of up elevator for takeoffs. After takeoff, flip the switch and go back to normal elevator. I can't see how to do it as some of the functions that would work apparently are not available in elevon mode. Thanks.
Hide Signatures
       Post #: 1
RE: Programming Aurora 9 - Elevon mode - 1/30/2012 6:13 PM
A.T.
Score: 181
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: JVB  I've got a plane set up in elevon mode.
As discovered, some functions such as setting a switched Flight Condition or P.Mix for "elevator" to be
"held up/raised" during launch, are not possible whilst "Elevon" is enabled for a GP or EP Delta.
Delta (Flying Wing) Launch Mode:
For those that desire a little extra Up Elevator during launch:
1. Model Type GLID, use the launch Function (as attached).
2. Model Type ACRO (Launch Function and some other mixes are disabled)
. Select [Camber Mix] during intial setup, assign switch G then enable "On" = Launch mode,
in forward position and flip back "Off" for normal flight.
. Return to CAMB.Mix screen, set:
AILE> Normal "S" OFF (& ON)
AILE: 0% / +50%, change to ELEV screen., set:
ELEV> Normal "S" OFF (& ON)
ELEV: 0% / -50%
Tested AOK on Twinjet, adjust % as required. The A9 monitor is a good guide..
Alternatively, If not already using dual elevator rates for speed purposes, simply dial in a "high"
elevator rate for takeoff/landing and a "Low" rate for flight.
Alternatively, change the elevator dual rate switch to a three position switch as attached.
see also:
. Aurora 9 - Delta or Flying Wing - Set up Elevon, Ailevator, Taileron & Launch Modes.
. Aurora 9 - Delta or Flying Wing - Set up EPA, D/R & EXP w/photos.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers & Telemetry
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by A.T. -- 1/31/2012 6:37 PM >
_____________________________
R/C hobby consultant for various companies
Hide Signatures
(in reply to JVB)
       Post #: 2
RE: Programming Aurora 9 - Elevon mode - 1/30/2012 8:03 PM
JVB
Score: 100
Status: offline
I don't want a different rate, I want both elevators (elevons) to be raised a bit on takeoff.
Hide Signatures
(in reply to A.T.)
       Post #: 3
RE: Programming Aurora 9 - Elevon mode - 1/30/2012 11:28 PM
mando
Score: 100
Last Login: 4/1/2013
Status: offline
For a little up with the elevons on take off just program a flight condition on a three position switch. For take off, flight condition 1 has a little more trim up. Flight condition 2, trim for level flight at maybe half throttle, and flight condition 3, trim for wide open throttle. You haven't changed the control rate, just the trim position. I learned this several years ago and works great with fast wings.......
You can't win if you don't enter
Hide Signatures
(in reply to JVB)
       Post #: 4
RE: Programming Aurora 9 - Elevon mode - 1/31/2012 2:35 AM
JVB
Score: 100
Status: offline
Mando,
I thought about that, but the manual makes no mention of being able to have different trims as a flight condition. Guess I should have just tried it.
Thanks.
Hide Signatures
(in reply to mando)
       Post #: 5
RE: Programming Aurora 9 - Elevon mode - 1/31/2012 2:57 AM
mando
Score: 100
Status: offline
Oh yeah, It only takes a smidge of up for take off, any more than that and it'll want to go straight up.......and double check EVERYTHING with the settings in each condition to insure they are the same.
Hide Signatures
(in reply to JVB)
       Post #: 6
RE: Programming Aurora 9 - Elevon mode - 2/5/2012 3:41 PM
cxcooper
Score: 100
Last Login: 3/20/2012
Status: offline
JVB,
I wanted to be able to do the same thing with my FunJet.... This what I did... the FunJet does not have flaps but I chose a delta model that had flaps so I could assign some up elevator to a switch for hand launches...
1) System->Model Type -> Flying Wing "2Aile+1Flap" 2 Servo
2) Model->2/2->FLAP CON
Mix: On
Switch: SW-A
0
Flap: 0%
Elev: 0%
1
Flap: 100%
Elev: 50%
Hide Signatures
(in reply to mando)
       Post #: 7
RE: Programming Aurora 9 - Elevon mode - 2/5/2012 3:50 PM
JVB
Score: 100
Status: offline
cxcooper,
Thanks. I accomplished what I wanted a bit differently. I too have a Funjet (ultra). I went back through the setup so that I had Spoilerons. I then had the airbrake function listed. I adjusted values (don't have them in front of me) such that when on, it gives me a touch of up on both surfaces for takeoff. I then set up two flight conditions, takeoff and high, along with normal on a three-way switch (C I think). Low position is takeoff, then normal then high. For takeoff, I have the airbrake engaged and low throws, for normal I have the airbrake off and low throw and I have higher throws set up on the high condition. Seems to work well. Can't wait to maiden it. We got 11 inches of snow yesterday so it will be a while.
Hide Signatures
(in reply to cxcooper)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
