RE: Spektrum DX18    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Spektrum DX18
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Spektrum DX18 - 2/15/2012 7:09 PM
John Tancock
Score: 100
Last Login: 5/22/2013
Status: offline
Servo slow is brilliant, doesn't matter what radio it's on! Have used it on the Futaba system, Martin used it on flaperons to introduce them in on the slow, when first test flying a model! The function went to normal speed when they were drawn back in again in case of severe pitching problems!
Hide Signatures
(in reply to Duncan)
       Post #: 201
RE: Spektrum DX18 - 2/15/2012 7:17 PM
vasek
Score: 147
Status: offline
quote:
ORIGINAL: schroedm
I've never used or seen model match but I can't help thinking that the chances of 2 models having the same channel assignments, centre points, directions, function etc is incredibly remote?? Or am I wrong?
I can't think of any model I've ever owned over the years where choosing a different model memory wouldn't be apparent either immediately (i.e. controls off centre) or after a 5sec check (i.e. surfaces operating back to front)
Am I missing something else it does for it to be 'a life saver'??
Maybe you don't own enough planes, my friend
The only people whom I have known that didn't like MM is BC their Tx didn't have it
_____________________________
Remember: Speed is life!
Hide Signatures
(in reply to schroedm)
       Post #: 202
RE: Spektrum DX18 - 2/15/2012 7:33 PM
JackD
Score: 100
Status: offline
quote:
ORIGINAL: schroedm
Marc, it is exactly for that. Turning on the transmiter on the wrong model can cause your landing gear to go up (destroying doors), surface binding, etc. I have stripped servo gears on things like retract valves by turning the radio on the wrong model
Of course you will notice before take off. you always do that 5 second up down left right check. Is what hapens immediately after turning on your radio what can hurt your plane.
Even if you are careful, I have left my plane on, to have someone else start my turbine (f100 at top gun...). In fact, ask my dad about his story about starting someone elses airplane in a trailer and setting it on fire...
later
Jack
Jack Gerardo Diaz
BVM Rep, Team Horizon, Team Jet Central
Hide Signatures
       Post #: 203
RE: Spektrum DX18 - 2/15/2012 8:04 PM
schroedm
Score: 103
Status: online
Vasek, I think I've owned enough models!
Jack, fair enough - I can see the merit in that. Perhaps never having had model match has got me into the good habit of checking things beforehand!
< Message edited by schroedm -- 2/15/2012 8:58 PM >
Hide Signatures
(in reply to JackD)
       Post #: 204
RE: Spektrum DX18 - 2/15/2012 8:23 PM
vasek
Score: 147
Status: offline
I was just teasing, no harm meant
Hide Signatures
       Post #: 205
HoundDog
Score: 178
Last Login: 5/21/2013
Status: offline
It's possible but slim ... But how many so called PILOTS do U see just slam the sticks back and fourth and say "Good ta Go' and don't really check for Correct positioning of flight surfaces ... That's the guys MM is intended for.
At least be thankful they arn't flying Maned aircraft.
Remember ... Every one of these Things we fly has a Termination date, The more expensive The bigger the tears.
Hide Signatures
       Post #: 206
RE: Spektrum DX18 - 2/15/2012 8:33 PM
HoundDog
Score: 178
Status: offline
quote:
ORIGINAL: JackD
quote:
ORIGINAL: schroedm
Doesn't happen if the Receiver is turned on after the transmitter and the proper model has been selected. Again MM is for the Person that doesn't follow proper Proceedures. Next they'll want homming GPS's so when it looses "Bind" or what ever it'll come home buy it's self.
Hide Signatures
(in reply to JackD)
       Post #: 207
RE: Spektrum DX18 - 2/15/2012 8:41 PM
JackD
Score: 100
Status: offline
quote:
ORIGINAL: HoundDog
quote:
ORIGINAL: JackD
quote:
ORIGINAL: schroedm
Doesn't happen if the Receiver is turned on after the transmitter and the proper model has been selected. Again MM is for the Person that doesn't follow proper Proceedures. Next they'll want homming GPS's so when it looses ''Bind'' or what ever it'll come home buy it's self.
I wish I was half as perfect as you are... I myself make some mistakes once in a while, so appreciatte any additional help I can get....
Jack
Jack Gerardo Diaz
Hide Signatures
(in reply to HoundDog)
       Post #: 208
RE: Spektrum DX18 - 2/15/2012 8:51 PM
HoundDog
Score: 178
Status: offline
I wish I was half as perfect as you are... I myself make some mistakes once in a while....
Congratulations on your perfection
Jack
     Jack  Me Matty ... It's not perfection ... It's Procedures, Procedures, Procedures. Follow the Procedures, Use the Check List, Engage Brain, Then check and double check. Never get complacent. All complacency will get ya is a "Big Expensive SMOKI'N Hole in the Ground"
Hide Signatures
(in reply to JackD)
       Post #: 209
RE: Spektrum DX18 - 2/15/2012 9:27 PM
madmodelman
Score: 110
Status: online
Well, that's me finally done with RCU, fed up with reading crap from people who obviously know everything and never learnt English at school, jeez.
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
       Post #: 210
RE: Spektrum DX18 - 2/15/2012 10:04 PM
Mart (Ham)
Score: 100
Last Login: 5/16/2013
Status: offline
I am also fed up with Some of the crap posts and have also now blocked houndDog.
Martin
Hide Signatures
(in reply to madmodelman)
       Post #: 211
RE: Spektrum DX18 - 2/15/2012 10:15 PM
Gordon W
Score: 105
Status: offline
It's easy. Just click on the block icon (the red hand thingy in the area below the text), and you'll never have to read his crap in bold text again. Of course, if some idiot chooses to reply to the buffoon by using the quote button, his crap will appear, but it's easier to ignore that as it's not in bold. All we really need is for everyone to block the troll and no-one will then reply to him and all will be sweetness and light. Best of all, the block button works across all threads.
FWIW, I've just programmed my two small Wren 44Gold powered jets for my DX8, which has replaced the JR10X which I've been using for 12 years. The 10X lost its touch-screen display when a sudden rain shower wet the screen and made it go blank - good luck 18MZ owners! The DX8 is 3/4lb lighter than the 10X, has a more comfortable shape to hold, and is a joy to program even in comparison with the 10X. I'll definitely be getting a DX18!
Gordon
Hide Signatures
       Post #: 212
RE: Spektrum DX18 - 2/15/2012 10:29 PM
RJE
Score: 100
Status: online
Gordon,
Thank you very much...Done, I should have done that long ago...
Hide Signatures
(in reply to Gordon W)
       Post #: 213
RE: Spektrum DX18 - 2/15/2012 11:40 PM
John Tancock
Score: 100
Status: offline
We do have a function on the 18MZ, where by the major functions carry an alarm when turning on the radio, which will not modulate until the said functions are reset (retracts, engine start etc........)! Not MM I know, but it does stop such mistakes!
Well said Gordon, an easy solution to mindless rants!
JT
Hide Signatures
(in reply to JackD)
       Post #: 214
RE: Spektrum DX18 - 2/16/2012 12:08 AM
madmodelman
Score: 110
Status: online
Thanks Gordon and you other guys, nice to know I'm not the only one fed up with him.
Just ordered one btw, hope I'm not gonna be a Guinea Pig!
Hide Signatures
       Post #: 215
RE: Spektrum DX18 - 2/16/2012 12:20 AM
John Tancock
Score: 100
Status: offline
The great thing about the latest generation radios is the fact that the hardware stays the same, the updates are free to download online keeping your gear bang up to date! So I'm sure any bugs you may find will be taken care of in this manner, I had this function for quite a few years on my FX40! Great system and easy to use. I'm sure the DX18 will be the same.
JT
Hide Signatures
       Post #: 216
RE: Spektrum DX18 - 2/16/2012 12:23 AM
larshkj
Score: 100
Last Login: 4/29/2013
Status: offline
quote:
ORIGINAL: JackD
Maybe I'm misunderstanding, but how can this happen with any modern 2.4 GHz radio, with or without model match?
Hide Signatures
(in reply to JackD)
       Post #: 217
RE: Spektrum DX18 - 2/16/2012 1:01 AM
Gra55h0pper
Score: 100
Last Login: 5/20/2013
Status: offline
That particular example will not happen anymore with any of the modern 2.4 radios, I think. However, without MM all planes you own will listen to one and the Tx. At my local club someone accidentally had is EDF which was parked in the pits start accelerating at full throttle as he'd forgotten to turn the Rx off while he was starting up the turbine in one of his other planes.
I think MM is a nice feature and consider it insurance just for the extremely remote case I would ever forget to follow a procedure or would ever miss to execute a check one of my extensive checklists. I'm guessing the only reason other radios do not offer it is because it's probably patented by Spektrum (?).
I think this new radio announcement is another step forward and am excited about it. I hope JR will follow suit with a new version of its high-end radio. The 12X is definitely getting outdated.
Hide Signatures
(in reply to larshkj)
       Post #: 218
RE: Spektrum DX18 - 2/16/2012 5:04 AM
vasek
Score: 147
Status: offline
quote:
ORIGINAL: madmodelman
Put her through the paces, then post a report
I gather the UK version will have the reduced signal strength as per EU guidelines (?) Is there a way to set the US strength back up with the menu in this one? I've done it with my other Tx's I own.
Hide Signatures
       Post #: 219
RE: Spektrum DX18 - 2/16/2012 7:15 AM
Duncan
Score: 110
Last Login: 4/13/2013
Status: offline
quote:
ORIGINAL: John Tancock
JT
That's slightly different mate, if you were to switch on a the wrong model memory l, the gear servo/valve may be reversed and still activate even with the rc thinking the switch was in the same place. MM is just an idiot proof way of doing it, it stops those D'oh moments when you're not concentrating as much as you should be.
As for the Troll, I blocked him days ago so this thread has become interesting and informative again. I'm not sure why the old prop flyer is posting on the jet section anyway. Maybe he annoyed the scale boys as well lol
Aero-creative - Vinyl Design & Application
www.aero-creative.com
Hide Signatures
(in reply to John Tancock)
       Post #: 220
RE: Spektrum DX18 - 2/16/2012 7:16 AM
Duncan
Score: 110
Status: offline
Double post damn RCU hang up
Hide Signatures
       Post #: 221
RE: Spektrum DX18 - 2/16/2012 7:59 AM
dubd
Score: 135
Status: online
quote:
ORIGINAL: HoundDog
     Jack  Me Matty ... It's not perfection ... It's Procedures, Procedures, Procedures. Follow the Procedures, Use the Check List, Engage Brain, Then check and double check. Never get complacent. All complacency will get ya is a ''Big Expensive SMOKI'N Hole in the Ground''
Hide Signatures
       Post #: 222
RE: Spektrum DX18 - 2/16/2012 8:57 AM
madmodelman
Score: 110
Status: online
I don't know, anyway we can't turn it up over here, breaks all the rules, BMFA, Insurance & the Radio Authorities that control our spectrum., the RCA.
Dubd, lol!
Hide Signatures
(in reply to vasek)
       Post #: 223
RE: Spektrum DX18 - 2/16/2012 12:07 PM
Couch Potato
Score: 105
Last Login: 5/15/2013
Status: offline
Just ordered one btw...
Did you check that your short fingers will reach the sliders ?
Hide Signatures
       Post #: 224
RE: Spektrum DX18 - 2/16/2012 12:15 PM
madmodelman
Score: 110
Status: online
Lol! The launch timing of the DX18 was disastrous!
As you are obviously aware I am used to the DSX9 sliders and flap/gear switches that look the same on the DX18.
Anyone know if it has the servo slow/speed feature?
Gary.
Hide Signatures
(in reply to Couch Potato)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
